Circa 1955 Phillips Step Through SA Dyno-Three Hubs with Working Lights! PHOTOS HEAVY
Old 01-07-15, 01:16 AM
Velocivixen
Velocivixen's Avatar
Quoted: 392 Post(s)
Liked 11 Times in 8 Posts
I already talked a bit about this bike on the "For the Love of Three Speeds" thread. Been wanting a project and something different, so spent $100 on a 1955 Phillips 3 speed with SA Dyno-Three hub dated "55", so bike likely around that era.
Front/rear lights work, chain has a "master link" type thing, front hub, rear hub & top of bb shell have oil ports. It's all original. Has original Phillips bell too. Strangely I didn't take the full bike photo, but it's sort of an "oxblood red" with gold lettering & stripes. Has Dunlop 26 x 1 3/8" rims and original "tyres" which say "The Silver Star Tyre....Extra Fine Quality...To Fit Rims B.S.F. 4 & EA 3" Looks like front chainring is approximately 47 teeth & rear about 18 teeth. Right brake is for the front & left brake for the rear. I tapped on the original brake pads and they actually sound like metal. Let's just say the test ride was short as bike really didn't stop me.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Last edited by Velocivixen; 01-07-15 at 01:26 AM. Reason: changed some duplicate photos.
Velocivixen is offline
Old 01-07-15, 01:21 AM
Velocivixen
Quoted: 392 Post(s)
Continued:
I pulled the seat post out and it looks pristine, just little rust where the saddle mounts. Stem moves also. I put some penetrating oil on the cotter pins as a prelude to tomorrow's excitement. I am in posession of a Park Tool Cotter Pin Press & the mechanic who gave it to me gave me some "tips". I plan to take care of the bottom bracket & headset first. If those are in good shape, then I'll clean & replace consumables.
Seller was a young guy whose friend's father passed away. He didn't know if the father rode it, but it was "in his family" and was housed in their barn outside of Portland. Very tiny amount of rust, just thick caked on grease & dust. So....feel free to impart any information, expertise or tips. Never dealt with cotter pins before.
Anyone know how to get that "master link" off & what kind of link it is? What chain? By the way, chain is not stretched, but very dirty, dry & stiff.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 01-07-15, 05:43 AM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Location: Ascending or Descending the NH Mountains NW of Concord!
Bikes: Snazzy* Schwinns, Classy Cannondales, & a Lonely '83 Santana Tandem (* Ed.)
Quoted: 488 Post(s)
Liked 51 Times in 33 Posts
Nice find Vv! I've had a '52 (minus the Dynohub and lights) in my basement for the past 4 years waiting for the same treatment. A member of my church has expressed interest so I need to get busy over the winter and bring it back to life so she can take possession this Spring. Mine is black with gold details.
Bob
Dreaming about riding in NH's summertime!
Visit my websites:
FreeWheelSpa.com orpastorbobnlnh.com
pastorbobnlnh is offline
Old 01-07-15, 06:24 AM
markk900
markk900's Avatar
Quoted: 144 Post(s)
Liked 3 Times in 3 Posts
Master Link: pretty typical style - easy to remove but also easy to poke yourself in the fingers doing it....The thin flat outer plate that looks like an extended "C" - you slightly spread the open ends apart and press the whole plate towards the closed end (and since the plate is so thin, this is where the screwdriver slips and pokes a hole in your hand). Once the closed end is moved off the link pin, the plate is rotated 90 degrees and pulled off. I usually do this by placing a suitable flat screwdriver flush with the open end and brute forcing the plate forward (not really a lot of force) - pushing will spread the arms, taking care not to hurt my hands, and it usually pops forward reasonably quickly. The other, more awkward way is to put a slightly larger flat screwdriver between the arms of the C on the inside of the pin, twist to spread the arms of the C, then with the third hand you don't have slide the clip forward.
BTW - that paint looks pretty good and will likely respond extremely well to polishing and waxing. Lots of folks recommend something like Meguire's Scratch-X followed by a good waxing....first thing you can try is a good rubdown with a cloth wetted with motor oil though....careful around the decals though.
markk900 is offline
Old 01-07-15, 06:40 AM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Bikes: 1977 Trek TX700; 1978/79 Trek 736; 1984 Specialized Stumpjumper Sport; 1984 Schwinn Voyageur SP; 1985 Trek 620; 1985 Trek 720; 1986 Trek 400 Elance; 1987 Schwinn High Sierra; 1990 Miyata 1000LT
Quoted: 1789 Post(s)
Liked 102 Times in 83 Posts
I'm looking forward to seeing it!
