crank upgrade?
crank upgrade?
Old 11-10-09, 10:27 AM
iamsomeguy
iamsomeguy's Avatar
crank upgrade?
I am currently running campy record 175 through axle (square bolt , not offboard bearing type) and was wanting to move to an offboard bearing crankset or something as light and stiff (tune?)
looking for recommendations around 500 ? something lighter than im currently running that I wont have to worry about tearing up (im 210 lbsish 6 foot 5)
iamsomeguy is offline
Old 11-10-09, 10:35 AM
AngryScientist
Lost
AngryScientist's Avatar
chorus or record ultra torque. done.
AngryScientist is offline
Old 11-10-09, 10:44 AM
iamsomeguy
iamsomeguy's Avatar
considering that is out of my price range (i dont run compact and dont plan on it any time soon)
Old 11-10-09, 10:52 AM
AngryScientist
Lost
http://www.totalcycling.com/index.ph...ecord0793.html
you said around 500. this is record for well under. chorus is less. both chorus and record come in compact and standard double. what am i missing here?
Old 11-10-09, 11:06 AM
iamsomeguy
iamsomeguy's Avatar
ahh nice , danka
ANy others ?
Old 11-10-09, 11:11 AM
JoelS
This. Or you could subscribe to BonkTown and wait for another Fulcrum Racing crank to come up. I think they were around $350.
Some sort of pithy irrelevant one-liner should go here.
JoelS is offline
Old 11-10-09, 11:47 AM
AngryScientist
Lost
ahh nice , danka
ANy others ?
honestly the campy cranks are so nice i wouldnt bother with even looking for anything else. the chorus one is really a nice unit for the price.
my link was to total cycling, try wiggle, lickbike and ribble too for their prices. they're all offshore, and they are all very reliable sellers.
Old 11-10-09, 11:57 AM
tagaproject6
tagaproject6's Avatar
Quoted: 502 Post(s)
Liked 155 Times in 88 Posts
Campagnolo Centaur Ultra Torque CT Carbon Crankset at bonktown right now for $199.99
tagaproject6 is offline
Old 11-10-09, 12:03 PM
bretgross
Bikes: Zinn road bike, Rockhopper MTB
You might consider looking at Lennard Zinn's Custom Cranks. As tall as you are (and presuming that you have proportionately long legs) he can supply longer crank arms. I'm 215 lbs/6'4" and the bike he's building for me will have 200mm crank arms.
bretgross is offline
Old 11-10-09, 12:35 PM
iamsomeguy
iamsomeguy's Avatar
thanks for the suggestions !!
anyone know about how much of a weight difference there is between the last generation metal campy 175's with record carbon bb to these ?
Old 11-10-09, 12:52 PM
clausen
clausen's Avatar
Bikes: Colnago Master XL, Bianchi Via Nirone 7, Marinoni Fango
+1
The Centaur would also be 10 spd. New Record, Chorus and Athena are 11 spd and the spacing between the chain rings may have decreased as they did from 9 to 10.
clausen is offline
Old 11-10-09, 01:03 PM
merlinextraligh
pan y agua
merlinextraligh's Avatar
Bikes: Wilier Zero 7; Merlin Extralight; Co-Motion Robusta; Schwinn Paramount; Motobecane Phantom Cross; Cervelo P2; Motebecane Ti Fly 29er; Calfee Dragonfly Tandem
Quoted: 907 Post(s)
Liked 13 Times in 9 Posts
Realize however that the square taper Campy BB has less friction than modern external bearing bb's.
IMHO, not much of an upgrade, and not worth the cost.
And unless you're flexing the crank to the point that its rubbing on the derailleur, or dropping the chain, getting a stiffer crank is highly overrated.
You could get lost and die.
You could hit a tree and die.
merlinextraligh is offline
Old 11-10-09, 01:45 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 858 Post(s)
Liked 81 Times in 66 Posts
Exactly why I'm converting my old school bikes to Campy 10 by way of Chorus square taper cranks from a couple of years ago. Can't beat the prices.
The loose ball BBs can be adjusted soooo smoothly. How do the older square taper cartridge BBs compare ?
FYI: http://www.bikeforums.net/forum-sugg...ad-please.html
Homebrew01 is offline
Old 11-11-09, 01:03 PM
iamsomeguy
iamsomeguy's Avatar
ditto on the prices of the square taper stuff they are smooth and pretty darn cheap now im running it on both of my good roadies and my race bike
