Let's Talk Consummables
Old 02-02-15, 07:27 PM
zazenzach
zazenzach's Avatar
Quoted: 16 Post(s)
What do you use for cables, housing, tips and crimps?
What are your opinions on galvinized vs stainless vs teflon coated cable wires? Is housing a big deal- do you need the fancy jagwire stuff or will the lower end stuff do just fine?
At numerous times I've considered buying bulk. Do you recommend this option or do you usually go on a pay as you need basis?
zazenzach is offline
Old 02-02-15, 07:37 PM
Chombi
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 140 Post(s)
I'm always looking for sources for clear cable housing with the inner plastic lining for smooth cable action. The ones that were used on early to mid 80's bikes, where you can see the silver, coiled, flat spring from the outside through the clear plastic outer sleeve. Only regular source I can find is Pork Chop BMX from eBay, but I have found a set from DiaCompe too, a couple of years ago.
Every time I asked for some from LBS's they tend to always give me a weird look then promise to check if they still have the big spool they remember they had of it somewhere in the shop or at shop owner's house,......... but of course they never come up with it....... the hoarders.....
Chombi is offline
Old 02-02-15, 07:41 PM
TiHabanero
Quoted: 824 Post(s)
Liked 95 Times in 64 Posts
Pay as you go, unless you are cabling an awful lot of bikes every year. Bulk is nice and handy, though. I use regular QBP cables and bulk housing on my own bikes. Works very well. Unless there is a need for the super slick stuff, keep it simple.
TiHabanero is offline
Old 02-02-15, 07:43 PM
oddjob2
Still learning
oddjob2's Avatar
Bikes: Too many
Quoted: 824 Post(s)
Liked 6 Times in 6 Posts
A picture is worth a 1000 words. Bulk is worthwhile under the following caveats:
  • I try to turn 2 bikes or more a month on average.
  • I use the same parts on the bikes I keep as the bikes I resell, except maybe tires.
  • I try to minimize cost on a bike reconditioned for resale, but use good quality consumables. Some will argue that Kenda tires are cutting corners, no pun intended, but Kenda is a large OEM supplier on LBS bikes as well.
  • I hate paying for postage and now Niagara wants $150 minimum order, so a box of cables and I am at $100 already.
  • Stainless is worth the slight upcharge.
  • I have used XLS, but recently switched to Jagwire. I can't "feel" the difference, but the price gap is reduced in the last 12 months.
  • Bulk bearing buys can save a bundle. I bought 3000 1/4 balls and saved about 75% off bottled bearings.
  • Bulk cable housing purchases savings are about 2/3 less than individual item purchases.
I stock several colors of brake cables, more than the better LBS, and most of the bikes are friction shifting, so I don't need much SIS cable. I only stock black SIS cable because I only need a short loop at the RD. I have yet to redo a brifter setup needing another cable color.
oddjob2 is offline
Old 02-02-15, 07:47 PM
PedalTraveler
PedalTraveler's Avatar
Bikes: 1958 Schwinn Deluxe Spitfire, 2016 Surly Cross Check, 1971 BH Folder, 2016 Felt DD10
I've always used bulk, Clarks, Jagwire, Shimano, and Sunlite. The Pre-lubed Jagwire is my favorite thus far. This latest build though I ordered this Road Pro | Jagwire fancy stuff. I'll report back if it's worth it.
PedalTraveler is offline
Old 02-02-15, 07:50 PM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 696 Post(s)
Liked 88 Times in 71 Posts
Similar to OJ, but not nearly as organized and tidy. Buying in bulk is all about economics and volume. You will save a lot of $$, but how much of this stuff do you use?
I always use stainless cables and lined housing.
wrk101 is online now
Old 02-02-15, 07:51 PM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Bikes: 1977 Trek TX700; 1978/79 Trek 736; 1984 Specialized Stumpjumper Sport; 1984 Schwinn Voyageur SP; 1985 Trek 620; 1985 Trek 720; 1986 Trek 400 Elance; 1987 Schwinn High Sierra; 1990 Miyata 1000LT
Quoted: 1789 Post(s)
Liked 101 Times in 82 Posts
I keep thinking I should buy shift cables and ends in bulk. As much swapping around as I like to do with shifters and derailleurs- you can only do that so many times before your cable crimps badly and starts fraying at the pinch bolt.
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Old 02-02-15, 08:22 PM
lostarchitect
incazzare.
lostarchitect's Avatar
Bikes: See sig
Quoted: 40 Post(s)
Liked 12 Times in 8 Posts
Unless it's a special bike (and sometimes even if it is) I just use basic black or white housing and cables from the LBS. I don't buy bulk, since I don't actively flip bikes.
edit: Chains, I just use your basic, cheap KMZ chains, and have never found a reason not to (again, unless it's somehow a special bike). Brake pads, I spend on Kool Stop, because they just work so well. Tires I default to Paselas unless I want something specific.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
lostarchitect is offline
daf1009
daf1009's Avatar
Bikes: LESS than I did a year ago!
Quoted: 67 Post(s)
So, where is the best place to buy bulk?
Also...how about chains?
72 Schwinn Super Sport, 80 Raleigh Super Course, 81 Miyata 1000, 85 Bianchi Veloce, 93 Tommasini Super Prestige, 05 Pinarello Surprise
daf1009 is offline
Old 02-02-15, 08:42 PM
juvela
juvela's Avatar
Quoted: 1725 Post(s)
Liked 78 Times in 70 Posts
aw shucks!
when i saw "consumables" immediately thought of alimentation.
oh well, this sort of consumable merits a bit of thought as well.
juvela is online now
Old 02-02-15, 09:58 PM
eschlwc
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 3 Times in 3 Posts
i'd like to know an ebay or similar source to buy bearings and stainless cables, not in great bulk, but $20ish worth.
i used to get bearings from loose screws, which went out of biz.
i buy the least expensive colored and lined housing off ebay whenever i'm building a bike. it's under $9 (shipped) for 7 ft.
hoods from vo or ebay and paselas from the lowest internet seller.
chains come from ebay too, either kmc or sram.
eschlwc is offline
Old 02-02-15, 10:47 PM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1381 Post(s)
Liked 88 Times in 59 Posts
Like Chombi above, I've gotten the clear-over-coil cable housing from Porkchop BMX. Their website usually has a better deal than their eBay sales, however. Most any other color can be had on eBay for $0.99/ft shipped. I've never felt the need to buy in bulk, with that kind of deal. My LBS sells a couple different colors at $1/ft, too.
● 1971 Grandis SL ● 1972 Lambert Grand Prix frankenbike ● 1972 Raleigh Super Course fixie ● 1973 Nishiki Semi-Pro ● 1980 Apollo "Legnano" ● 1981 Miyata 1000 ● 1984 Bianchi Limited ● 1984 Nishiki Landau ● 1984 Peugeot Vagabond ● 1985 Shogun Prairie Breaker ● 1986 Univega Nuovo Sport ● 1986 Merckx Super Corsa ● 1987 Schwinn Tempo ● 1988 Schwinn Voyageur ● 1989 Trek 400 ● 1989 Bottechia Team ADR replica ● 1990 Cannondale ST600 ● 1993 Technium RT600 ● 1996 Kona Lava Dome ●
Lascauxcaveman is offline
Old 02-03-15, 06:03 AM
miamijim
miamijim's Avatar
Quoted: 327 Post(s)
Liked 8 Times in 7 Posts
Stainless inner wires with lined housing.
I buy housing in bulk but not always the inner wires because I tend to reuse them, rear wires become fronts and I get SS inner wires on the cheap localy.
miamijim is offline
Old 02-03-15, 06:47 AM
eschlwc
Quoted: 59 Post(s)
it seems ridiculous to order individual cables from the far east (hong kong), but i just did it. just too damn cheap to pass up on ebay.
you can blame me for global warming. sorry.
eschlwc is offline
Old 02-03-15, 07:05 AM
auchencrow
auchencrow's Avatar
Quoted: 13 Post(s)
I'm a believer in better quality consumables except when it comes to chains and FWs - Cheapo KMC chains have proven to be exceedingly reliable and trouble free, but of course you can't replace a chain without replacing a FW, and that's the other place where, IME, the cheapest turns out to be equivalent to (or better than) the items costing 5x as much. That's why I usually stick with SunRace FWs.
- Auchen
auchencrow is offline
Old 02-03-15, 05:40 PM
CliffordK
CliffordK's Avatar
Quoted: 9201 Post(s)
Liked 207 Times in 160 Posts
I like to keep a few "consumables" in stock, especially things like brake and derailleur cables, so I don't run to the LBS every time I need one (and may have my bike hobbled). I changed to Stainless Steel recently as it seems a little slicker than the Galvanized, and hopefully less prone to corrosion.
Since I buy in advance, I can do direct Chinese orders for $1 to $2 per cable, or less. E-Bay is your friend. I still buy them several at a time.
I used to put a little ball of solder on the cable ends. :However, the last time I tried with Stainless, I had a lot of troubles getting the solder to stick. I noticed the new cables I was getting were welded, so I've now started tig welding my cable ends.
For years I've used unlined cable housings. I now bought some teflon lined cable housing, 25 ft rolls off of E-Bay for dirt cheap. We'll see how they last. I usually get 10 to 20 years out of my unlined cables, but have heard of people getting less than a year out of lined cables... pretty scary thought. If that is true, I'll look for something else.
Chains also from E-Bay, $10 to $11 each for HG-73 chains (Shimano 9S). I have some replaceable pins somewhere, but I got 2500 miles out of my last chain pushing the pin back in. I marked the pin on the new chain I just mounted... I think. Anyway, I coudn't find my pins so I just pushed it back in for another test.
I usually just re-use my bearings. However, I decided to try some E-Bay ceramic bearings in one hub. So far, so good... I think
I bought several tubes with my last Ribble order, $3.33 each, although I will frequently pick up some at a LBS or dept store (assuming they have them in stock, it isn't uncommon for narrow 700c tubes to be out of stock).
I did pick up some extra tires for my projects, but I don't really want to buy them too far in advance as I don't want the rubber drying out.
I've got some import bar tape on the way. I don't know what to expect. I may end up buying some Fizik 3mm tape sometime soon. A little more expensive, but hopefully good stuff.
CliffordK is online now
Old 02-03-15, 05:55 PM
Dfrost
Dfrost's Avatar
Quoted: 280 Post(s)
Loose Screws is back in business, but only a few bearings. Hopefully the new owner will eventually be able to rebuild the inventory of small parts stock that Jeff had.
Loose Screws Bicycle Small Parts Hard to find bicycle parts, made easy! For both the classic and modern cyclist.
Dfrost is offline
Old 02-03-15, 06:24 PM
eschlwc
Quoted: 59 Post(s)
^ thanks, david. i didn't know they were still up.
i scanned his site. he still has a lot of really hard to find items. hopefully, he'll continue to add stuff i actually use, like bearings.
eschlwc is offline
Old 02-03-15, 06:30 PM
oddjob2
Still learning
oddjob2's Avatar
Bikes: Too many
Quoted: 824 Post(s)
Ball Bearings
1/4 : Bearing Ball Store, Wholesale Bearing Balls
oddjob2 is offline
Old 02-03-15, 06:33 PM
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 357 Post(s)
Liked 402 Times in 263 Posts
What do you use for
cables: Novara Teflon from REI-if I only need the cable
housing: Jagwire or Campagnolo, especially if I need the kit
tips and crimps: good question, I ran out a short time ago, use whatever I can find, scavenging between minor refills of the jar
galvinized vs stainless vs teflon coated cable wires: 1-Teflon, 2-Stainless, 3-Not
Is housing a big deal? Yes. I go for performance when non-friction, appearance on friction.
Do you need the fancy jagwire stuff "need" is a strong word, but yes, my ego dictates the big kid stuff
or will the lower end stuff do just fine? not if I'm going to ride it a lot and it's not friction
Do you recommend this option or do you usually go on a pay as you need basis? As needed.
Bulk buying mandates that I make some choices before I've even bought the other stuff on impulse.
It also indicates that I have a "n+1" problem and am willing to admit it. I don't go there.
The worst thing for this is pegboard. I like hanging stuff up just like the bike shops.
This, of course, leads people to think it's available, just like the bike shops.
Some of it is decoration, some to torture 1 or 2 specific visitors, and some just to act capable.
Robbie ♪♫♪...☻
I have unfinished business.
RobbieTunes is offline
Old 02-03-15, 06:42 PM
RobbieTunes
Half drunk? Finish!
Quoted: 357 Post(s)
It is, but they should drop some of the extra parts and put Tube Tops in those kits.
Robbie ♪♫♪...☻
Old 02-03-15, 09:44 PM
eschlwc
Quoted: 59 Post(s)
Originally Posted by oddjob2 View Post
wow! "world's largest ball bearing store"!
"kid's, would you rather we go see the world's largest ball bearing store or the great ball of twine?"
thanks for the link! i'm gonna need some more bikes to overhaul now...
eschlwc is offline
Old 02-03-15, 10:16 PM
repechage
Quoted: 995 Post(s)
Liked 53 Times in 43 Posts
Reasonable and impressive.
repechage is offline
Old 02-03-15, 10:48 PM
zazenzach
zazenzach's Avatar
Quoted: 16 Post(s)
100 ft Roll Teflon Lined Brake Cable Housing Many Color | eBay
stuff like this gives me pause. i almost want to buy it, just to see its quality. but the other side is telling me I might as well flush money down the toilet.
Very, very impressive. I am currently building up my garage workspace. would be awesome to have somthing like this.
Old 02-04-15, 10:29 AM
Pars
Pars's Avatar
Bikes: '73 Raleigh RRA, 1986 Trek 500 commuter
Quoted: 33 Post(s)
That place linked looks good.
I've used vxb for bearings, and have been satisfied. The site is a bit harder to navigate than the previous link, but they also carry G10 balls, which I think are closer to what Campy actually used than the G25 are.
Pars is offline
