PSA: Actual tire widths
Old 03-18-11, 11:57 AM
MileHighMark
Old. Slow. Happy.
MileHighMark's Avatar
Just wanted to give folks a heads-up on the 700x37c Conti Contact (2011) tires. They measure just over 34mm when mounted on a 24mm (outside) rim. This was after 24 hours at max psi. By contrast, my 700x32 Vittoria Hypers were only 1mm narrower, and actually taller than the Contacts.
I think it would be helpful if we could compile a list of actual widths for the popular commuting tires. Once I replace the batteries in my calipers I'll post some exact measurements.
MileHighMark is offline
Old 03-18-11, 07:54 PM
CliftonGK1
CliftonGK1's Avatar
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Good luck!
Tire manufacturers are notorious for bad sizing. Racers want the lightest gear, so tire manufacturers started claiming wider values than actual so they could say they have the lightest tire in its size. It's followed suit with quite a few non-race tires, but for non-racing rubber the problem seems to be batch-to-batch variability due to sloppy manufacturing tolerances. In an article from Velo News over the summer (about UCI changing the 34mm width max in CX racing) it was brought to light that one manufacturer has a tolerance of +/- 2mm. That means one batch of 28mm tires might be 26mm, while the next is 30mm, and they're within spec.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
CliftonGK1 is offline
Old 03-18-11, 08:36 PM
Ipedaltahoe
Ipedaltahoe's Avatar
Bikes: Motobecane Single Speed, Trek Mountain Track Xtracycle
interesting, I just ordered a pair of Kendas and went up to 38's for my SS and was worried they were going to be too wide but when I got them today I was surprised by how narrow they actually are.
Ipedaltahoe is offline
Old 03-18-11, 08:46 PM
CliftonGK1
CliftonGK1's Avatar
Put a caliper to them. My Conti Gatorskin 28s measured between 26.1 and 27. My 28mm Pasela TGs are 27.6 (closest I've ever seen to claimed) but the 32mm version is 30.8mm
- Mandi M.
Old 03-20-11, 03:16 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 1789 Post(s)
Liked 61 Times in 47 Posts
Continental is notorious for having narrower than advertised tires. That said, it does depend, to some extent, on the rims. I've got 700x28 Conti GP 4 Seasons on one of my bikes. The front tire, on a Salsa Delgado Cross rim, measures at 28.4. The rear tire, on a Ritchey Silhouette rim, measure 26.3.
Andy_K is offline
Old 03-22-11, 05:18 PM
Hibonite
Pasela 28, actual is 27. Michelin Dynamic 28, actual is 29. Michelin Dynamic 32, actual is 33. Michelin City 35, actual is 35.
Hibonite is offline
Old 03-23-11, 06:58 AM
tarwheel
tarwheel's Avatar
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 194 Post(s)
Width depends on the rims, which accounts for much of the variation.
tarwheel is offline
Old 03-23-11, 09:38 AM
MileHighMark
Old. Slow. Happy.
Yes, but if you always use the same rims, you've eliminated that variable. For example, I have a 700x37 Conti that measures 34mm wide, and a 700x32 Vittoria that's 33.5mm. Both were mounted on the same rim, and inflated to their respective max psi. That discrepancy is not due to the rim(s), but the fact that one company's tire is undersized.
Old 03-23-11, 12:29 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
...or they made their width claims based in different rim widths. I know I'm splitting hairs here, but if a rim exists on which the Conti 700x37 measures 37mm wide, then arguably it isn't undersized.
Andy_K is offline
Old 03-23-11, 12:59 PM
JeffS
not a role model
JeffS's Avatar
That's a stretch of logic.
Like this guy thinking his tires fit.
JeffS is offline
Old 03-23-11, 01:14 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Is it? Would you say that the Vittorias in MileHighMark's example are oversized?
Andy_K is offline
rustang351
Road Cycling
10
05-19-13 11:05 AM
smurray
Road Cycling
2
06-11-12 11:19 AM
Dannihilator
Mountain Biking
5
12-06-11 05:46 PM
FastJake
Bicycle Mechanics
12
10-31-11 09:15 AM
Nobodyetal
Commuting
5
12-17-09 11:09 AM