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Old 01-07-15, 07:02 AM
arex
Abuse Magnet
arex's Avatar
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll
Quoted: 67 Post(s)
Liked 7 Times in 4 Posts
Really cool.
arex is offline
Old 01-07-15, 08:54 AM
Number_6
Number_6's Avatar
Bikes: Too many to list in this particular space...
Too cool! Be prepared to get lots of attention, questions!
Number_6 is offline
Old 01-07-15, 09:13 AM
Pompiere
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T
Quoted: 224 Post(s)
Liked 14 Times in 12 Posts
I usually lift one side of the clip at a time off the pin on the open end, then turn the clip 90 degrees and slide toward the middle to lift off the other pin. I have done this on some chains with only my fingernail.
Nice find. My dad has a Hercules of similar vintage that he still rides in the summer.
Does any one know if the bags like on pastorbob's bike are still available?
Pompiere is offline
Old 01-07-15, 10:58 AM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1381 Post(s)
Liked 88 Times in 59 Posts
Heh, you bought it. I knew you would.
Surprised it lasted so long on CL in the PDX market.
● 1971 Grandis SL ● 1972 Lambert Grand Prix frankenbike ● 1972 Raleigh Super Course fixie ● 1973 Nishiki Semi-Pro ● 1980 Apollo "Legnano" ● 1981 Miyata 1000 ● 1984 Bianchi Limited ● 1984 Nishiki Landau ● 1984 Peugeot Vagabond ● 1985 Shogun Prairie Breaker ● 1986 Univega Nuovo Sport ● 1986 Merckx Super Corsa ● 1987 Schwinn Tempo ● 1988 Schwinn Voyageur ● 1989 Trek 400 ● 1989 Bottechia Team ADR replica ● 1990 Cannondale ST600 ● 1993 Technium RT600 ● 1996 Kona Lava Dome ●
Lascauxcaveman is offline
Old 01-07-15, 11:15 AM
icepick_trotsky
Aspiring curmudgeon
icepick_trotsky's Avatar
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 103 Post(s)
Cool headbadge.
"Party on comrades" -- Lenin, probably
icepick_trotsky is offline
Old 01-07-15, 11:55 AM
Velocivixen
Quoted: 392 Post(s)
@pastorbobinnh - fantastic bicycle! The person you fix it up for will really like it. As they say, "It'll buff right out" Could you please tell me what pump it on there & take photos if you've got time? Also the grips? That saddlebag is just great too. Wonderful find for you. Maybe my post will nudge you toward the refurb.
Thanks all. I'll keep you posted with the progress. Today is cottered crank day. It's been soaking in Liquid Wrench all night & I've got a cotter pin press so keep your fingers crossed.
Question: Black Tires or tan walls? I know tan walled tires like the Paselas are popular on older bikes, but how far back does that trend go? Current tires are all black & think that buy using tan/black tires it will take away from the overall aesthetics of the bike. Saddle is also black, grips are RED! (Hunt-Wilde so not original) and housing is beige. So I thought to keep tires/saddle/grips all black & either reuse housing or go black. What do you all think? I've tried more colorful housing & tan/black tires on other bikes & it was too "visually messy" & distracting.
Thanks.
Old 01-07-15, 03:05 PM
Velocivixen
Quoted: 392 Post(s)
Update: bent the left side cotter pin, but the right side came out easily. Removed the fixed cup, and undid the left side lock ring & adjustable cup and the entire bb is out.
Got the "master link" figured out & things are cleaning up nicely.
Question: That brown stuff is actually dirt that's sort of "baked on" I've soaked in oil & degreaser, but is not softening & am having to very carefully with a tiny tool, scrape it off. How to I scrape & not mess up the paint?
Old 01-07-15, 03:19 PM
pastorbobnlnh
Freewheel Medic
Quoted: 488 Post(s)
Try using the edge of a plastic scraper or even a plastic spoon as you remove more and move closer to the paint. I also like the green Scotch pads with a generous amount of Dawn dish detergent. The Scotch pad is basically plastic fiber, so it does not tend to scratch paint, but go at it slow and carefully.
Bob
Visit my websites:
Old 01-07-15, 04:28 PM
noglider
noglider's Avatar
Quoted: 5684 Post(s)
Liked 253 Times in 178 Posts
This is just great.
You won't need to take apart the rear hub. Just drop some oil in it.
