Useless and Worthless Tools
Old 05-11-16, 12:11 PM
techsensei
A couple of current threads got me thinking about tools that I think are inadequate, a waste of money, something I would never use, etc. For example, I've never bought a handlebar holder; the thing that keeps the front end of the bike from swinging when the bike is in a repair stand. The few times I tried one, it annoyed me more that the bars were immobile. Until I became a total tool geek, I'd never buy the "fake pedal" thingie either ... the thing you screw into the right crankarm for when you're building up a bike. Why not just screw in a pedal? Waste of money to look more "pro."
What tool do you never see yourself buying? What tools have you bought that you ended up regretting?
techsensei is offline
Old 05-11-16, 12:19 PM
dr_lha
Bikes: 2016 Black Mountain Cycles Monster Cross v5, 2015 Ritchey Road Logic, 1998 Specialized Rockhopper, 2017 Raleigh Grand Prix
Quoted: 360 Post(s)
I've found my handlebar holder to be extremely useful when building up bikes. For everyday maintenance, it's not super useful, but I like to use it when doing jobs where keeping the handlebars steady is helpful, like putting on new bar tape.
dr_lha is offline
Old 05-11-16, 12:20 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1603 Post(s)
Liked 212 Times in 135 Posts
My Priority Classic came with a 2-ended 5/6mm Allen wrench that worked great, a pump that seemed pretty hinky but worked the one time, and a stamped combination wrench for the wheel nuts and pedals; the pedal end bent open when used. The intent of the package is that it includes everything you need to assemble the bike. I got feedback from the company, they intend to change the design of the wrench for the next run.
Genesis 49:16-17
Darth Lefty is offline
Old 05-11-16, 12:21 PM
Spoonrobot
Spoonrobot's Avatar
Quoted: 1102 Post(s)
Liked 89 Times in 64 Posts
Park tire levers are 100% junk
When I was a pro mechanic I used a cable puller pretty much everyday as well as the dummy pedal but now that I just home mech I never use those things. I even bought a cable puller after thinking it would be useful but it actually makes things take longer.
Spoonrobot is offline
Old 05-11-16, 12:29 PM
blakcloud
blakcloud's Avatar
Bikes: Custom Winter Cycles flat bar road bike, Trek Domane SL6, Rivendell Sam Hillborne, Brompton S/M3L (modified)
Quoted: 326 Post(s)
Liked 17 Times in 12 Posts
I don't regret buying any tool that I own. If I used it just once then it did what is was suppose to do. BTW I own one of the those handlebar holders and love it. I have tools that I may never use again but if I do, at least I own it.
blakcloud is offline
Old 05-11-16, 12:34 PM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1213 Post(s)
Liked 56 Times in 51 Posts
I once had three different designs of "Third Hand Tools" and never used any of them. This was true of caliper, cantilever and V-brakes. I was always able to adjust the brake cable slack by holding the pads in contact with the rims with one hand and snugging down the clamp bolt with the other.
However, a "Fourth Hand Tool", which I got for free along with a used bike but never planned to buy, has turned out to be very useful for taking the slack out of shift cables and for tightening zip ties.
HillRider is offline
Old 05-11-16, 12:38 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 1791 Post(s)
Liked 63 Times in 48 Posts
There are very few tools that I regret buying. The first two that come to mind were really inexpensive initial purposes but ended up causing more problems than they solve.
(1) a Spin Doctor chain checker -- cheap little tool that gives you a quick and easy answer as to whether or not your chain needs replacing; great idea except that it almost always tells me my chain needs replacing well before it actually does. We've had more than enough threads about this, but it was the first tool that came to mind.
(2) a Park SW-7 "triple" spoke wrench -- Y-wrenches are a good idea, right? So when I bought my first spoke wrench I thought this would be a good idea. Little did I know that very nearly every nipple I'd come across would be the same size. Meanwhile, I rounded off more than a few nipples using the wrong size before giving in and getting the SW-0 (and then rounding off a few more even though it was the right size until I got the SW-40).
As for tools I can't see myself buying...mostly just things that are too expensive to be practical and even those I can't entirely rule out. I'll probably never buy a headset press because I can do the same job with $8 worth of parts from the hardware store for run-of-the-mill headsets and I'm willing to pay the LBS to install really expensive headsets. I'll probably never buy facing tools because dang those things are expensive. At the low end of the price scale, I'll probably never buy a nipple driver because I have a Dremel tool and a drawer full of old screwdrivers (and the tips on most retail nipple drivers seem to be too short).
Finally, I'll probably never buy a Abbey Bike Tools Team Issue Titanium Hammer, because I'm not the U.S. government so I can't justify spending $180 on a hammer, but if anyone wants to get me a Christmas present I'd really love to have one of these:
My Bikes
Andy_K is offline
Old 05-11-16, 12:44 PM
1989Pre
Standard Member
Bikes: 2001 Raleigh M80, 1989 Raleigh Technium, 1983 F. Moser Sprint, 1963 Freddie Grubb Routier, 1948 P. Barnard & Son
Quoted: 693 Post(s)
Finish Line Chain Cleaning Tool. "Drip-free design" they say. This thing will make a mess of your bike, the floor and anything else around.., and it does a terrible job of cleaning a chain.
1989Pre is offline
Andy_K
Andy_K's Avatar
Bikes: Yes
I have a fourth hand tool and tightening zip ties is pretty much the only thing I ever use it for. It is really good for that though. For shift cables, I prefer a pair of pliers.
My Bikes
Andy_K is offline
Old 05-11-16, 12:48 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
True. I've actually got two chain cleaning tools, because I guess I'm a slow learner. I started off with the Performance house brand, it didn't work well and eventually broke. I thought maybe the Park machine would be better and I guess it is...it hasn't broken. It's still somewhat less effective than a clean rag and a spray of degreaser.
