Clydesdales/Athenas (200+ lb / 91+ kg) Looking to lose that spare tire? Ideal weight 200+? Frustrated being a large cyclist in a sport geared for the ultra-light? Learn about the bikes and parts that can take the abuse of a heavier cyclist, how to keep your body going while losing the weight, and get support from others who've been successful.
average size?
Old 01-12-10, 09:30 PM
iamsomeguy
iamsomeguy's Avatar
average size?
im 6 foot 5 and weighing in at 220 , what would be the best way for me to get down lower , my diet is not complete crap but ive been aving a hard time getting lower , at my height is my weight average ?
iamsomeguy is offline
Old 01-12-10, 09:34 PM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 2010 Expedition, 03 GTO
Quoted: 709 Post(s)
You might be just right.
I wouldn't be concerned.
Fred "The Real Fred"
10 Wheels is offline
Old 01-12-10, 09:37 PM
DieselDan
DieselDan's Avatar
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
6'5" and 220? Sounds downright healthy.
DieselDan is offline
Old 01-12-10, 09:56 PM
bigvegan
bigvegan's Avatar
Depends on your frame / build.
Sounds pretty good to me, but if you're concerned, take a pic of yourself and see if you're happy with it.
bigvegan is offline
Old 01-13-10, 07:07 AM
chewybrian
"Florida Man"
chewybrian's Avatar
Quoted: 948 Post(s)
Liked 92 Times in 64 Posts
I'm the same height and weight, and it's not a bad number for me. On the BMI chart, it's just off normal and a few pounds into overweight. You may or may not really be overweight, depending on build and muscle.
I dropped a lot of weight to hit that number, but my body does not want to give up the last 10-15 that might get me to 'racing weight'. I don't stress about it, but I'm not a serious racer. If that's what you want to be, then it's critical, and you should get some help from a trainer.
If you just want to look better, try weight training. You can lose some fat, and look fitter, even if your body weight stays the same.
chewybrian is online now
Old 01-13-10, 07:30 AM
late
late's Avatar
Quoted: 9307 Post(s)
Liked 37 Times in 34 Posts
Drink coffee? Substitute green tea. Stash Fusion and Stash Japanese Special Occasion Green Tea are
both decent green teas that don't cost a lot. Brew 3 minutes to start. After I got used to it, I went to
4 minutes.
Sounds dumb, but on some people it works.
late is offline
Old 01-13-10, 07:41 AM
Go dog Go
Go get a VO2max test with body composition. Then it'll all be in black and white.
Go dog Go is offline
Old 01-13-10, 08:07 AM
CliftonGK1
CliftonGK1's Avatar
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
That's a key element to remember, is that the BMI chart isn't accurate for muscular individuals. At 6'6", my target weight is 210. That will put me at 9% bodyfat, but a BMI score nearing the low end of the overweight range. Overweight on the bodyfat charts is over 19%.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
CliftonGK1 is offline
Old 01-13-10, 08:24 AM
takingcontrol
Mass Mover
takingcontrol's Avatar
Bikes: KHS XXL
Umm.. I'm 6'5" and my Goal weight is 225........
takingcontrol is offline
Old 01-13-10, 10:20 AM
rockdog
rockdog's Avatar
Bikes: Co-Motion Americano - LBS Build, 90something Fuji Sunfire hybrid
I'm only 6'3" and dream of getting back down to 220, I'd say your good.
rockdog is offline
Old 01-13-10, 11:57 AM
deraltekluge
deraltekluge's Avatar
Bikes: Kona Cinder Cone, Sun EZ-3 AX
The BMI formula is screwed up for tall people. It uses the square of the height...it should use a higher power, perhaps 2.5 or so. The result is that the "normal" weight it gives for tall people is too low.
For instance, a 5 foot tall, 110 lb. person would have a BMI of 21.5, right in the middle of the "healthy" range. For a 6 foot person, the weight would be 158.4 lb. to get the same BMI, and for a 7 foot person it would be 215.6 lb. I can believe that 110 lb. for a 5 foot person could be a "healthy" weight, but the 7-footer would be near emaciation.
deraltekluge is offline
Old 01-13-10, 12:45 PM
Greg_R
Bikes: Surly LHT set up for commuting
+1. If you look at yourself in the mirror and want to lose more fat then I would suggest "Burn the Fat, Feed the muscle" as an excellent resource. It covers all three critical areas: mental, exercise, and diet. If you want to get better / faster on the bike then there are other resources (training area on the website as a starting point).
Greg_R is offline
Old 01-13-10, 04:23 PM
EKW in DC
EKW in DC's Avatar
Bikes: Trek 830 Mountain Track Drop bar conversion
That's what I was thinking. I'm 6'1" and would be pretty happy at 220. For now it's about my goal weight.
OP, were you just trying to rub it in?!
EKW in DC is offline
Old 01-15-10, 12:26 AM
iamsomeguy
iamsomeguy's Avatar
haha not trying to rub it in and for the guy trying toget down to 225 , keep going you have done an awesome amount of work so far!
late , what is up with the tea thing , im a coffee junky so that may be part of the problem ?
i have a some gut hanging around that i really want to loose , i was thinking about getting the vo2 max done , does anyone know of a good place to go get this done at in dfw ?
i have a hr monitor now and at 60 rpm im floating at 95 bpm and around 120 cadence getting up to 145 bpm (on my roller's with my track trainer ) 49 x 13 on 175 mm cranks
jskwarek
26
07-24-13 04:48 PM
Mark Stone
24
02-17-13 08:19 AM
finsfree
Road Cycling
14
07-30-11 01:04 PM
happa95
Road Cycling
1
06-18-11 09:15 PM
dooodstevenn
Road Cycling
16
06-20-10 10:30 PM