Blackwall tires would be period correct. Skinwall tires came later and were not fashionable for three-speeds.
noglider is offline
Old 01-07-15, 05:32 PM
nlerner
Quoted: 1160 Post(s)
Liked 59 Times in 48 Posts
I just put a set of Schwalbe Marathon 590mm tires on a 3-speed; they seem pretty nice. And I did see that Harris is once again stocking Panaracer Col de la vie tires in that size. Those are very plush.
nlerner is offline
Old 01-07-15, 05:50 PM
nlerner
Sorry, Tom, but you're wrong. Look at the tires on this 1951 Raleigh Clubman advert:
For the Raleigh Sports and the like, the typical tire was actually a whitewall: the Dunlop Tourist Sprite. Here's someone's 1958 Raleigh with those tires:
Blackballs were common, too, but definitely not the only "fashion."
nlerner is offline
Old 01-07-15, 05:55 PM
noglider
noglider's Avatar
Happy to be corrected. Nothing to say sorry about!
noglider is offline
Old 01-07-15, 06:24 PM
Velocivixen
Quoted: 392 Post(s)
This is just great.
So what about the ball bearings in the outer part of the rear hub? Heck, I read the SA 1956 instruction manual for assembly/disassembly & was about cross eyed when done.
Thinking about getting the Rubena Flash V66 tires - $15 at local place.
I have another thread regarding the trials & tribulations of bent cotter pin. LBS whacked it & it came out.
Old 01-07-15, 07:34 PM
noglider
noglider's Avatar
I believe oiling the hub in the usual way will get oil into the bearings. I don't know about the AG hub, but I know it's easy to demagnetize the front dyno hub accidentally by not following procedure. I just don't think it's necessary, and it carries some risk.
noglider is offline
Old 01-07-15, 08:18 PM
markk900
markk900's Avatar
Quoted: 144 Post(s)
I agree with Tom on this one - you will be astounded at where the oil gets to! I think right now I'd leave the hub alone with just a squirt of fresh oil and ride the bike a bit.
@nlerner: thanks for the update on non-black tires - I just invested $50 in new tires for the Humber and ordered the Panaracer Col de la Vie from Niagara, along with some nice shiny CR18s. I was a little worried the tan walls might look out of place....When I first got the Humber it needed a saddle (a nice Brooks *had* to be obtained) - that doubled my investment. The new rims and tires are going to double my investment again.....but it will be worth it I hope, and it feeds the sickness.
markk900 is offline
Old 01-07-15, 08:24 PM
Salubrious
Salubrious's Avatar
Quoted: 180 Post(s)
Liked 7 Times in 6 Posts
A good oil for SA hubs is automatic transmission fluid. The next thing you will want is a period correct oiler can so you can oil the fittings on the bike in style
Salubrious is offline
Old 01-07-15, 08:38 PM
The Golden Boy
That's just a small example of what makes you awesome Tom.
Old 01-07-15, 09:13 PM
mechanicmatt
Hoards Thumbshifters
mechanicmatt's Avatar
Bikes: '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '07 Stumpjumper
Quoted: 43 Post(s)
Liked 28 Times in 15 Posts
Velocivixen, I just wanted to say how much I have enjoyed you constantly stepping up your game with repairing/restoring bikes since you have joined BF. It's fun to see someone so open minded and with such good spirit go about learning to do all this stuff. I think we all appreciate it.
mechanicmatt is offline
Old 01-07-15, 11:52 PM
Big Block
Quoted: 147 Post(s)
plain black tyres on this one from 1955
have a look through the 1955 catalogue
Big Block is offline
Old 01-08-15, 12:03 AM
Velocivixen
Quoted: 392 Post(s)
Thanks you so much for the compliment. It helps to have an open minded and generous group of members here who are willing to give information, photos, divergent opinions, and just about everything. I so appreciate it.
I'm torn on the tires. On one hand I want to get some decent riding tires, because if I get super cheap ones now, then end up loving the bike, making new wheels I'd want "nicer" tires, so then I'd have a inferior pair hanging around. I don't really want/need several pairs of 26 x 1 3/8" tires around. On the other hand, I don't want to buy real plush & expensive tires and come to find out that I don't really like riding the bike. If I sold it not sure I could get my money back. I figured if I got the Rubena V66 Flash or the Continental World Tour they would be somewhere middle of the road.
Grips? Not leather. Preferably black. Period correct or era correct?
Handlebars? Don't necessarily wanna spring for Nitto, not knowing whether or not I'll love the bike. VO Has "Tourist" bars supposed to be for English 3 speeds. Thoughts?
OK....now the good stuff. Pictures:
Some "before" & "afters". Master Link chain system, spindle from bb, fixed cup. The chain even says "Made in England" as do all the other parts so far. I'm still working on that baked on brown dirt on the bb shell. Ugh....slow going.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
