Go Back  Bike Forums > Bike Forums > Clydesdales/Athenas (200+ lb / 91+ kg)
I'm 170kg looking for recommendation.
Clydesdales/Athenas (200+ lb / 91+ kg) Looking to lose that spare tire? Ideal weight 200+? Frustrated being a large cyclist in a sport geared for the ultra-light? Learn about the bikes and parts that can take the abuse of a heavier cyclist, how to keep your body going while losing the weight, and get support from others who've been successful.
Old 09-15-17, 02:25 AM
LaughingBasher
Hi guys, im trying to lose weight by cycling such i used to love but sadly due to my weight and budget there's no wheelset that can handle my weight.
So anyone can recommend me on cheap 27.5" wheelset for my MTB?
I currently using a DH wheelset and Maxxis Detonator tyre sadly side wall of the tire starting to cracks...
LaughingBasher is offline
Old 09-15-17, 03:34 AM
checoles
checoles's Avatar
Bikes: Tern Link A7 Folding Bike, Marin Gestalt 2019
Quoted: 73 Post(s)
sidewalls cracking sounds like you're putting the pressure way too high or they're dry and old, not your weight.
In terms of a wheelset, whats your budget? one mans "budget" price is completely different to another's.
Cheers
checoles is offline
Old 09-15-17, 06:11 AM
Myosmith
Lover of Old Chrome Moly
Myosmith's Avatar
Quoted: 141 Post(s)
Liked 17 Times in 13 Posts
Please provide more information:
  • Type of riding you do: commuting, paved trails, off road, gravel, road, etc.
  • Make and model or at least the type of bike: road, touring, gravel/adventure, hybrid, MTB.
  • Size of tires and pressures you run.
In general, you'll want features such as 36 butted spokes (don't let anyone tell you straight gauge are stronger), double wall rim, eyelets (single or double), fairly wide rim (increases internal volume of any given tire). You'll also want to pick tires that have a fairly large volume such as; 28mm for a road bike, 32-35mm for a touring, hybrid or gravel bike. Higher tire volumes provided added protection to your wheelset.
As important as the components of the wheelset is the build. Your wheels should be 36-spoke, 4-cross, with adequate and relatively even tension and in both radial and lateral true. Avoid wheel damaging activities such as curb jumping, drops, potholes, or ramming your way over obstacles.
Myosmith is offline
Old 09-15-17, 09:34 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 735 Post(s)
Liked 61 Times in 49 Posts
Exactly how many spokes do you have?
You can prolong the life o your current wheels by having the spokes PROPERLY & EVENLY tensioned.
That may result in a better wheel than a CHEAP wheel set.
IF you need a new wheel, likely it would just be the rear. In that case, look for an offset spoke bed (OC) rim. It results in a more symmetrical (thus stronger) wheel.
Tire sidewall cracking is a different issue than wheel "strength".
Straight gauge spokes ARE stronger, but butted spokes result in longer wheel life.
Bill Kapaun is offline
Old 09-15-17, 10:02 AM
MRT2
MRT2's Avatar
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast, 1997 Bianchi Advantage, 1994 Trek 930.
Quoted: 829 Post(s)
Liked 3 Times in 2 Posts
I would suggest you go to a wheel builder and explain what you need, which is some stout rims and at least 36 spokes.
MRT2 is offline
Old 09-17-17, 03:05 AM
LaughingBasher
  • Type of riding you do: commuting, paved trails, off road, gravel, road, etc. For now paved trails to lose weight.
  • Make and model or at least the type of bike: road, touring, gravel/adventure, hybrid, MTB. MTB w/ DH wheelset 36H
  • Size of tires and pressures you run. 27.5"x1.5/85PSI
Noted, thanks for the tips.
Originally Posted by Bill Kapaun View Post
Exactly how many spokes do you have? Currently 36H
Noted, i felt that it's because of my weight i stretch the rubber rapidly when i steer, the cracks are all located near the rim.
Old 09-17-17, 05:10 AM
WOT
Quoted: 11 Post(s)
Liked 6 Times in 6 Posts
By any chance are your brake pads set too close to the tyre and actually cutting it as you brake?
Or is the wheel out of true and occasionally rubbing the pad?
WOT is offline
Old 09-17-17, 03:04 PM
Myosmith
Myosmith's Avatar
Quoted: 141 Post(s)
I stand corrected, Bill. I should have said "Don't let anyone tell you that straight gauge spokes make a more durable wheel".
Myosmith is offline
Old 09-17-17, 03:11 PM
Myosmith
Myosmith's Avatar
Quoted: 141 Post(s)
Hmmm . . . I'm heavy and have abused a lot of tires and have never seen what you describe. Could you possibly post some pictures of the problem?
I have a 26" MTB and a wheelset that has held up really well for me is a Rhyno Lite 36H rims, laced with DT Swiss Comp Spokes to Deore hubs.
Myosmith is offline
Old 09-18-17, 01:05 AM
LaughingBasher
I can't post image/link so replace DOT with .
iDOTimgurDOTcom/aqaUGYWrDOTjpg
Old 09-18-17, 01:06 AM
LaughingBasher
Center lock disc brake abd the rim seem ok to me
Old 09-18-17, 02:33 AM
Myosmith
Myosmith's Avatar
Quoted: 141 Post(s)
Image link takes me to the main page of an image storage website
Myosmith is offline
Old 09-18-17, 04:10 AM
LaughingBasher
Yes i upload the image to imgur
kansascity
Touring
8
05-01-19 07:00 PM
jsbach
11
08-14-17 10:14 AM
erqa
35
02-18-12 06:57 PM
you
Touring
5
02-11-12 11:59 PM
Conquius
General Cycling Discussion
6
06-19-11 09:45 AM
