8 speed chains compatible w. 9-speed cassettes...?
Old 07-27-10, 02:01 PM
norbikes
norbikes's Avatar
Bikes: lots!!
What issues, if any, would I encounter if I ran an 8-speed chain with a 9-speed cassette? Are the clearances too close to permit?
norbikes is offline
Old 07-27-10, 02:04 PM
Al1943
I would not try that.
Al1943 is offline
Old 07-27-10, 02:13 PM
josephjhaney
Quoted: 25 Post(s)
Liked 4 Times in 2 Posts
9 speed chains for 9 speed, there is a reason they sell separate chains, the 8 is too wide to work properly from everything I've seen.
Joe
josephjhaney is offline
Old 07-27-10, 04:15 PM
DieselDan
DieselDan's Avatar
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Won't work. Chain plates too wide. Get the correct part before encountering FAIL.
DieselDan is offline
Old 07-27-10, 10:34 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 36 Post(s)
Liked 7 Times in 7 Posts
Won't work. You'll find that the shifting will suck because the chain will constantly be trying to ride up on adjacent cogs. Been there done that.
operator is offline
Old 08-02-10, 04:42 AM
norbikes
norbikes's Avatar
Bikes: lots!!
Thanx for quick response! So it appears there are legit diffs 'tween diff speed drivetrains, and it's not all marketing hype. I'll stick w matching chains to drivetrains, and try to find tandem versions of the chain what will provide me w 2 lengths for cheaper than 2 separate chains.
norbikes is offline
Old 08-02-10, 06:33 AM
bigdaddy10028
chains are backwards compatible meaning a 10 speed chain would work on a 7 speed but not the other way around.
bigdaddy10028 is offline
Old 08-02-10, 07:02 AM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1212 Post(s)
Liked 55 Times in 50 Posts
That's certainly true for rear shifting. For front shifting, the narrow chain may give problems with a front derailleur intended for a wider chain. It will shift but may require some fiddling.
HillRider is offline
Old 08-02-10, 02:03 PM
josephjhaney
Quoted: 25 Post(s)
Additionally due to strength issues, I would not replace a 9 speed chain on a 9 speed system with a 10 speed necklace, er, uh, I mean chain
Joe
Old 08-02-10, 02:06 PM
Cynikal
Team Beer
Cynikal's Avatar
Bikes: Too Many
Quoted: 24 Post(s)
Why do you think that a 10 speed chain is any weaker than a 9? The shorter pins on a 10 sp chain should make it stronger, at least in theory.
Cynikal is offline
Old 08-02-10, 03:34 PM
DieselDan
DieselDan's Avatar
Theory? So is penis envy.
Ptcycles
Bicycle Mechanics
10
02-23-19 10:34 AM
spectastic
Bicycle Mechanics
17
03-05-18 01:35 AM
gosmsgo
Bicycle Mechanics
46
09-07-17 10:58 AM
millip
Bicycle Mechanics
10
03-24-12 11:20 PM
DLoMatic
Road Cycling
24
05-25-10 06:09 AM