My Bikes
Andy_K is offline
Old 05-11-16, 12:50 PM
techsensei
I love me the Hozan C-356! I find it nearly indispensable for cantilevers and centerpull brakes. But I never use it for side pulls, and I have never even tried to use it for derailleurs; that would be pointless.
Old 05-11-16, 12:53 PM
techsensei
When I worked in retail shops, I would always steer people away from buying those things.
Old 05-11-16, 01:29 PM
melloveloyellow
melloveloyellow's Avatar
Bikes: RitcheyAscent, FisherMontare
Got these decades ago for my Shimano 600 headsets. I've never encountered another headset I could use them on.
As mentioned before, multi-size spoke wrench means multi-frustration. Just get a red Spokey.
File Type: jpg
File Type: jpg
melloveloyellow is offline
Old 05-11-16, 01:35 PM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 24 Post(s)
I must be the only person that builds wheels with the Park SW-7 triangle spoke wrench. I have two "dedicated" spoke wrenches that work much better on really tight spokes (final tensioning). But for me the SW-7 is easier to add a full turn or two to every spoke.
Worthless tools? The Park chainring bolt holder. I bent mine up pretty bad the first time I ever tried using it on a tough chainring bolt that would turn but wouldn't loosen. Any tool that isn't as strong as my hand is pretty lousy.
I need a pair of these for my 600 headset! I used normal wrenches very carefully with a rag underneath, but would like to have the correct tool.
FastJake is offline
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 735 Post(s)
Liked 61 Times in 49 Posts
My 3rd chain whip?
Bill Kapaun is offline
Old 05-11-16, 01:39 PM
bikemig
bikemig's Avatar
Quoted: 3896 Post(s)
Liked 229 Times in 186 Posts
+ 1, I'd like that special tool for my 600 headset as well, lol.
bikemig is offline
Old 05-11-16, 01:45 PM
CliffordK
CliffordK's Avatar
Quoted: 9227 Post(s)
Liked 209 Times in 162 Posts
I like the multi-size spoke wrenches for carrying with me. That way I don't have to worry about having the right size, and I can even assist others if the need arises.
And, if a nipple has been replaced... I don't have to worry about it being the wrong size.
CliffordK is offline
Old 05-11-16, 01:52 PM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 630, '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 633 Post(s)
Liked 143 Times in 88 Posts
Worthless tools? The Park chainring bolt holder. I bent mine up pretty bad the first time I ever tried using it on a tough chainring bolt that would turn but wouldn't loosen. Any tool that isn't as strong as my hand is pretty lousy...
^ this. I just sheared one end from mine. Does Park offer a Craftsman-like warranty?
Phil_gretz is offline
Old 05-11-16, 01:57 PM
rfmarotti
rfmarotti's Avatar
Bikes: 2015 Redline Conquest Elite; 2014 Fuji Tahoe 1.1 27.5er; 2006 Scott Speedster S30 (sold); 2001 Specialized S-Works CX; 1990 Trek 750 (sold); 1999 Bianchi Volpe; 1988 Bianchi Campione D'Italia.
Quoted: 131 Post(s)
Originally Posted by Bill Kapaun View Post
My 3rd chain whip?
rfmarotti is offline
Old 05-11-16, 02:21 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1214 Post(s)
Liked 67 Times in 52 Posts
That's way too beautiful to use as a hammer, that makes it a Pope tablecloth..
My grandmother hand made the most beautiful lace tablecloth that I've ever seen. It has never been used as a tablecloth because it was too good. It's always been reserved for when the Pope or somebody like that comes to visit. The Pope never came and now my grandmother (and mother) are dead. One of my kids has it now. To my knowledge it has still never been used.
Retro Grouch is offline
Old 05-11-16, 02:23 PM
Retro Grouch
If you can use that tool your fingers are a lot tougher than mine.
Old 05-11-16, 02:34 PM
dr_lha
Quoted: 360 Post(s)
Yes, I just replaced the chainring bolts on my bike with ones that take hex wrench on both sides, just so I didn't have to use that damn tool. Note I was replacing a chainring at the same time, so it was a opportunistic swap, before anyone says "well you had to use the tool to change the bolts anyway!
dr_lha is offline
Old 05-11-16, 02:52 PM
rmfnla
rmfnla's Avatar
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 269 Post(s)
I can't think of any bad tools I bought but years ago we got a shipment of made-in-Taiwan lock ring wrenches that said on them "Rock Ring Wrench".
I wish I could find the one I kept...
Today, I believe my jurisdiction ends here...
rmfnla is offline
Old 05-11-16, 03:34 PM
Miele Man
Bikes: Miele Latina, Miele Suprema, Miele Uno SL, Miele MTB, Bianchi Model Unknown, Fiori Venezia, VeloSport Adamas AX
Quoted: 351 Post(s)
Liked 54 Times in 42 Posts
Park USED to have a good warranty. However I'll no longer buy a Park tool unless it's the ONLY tool made for the job. The Park warranty sucks and they refused to replace two tools i have that broke in use.
A warranty is only as good as the company's willingness to stand behind it. My experience is that Park does everything it can to get out of a warranty replacement of a tool. Other's may have had better luck but I've blacklisted Park tools as far as any of my future purchases go.
Cheers
Miele Man is offline
Old 05-11-16, 03:39 PM
Miele Man
Quoted: 351 Post(s)
I was REALY luck to get a pair of those DUra ACE Ax headset wrenches recently for ONLY $12.50 U.S. I got hen for my Dura Ace AX headset.
Cheers
