Thread for Specialized Sirrus
#877
Put in a nice leisurely 16.5 miles this morning, Next round of upgrade parts are streaming in. After last weeks single track riding, brakes are getting changed out.
Likes For GravelGurty:
#878
I was looking at force and ultegra sets, but came across some new GRX calipers for a steal, and picked up a set of saint centerlock rotors.
From day one I haven't liked how cheap the stamped levers feel, I've yet to decide on a replacement. I'd like to get tool less reach adjustment, but still unsure.
#880
Quoted: 1581 Post(s)
Liked 1,189 Times
Soooo ... a quick preliminary update on my Sirrus X Comp.
As I've mentioned a couple times here, the FS cartridge on mine was defective from the get-go (June of this year): noisy, and with a distinct metallic 'click' whenever it neared full compression. LBS tried a number of different things, to no avail, so ordered a replacement under warranty.
I asked for the version of the cartridge that was on the original Roubaix -- linear, not progressive, spring -- as my bike is and will be used as a 'road bike'. The replacement was done today, and when I went to pick up my bike --
What Specialized sent was the Future Shock 2.0 cartridge, as one gets with the top-end 2020 Roubaix: full hydraulic damping w/a dial that goes from full-open to almost (not quite) lockout. No 'booster springs'. Retrofit more or less seamlessly into my bike with a bit of fiddling; no major bodges required. Initial impressions (short ride home): utterly silent; buttery/silky smooth; looks nicer; ruts/imperfections etc. absorbed fluidly. A complete transformation of the bike, which now 'feels' like what I was expecting when I ordered it.
So: with that, and with change to Roubaix Pro 32 tires, and with brakes sorted: bliss.
I'll update this with a fuller report, and pics, after a few more kms.
Likes For badger1:
#883
Liked 1,189 Times
Apologies for the crap pictures; best I can do at the moment. So, pic 1 is of the bike as at a couple days ago: stock, with the only changes being my preferred contact points -- XT (xc) pedals; Avatar saddle; and Ergon GP2 grips -- along with a new set of my favourite tires, Spec. Roubaix Pro 30/32.
As I've mentioned, I've had a few teething problems such as noisy brakes and so on. These were all addressed; the one outstanding issue was an obviously-defective FS cartridge -- noisy/clicky etc. As noted a couple posts back, this has now been replaced by the FS 2.0 cartridge as supplied on the upper-end 2020 Roubaix. This was an unasked-for treat; it was what was sent by Spec. as a warranty replacement for my 1.0 cartridge. Still early days, but as noted above -- what a difference! Pics 2 and 3 try to show the thing.
Likes For badger1:
#884
That new future shock looks awesome! Do you think its a touch taller, or an optical illusion on my part?
#885
Could you ever so kindly provide me with the part number for the rear caliper adapter.. I foolishly thought flat mount meant "direct mount".. Hey guess what the wheel doesn't go back on, I got to put the old stuff in the rear back on so I can still roll this week. Front looks good though, Deore XT 8100 levers enroute.
#886
Liked 1,189 Times
However, on reflection I'm pretty sure actual stack height above the headtube is the same, or within a very few mms. Might actually be around 1 or 2 mms, which you can see in the 'gap' between the bottom of the shroud and the actual headtube, which iirc is very, very slightly greater than the gap was with the stock cartridge. I was actually in my lbs today and looked closely at a 2020 Roubaix Expert: same cartridge/shroud, and that gap is virtually identical, so I expect that's where that very small difference is.
In any case, I still have my preferred slight saddle-bar drop of around 2 cms. I think the main reason for the perceived height difference is the damper knob perched on top; it is itself a good centimetre tall.
BTW, your brake upgrade is pretty much what I'm thinking, though still considering going with Ultegra flat-mount calipers with Ice-Tech and XT levers.
#887
#888
Liked 1,189 Times
I've been a customer there since I re-started cycling in '02; never shopped anywhere else. Lucky, I guess; reading some of the 'lbs' threads here on teh Biek Forms one would think ... well, you know.
#889
Yep, good to know and thanks. I'm pretty sure my lbs will take care of all that; the crew there is fantastic even with an aging Fred like me! They really know their stuff.
#890
Liked 1,189 Times
@badger1 have you considered any other saddles apart from Avatar and also any reviews about Avatar that you can share, I am considering either Avatar or Toupe, will be checking out whether I can get to demo both so that I can decide. Grips is something I want to change, howz Ergon GP2 in terms of comfort to the stock grips ? Any other that you have considered before buying this.
Grips are kind of the same. I've been using Ergon exclusively since they became available in North America -- whenever that was. '07ish maybe? Again, they 'just worked' for me from the get-go. First thing I changed on my '10 Sirrus and again on this new one. I found the stock ones on the '19 particularly awful; they were on the bike for all of the 10 kms or so it took to ride the bike home from my lbs.
Two things about Ergons. First, watch the sizing. They come in 'Small' and 'Large' (or equivalent): the 'Large' really are huge. I use 'Small'. Second: be prepared to fiddle a little with angle. I can now set a new pair by feel/look because I've been using them for so long, but if you get them take an Allen key along with you the first few rides so you can alter the angle a little til they 'feel' right. Remember too that though they are very popular they don't suit everyone.
#891
Okay thanks for the reply, I will try to demo Avatar and Toupe and then decide. Yeah even the Ergon I need to try out, looks a little too big for me.
#892
Quoted: 7 Post(s)
Greetings from the UK
I came across this forum when researching all things Sirrus, so hope someone can help ??
I've just been GIVEN a Sirrus Expert Carbon by Specialized after my ten year old Crosstrail with 12,000 miles on it developed a crack in the frame. Well, in truth, they offered me an Elite, but I asked if I could put a few hundred pounds towards a further upgrade and got the Expert, as I wanted a bike with "suspension"
I must admit, it's not as comfortable as my old Crosstrail, and the future shock.......isn't, and it creaks and groans with what I assume is the internal cabling, but hey-ho, it is what it is
Anyway........to get to the point.......I've been reading about how careful you have to be about adding accessories to a carbon bike, to the point I am paranoid about putting a pannier rack on. I've ordered a Topeak Super Tourist Uni pannier rack and a seat post clamp with pannier bolt holes. I'm worried that where the bottom lugs are on the rack will crush the frame where the eyelets are ?? Can anyone reassure me that this won't happen ?? Would it be safer to put a couple of small washers between the frame and the lugs so they are not in contact with each other ?? Are the eyelets carbon on the outside where the bolt head sits or alloy ??
any advice would be warmly welcomed,
cheers,
Graeme
cheers,
Graeme
#893
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
#895
Liked 1,189 Times
I haven't, and probably wouldn't, but I don't think there's any technical reason one couldn't.
I think the only restriction might be to stay away from anything in 650b much below a 40mm tire, as that might drop the b/b down a little too low. If I wanted to run really wide tires (anything over 40mm) on the bike -- either road slicks or gravel tires -- I probably would go with 650b. This is pretty common practice now in the 'gravel' world.
But I don't; already binned the stock 38s for 32mm road slicks.
#896
Liked 1,189 Times
Btw, continuing the update, this bike, w/high-quality road tires and this gizmo (FS 2.0) is simply a wonderfully-smooth 'road ride', while being very quick-handling. I've now ridden my '10 Sirrus (same tires/better wheels) back-to-back with this one: night and day as far as my aging/arthritic self is concerned.
Likes For badger1:
#897
Liked 310 Times
Glad to oblige; not great, but the best I can do at the mo, Colonel.
My wallet is glad I'm not in the market right now for another bike.
Likes For Meech33:
