How do you deal with road/lube gunk build up on C&V bikes?
Old 03-05-15, 01:14 PM
willydstyle
Quoted: 146 Post(s)
I'm in the process of bringing a new-to-me '79 Fuji America up to speed, and while I just straight-up replaced the chain due to extreme wear, I want to salvage the freewheel and clean up the chainrings. My problem is that they have built-up sticky, black gunk. I've tried cleaning them with soapy water, WD-40, scrubbing with a brass brush, but this gunk is just really tenacious.
Any tips on how to deal with it?
willydstyle is offline
Old 03-05-15, 01:23 PM
icepick_trotsky
Aspiring curmudgeon
icepick_trotsky's Avatar
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 103 Post(s)
It's a good idea to replace your freewheel anytime you replace your chain. For the chainrings, try some degreaser like Simple Green.
"Party on comrades" -- Lenin, probably
icepick_trotsky is offline
Old 03-05-15, 01:27 PM
bikemig
bikemig's Avatar
Quoted: 3881 Post(s)
Liked 213 Times in 176 Posts
Not exactly. There is no need to replace the freewheel if the chain has been replaced before it becomes too worn. If you run the chain for too long, the freewheel becomes worn and a new chain is likely to skip.
I'd replace the chain and clean off the freewheel. The cogs can be spun off using freewheel chain whips. The body of the freewheel will need some lube; I like phil wood tenacious oil. If the new chain doesn't skip on your freewheel, you're good to go. Otherwise replace as needed.
bikemig is online now
Old 03-05-15, 01:28 PM
willydstyle
Quoted: 146 Post(s)
Sweet, my partner has a huge jug of simple green, I'll give it a go. I remember it leaving a residue, should I rinse with soapy water -> water afterwards?
Old 03-05-15, 01:32 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 607 Post(s)
Liked 39 Times in 37 Posts
Always use mechanical methods first when dealing with hardened and thicker layers of detritus.
I use a 6" metal rule for instance, applied to the rotating cogs, to strip out all of the crud.
A screwdriver tip similarly easily strips crud off of the rotating pullies.
The edge of a shop rag, pulled tight like a string, can be slid back-and-forth between cogs, forcing the freewheel to ratchet backwards in full circles for thorough cleaning.
A light spritz of WD40 on the rag edge area will provide needed dissolving power for a more scrubbed look if that's important.
I only use a solvent-diluted lube on my chain, so after a thorough post-application wipe-down, there is almost nothing visible to attract dirt and transfer oil to the rim, spokes, etc.
Best to apply the lube and do the thorough wipe-down after riding, so the solvent has time to dry, then the minimal remaining lube won't creep out and fly off.
A second wiping down of the chain is good after the first ride, if much lube has been squeezed out of the chain links from riding.
So I always spare the use of cleaners. I use a dampened terrycloth shop rag to do the remaining cleanup of the rest of the bike, starting at the bars and doing the dirtier drivetrain-are cleaning last, so as not to spread greasy dirt in the wrong direction.
You can't wipe too much lube off of a chain, and no lube should ever be applied to the sprockets.
dddd is offline
Old 03-05-15, 01:43 PM
noglider
noglider's Avatar
Quoted: 5677 Post(s)
Liked 248 Times in 175 Posts
If it is very tenacious grime, you may want to use Krud Kutter or something similar. I've heard brake cleaner (for cars) does a good job, too. For the not-as-bad stuff, I use furniture polish.
noglider is offline
Old 03-05-15, 01:59 PM
likebike23
Rides Majestic
Bikes: 1983 Univega Gran Turismo, 1970 Schwinn Super Sport, 2001 Univega Modo Vincere, Self-Built Nashbar Touring, 1974 Peugeot U08, 1974 Atala Grand Prix, 1986 Ross Mt. Hood, 80's Maruishi MT-18
I've had good luck getting tenacious old grease off with PB blaster. To get between cogs I've used a piece of cardboard box followed by a folded over rag soaked in PB.
likebike23 is offline
Old 03-05-15, 02:03 PM
randyjawa
randyjawa's Avatar
Bikes: 1958 Rabeneick 120D, 1968 Legnano Gran Premio, Rocky Mountain Cardiac
Quoted: 649 Post(s)
Liked 100 Times in 80 Posts
I use a narrow scraper to scrape off most of the bulk gunk, between the cogs, right down to the hub of the freewheel. I then use a stainless steel wire brush and a gloved hand to hold the freewheel pressed to a wood surface (any non hard surface will do).
