Grease for a Bendix Coaster Brake Hub
Old 10-19-10, 02:25 PM
Grand Bois
Grand Bois's Avatar
Quoted: 430 Post(s)
Is Park grease good enough, or do I need something special? Sheldon Brown mentions high temperature grease.
Repack Hill is nearby, but this bike will just be ridden around the neighborhood.
Grand Bois is offline
Old 10-19-10, 02:36 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6924 Post(s)
Liked 246 Times in 204 Posts
Tub of HT Disc brake wheel grease is probably cheaper than Park sold for bikes.
fietsbob is offline
Old 10-19-10, 03:00 PM
bikeman715
bikeman715's Avatar
Bikes: Bike Nashbar AL-1 ,Raligh M50 , Schwinn Traveler , and others
Quoted: 85 Post(s)
Yes Park's grease will work just fine for you. I use it for all of my coaster brakes' rebuilds.
bikeman715 is offline
Old 10-19-10, 03:10 PM
Grand Bois
Grand Bois's Avatar
Quoted: 430 Post(s)
Thanks! This is my first coaster brake rebuild.
Old 10-19-10, 03:21 PM
davidad
Quoted: 330 Post(s)
Liked 20 Times in 20 Posts
Any automotive grease is more than good enough for our applications.
davidad is offline
Old 10-19-10, 03:22 PM
bikeman715
bikeman715's Avatar
Quoted: 85 Post(s)
hey good luck with it, if you need any help with it let me know and i be more than happy to help out.
Old 10-19-10, 06:03 PM
Grand Bois
Grand Bois's Avatar
Quoted: 430 Post(s)
Thanks again, bikeman, the shoes are worn awfully thin and the rims are rusty. I'm tempted to just but a wheelset. At least I can add rebuilding a coaster hub to my resume.
I sincerely hope that this doesn't turn into another grease thread. I already have the Park grease. I'm not interested in buying a tub of anything else. I'm sure I could save big bucks by buying some sort of automotive grease in a tub, but the park in tubes is convenient and two tubes have lasted over two years and nine complete overhauls.
Old 10-19-10, 08:35 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1807 Post(s)
Liked 140 Times in 102 Posts
Park grease is fine. Even on "Repack Hill" all you'll need to do is repack.
JohnDThompson is online now
Old 10-19-10, 08:48 PM
curbtender
curbtender's Avatar
Quoted: 566 Post(s)
Liked 66 Times in 50 Posts
Pack those shoes in grease also. Did you go up to the 'Bikefest'?
curbtender is offline
Old 10-20-10, 12:25 PM
Batavus
Bikes: Wabi Lightning, fixed 13.6 pounds. Cera steel road bike Campy veloce 9s
coaster brake hubs need 'stahlbremsenfett'. We use it on coaster brakes and planetary gear hubs (mainly Sachs/Sram) to grease the sun and planetary and ring gears. It is available through SRAM.
Batavus is offline
Old 10-20-10, 12:35 PM
bikeman715
bikeman715's Avatar
Quoted: 85 Post(s)
yes one tub of park's grease can last a long time. I go though a can every year.
Old 10-20-10, 02:02 PM
Grand Bois
Grand Bois's Avatar
Quoted: 430 Post(s)
There's a link to my pictures here:
http://www.bikeforums.net/showthread...oberfest-today
Old 10-20-10, 05:03 PM
curbtender
curbtender's Avatar
Quoted: 566 Post(s)
Looks like I missed some good ciopino...
Old 10-20-10, 07:19 PM
Grand Bois
Grand Bois's Avatar
Quoted: 430 Post(s)
It's Paella at Biketoberfest, not ciopino at bikefest.
Old 10-21-10, 05:15 AM
kingsting
Bicycle Repairman
kingsting's Avatar
Bikes: Many
Quoted: 10 Post(s)
Liked 3 Times in 2 Posts
Most of the old school shop manuals recommend giving Bendix hubs a shot of oil (30W is fine) in addition to greasing all the internal parts.
kingsting is offline
Old 10-21-10, 10:29 AM
Grand Bois
Grand Bois's Avatar
Quoted: 430 Post(s)
Where do you shoot the oil?
Old 10-21-10, 03:15 PM
bikeman715
bikeman715's Avatar
Quoted: 85 Post(s)
you can mix the oil with the grease before you put it in the hub or on the parts. just a few drops will do it . use more than that and the grease will break down into nothing but oil. just remember grease is nothing but oil in a soap mixer anyway.
Old 10-22-10, 06:47 AM
kingsting
Bicycle Repairman
kingsting's Avatar
Bikes: Many
Quoted: 10 Post(s)
I give it a squirt inside the hub shell and one somewhere near the ******er spring (keeps it from squeaking). That's usually all you need.
Old 05-12-14, 11:49 PM
bikeman68
HI temp waterproof grease
I have found that nothing compared to Phil Grease for resistance to wear and rust. When i used Parks grease I found out the hard way I couldnt count on it, rust formed on bearings after rain, and the riding scored bearing surfaces, Id rather use Wal Marts red universal auto bearing grease than Parks if you seek grease on the economy price side. The clutch and steel brake shoes definitely need a Hi temp grease in CB hubs, so dont use Oil or anything cheap
bikeman68 is offline
Old 05-13-14, 10:48 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 467 Post(s)
Liked 51 Times in 37 Posts
Did you happen to notice that you're replying to a thread that's 3 1/2 years old?
Jeff Wills
Jeff Wills is offline
Old 05-14-14, 07:19 AM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 591 Post(s)
Liked 87 Times in 73 Posts
Originally Posted by Jeff Wills View Post
We need the mods to edit this pic into the OP of every thread that's bumped from the grave.
Kimmo is offline
Old 05-14-14, 07:25 AM
rydabent
Quoted: 1360 Post(s)
Liked 45 Times in 29 Posts
The simple fact is that ANY automotive wheel bearing grease will work just fine. And the big deal is that since it isnt a namebrand cycling grease, it will cost tons less.
rydabent is offline
Old 05-14-14, 07:39 AM
unterhausen
Randomhead
Liked 71 Times in 61 Posts
depends on why the thread gets bumped. If it's over a couple of years old, we just close it. My suggestion is that after a while the background color is changed to green, which becomes darker and darker over time. So a 10 year old thread would be kelly green background. They don't take me seriously for some reason
unterhausen is offline
Old 05-14-14, 11:20 AM
bikeman68
Jeff we still need and will always need petrolium oil for mechanical friction, so when you learn how not all grease is the same and pay for that with hub damage, then knowledge is super valuable. Im just sharing what I learned with actual ride experience, riding in all conditions including rain which is the ultimate test so when 1 grease hold up and keeps races from scoring and rusting while another, such as PARK fails, thats a big difference especially since you end up with a wrecked hub thats a DRAG from that point. Its just a shame that some bearings greases are bottom of the barrel, and somebody will value this post in yr 2020 just the same
Old 05-14-14, 06:57 PM
Jeff Wills
Jeff Wills's Avatar
Quoted: 467 Post(s)
I don't understand what you're talking about. All I said was "Did you happen to notice that you're replying to a thread that's 3 1/2 years old?"
Jeff Wills