Vigorously steel brush the FW until it looks pretty good. Spray lightly with WD40, brush again, and repeat until it is clean as can you can get it. Results are pretty darn good, if you take the time to do a good job. That said...
Sometimes the cosmetics and tooth fit are shot. Then you replace what ever, as required.
"98% of the bikes I buy are projects". Learn how to find, restore and maintain vintage road bicycles at... MY "TEN SPEEDS"
randyjawa is offline
Old 03-05-15, 02:20 PM
mechanicmatt
Hoards Thumbshifters
mechanicmatt's Avatar
Bikes: '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '07 Stumpjumper
Quoted: 42 Post(s)
Liked 22 Times in 15 Posts
superlube cleans crude pretty well
mechanicmatt is offline
Old 03-05-15, 02:21 PM
CycleryNorth81
Quoted: 155 Post(s)
Liked 14 Times in 11 Posts
Use carburetor cleaner to dissolve the gunk on your freewheel.
Replace current freewheel with a Sunrace freewheel if current freewheel is worn.
CycleryNorth81 is offline
Old 03-05-15, 02:43 PM
poprad
poprad's Avatar
Bikes: 07 Vanilla, 98 IRD road frame built up with 25th Ann DA, Surly cross check with 105 comp, 78 Raleigh Comp GS, 85 Centurionelli
Quoted: 11 Post(s)
Liked 3 Times in 3 Posts
I might mention the use of heat, like a hairdryer or similar, prior to application of solvents and scrubbing. Heat does a great job softening up the gunk before you scrape it. I like a thick ziptie cut square instead of metal tools for scraping, if it's a nice freewheel or if you're not sure if it might just be aluminum (not unheard of but rare).
poprad is offline
Old 03-05-15, 04:00 PM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Location: Ascending or Descending the NH Mountains NW of Concord!
Bikes: Snazzy* Schwinns, Classy Cannondales, & a Lonely '83 Santana Tandem (* Ed.)
Quoted: 483 Post(s)
Liked 42 Times in 27 Posts
If your freewheel is worth saving, oil on the inside is only a temporary solution. It really should be taken apart, completely cleaned, and then use grease.
This Regina CX looked like this on the outside.
The inside did not look much better. But after cleaning and proper grease, it looked like this.
Unfortunately I couldn't do anything more to restore the finish on the cogs. Corrosion had eaten that off long before it came into my hands.
Bob
Dreaming about riding in NH's summertime!
Visit my websites:
FreeWheelSpa.com orpastorbobnlnh.com
pastorbobnlnh is offline
Old 03-05-15, 04:30 PM
dddd
dddd's Avatar
Quoted: 607 Post(s)
This Regina CX looked like this on the outside...
...Unfortunately I couldn't do anything more to restore the finish on the cogs. Corrosion had eaten that off long before it came into my hands.
With corrosion like that, how fortunate that the insides weren't rust-pitted.
Looks like a good vinegar soak took place...
Oil applied from the outside is indeed temporary, but I've never had to apply it more than once every two years or so.
Conditions here are normally dry however.
dddd is offline
Old 03-05-15, 04:41 PM
auchencrow
auchencrow's Avatar
Quoted: 13 Post(s)
I use a Park Tool toothbrush and WD40 to clean FW's - though only if it's a primo item that really looks salvageable.
Even then, most are deep-sixed, because with a new chain, they end up skipping under load anyway.
(YMMV if you're not a masher).
- Auchen
auchencrow is offline
Old 03-05-15, 04:52 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '18 class built steel roadbike, '19 Fairlight Secan, '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara Trionfo, '18 Diamondback Syncr
Quoted: 3268 Post(s)
Liked 328 Times in 225 Posts
I use simple green HD, which is actually purple, as the initial grease and crud remover. soaking all the components in that stuff for a couple hours and then scrubbing with a nylon bristle brush gets most everything off. And what isn't removed can then soak for another hour or two before coming off easily.
rinse it with water and scrub towel everything dry.
That typically gets rid of everything visible, but I have also then soaked rusted parts in Evaporust for 2-5 hours and rinsed with water.
to get between the cogs of a freewheel, after it has been cleaned with the above process I then spray some wd40 and spin the wheel while holding the edge of a towel between the cogs. the edge fits right in between and the spinning plus wd40 gets the towel edges dirty pretty fast with any remaining dirt/grime/grease.
Freewheels come out looking pretty new after this. Mostly because I am convinced I get most of my bikes from people who rode them thru dirt and mud 20-30 years ago for a few hundred miles and then left em to rot. The years have made cleaning a chore, but the components are often flawless once clean.
mstateglfr is offline
Old 03-05-15, 05:11 PM
lostarchitect
incazzare.
lostarchitect's Avatar
Bikes: See sig
Quoted: 40 Post(s)
Liked 12 Times in 8 Posts
This works, but it destroys paint and rubber--so be very careful.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
lostarchitect is offline
Old 03-05-15, 06:23 PM
old's'cool
curmudgineer
old's'cool's Avatar
Bikes: 2 many 2 fit here
Quoted: 202 Post(s)
Liked 10 Times in 7 Posts
I can usually get things pretty clean with straight kerosene (the basis of WD40) and a toothbrush. I can buy kerosene in bulk at my local gas station, so it is quite cheap for me.
Carb cleaner, or Berryman's solvent, that you can get in auto parts stores, takes cleaning to the next level, but be sure to use as directed.
Cleaning a freewheel is much more efficient and effective if you dismantle it first, as illustrated by Bob. And scraping the heavy crud first will save time, effort, and cleaning media in the long run, as mentioned by dddd.
Geoff
"There is no Fail without Try" - Yoda Simpson
old's'cool is offline
Old 03-05-15, 06:30 PM
dddd
dddd's Avatar
Quoted: 607 Post(s)
Not to mention the toluene fumes are horrendous.
Carb cleaner is designed specifically to dissolve gasoline varnish, but as a bike parts cleaner for really tough grime I find that Finish-Line Citrus Degreaser works even better.
This is a petro product that contains no water, and works best using a tiny amount that's allowed to sit for a couple of minutes. It's fairly smelly but nothing near as bad as carb cleaner, and very effective on sprocket grime. I wouldn't soak plastic or rubber in it for long.
A drop or two of this stuff on a toothbrush will usually do one flange of a grungy hub in a built wheel, which I follow up with a spritz of rubbing alcohol on the same brush. It's an easy way to clean at the spoke attachment crevices, gets the job done yet uses nearly no cleaning product at all.
dddd is offline
Old 03-05-15, 06:47 PM
Antieverything
I never let them build up grime. I spray it, scrub it, rinse it, every time I ride in the rain or every few rides if it's been dry. Simple green and the garden hose outside, dry in front of a fan inside, air blow water out of hidden areas, then rubbing alcohol the stubborn stuff, a pledge wipe down to shine it up, then lube the chain and all necessary items. Even the beater gets the same treatment.
Antieverything is offline
Old 03-05-15, 06:52 PM
willydstyle
Quoted: 146 Post(s)
what's the easiest way to apply cleaner to the chainring without getting it on the chain without breaking the chain?
Old 03-05-15, 07:53 PM
Antieverything
What cleaners are you referring to? basically if it ain't strong enough to damage the paint it won't be strong enough to hurt the chain. Anytime you ride in the wet or get the chain wet when cleaning you should let it dry then relube. Most people clean the chain with wd40 and at the same time use a rag/toothbrush to scrub the cassette and chainrings at the same time.
Old 03-05-15, 08:16 PM
Velognome
Get off my lawn!
Velognome's Avatar
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 69 Post(s)
Liked 8 Times in 5 Posts
Gunk engine cleaner ( safe for paint and plastic),\; spray it on, let is soak, wash it off. Then lube the chain and you're ready to go. If it's really grimey, an old tooth brush works wonders.
Velognome is offline
Old 03-05-15, 08:40 PM
radeln
There is an air freshener called Pure Citrus that is made of orange oil. It cuts through old oil and grease very well, not too toxic, and smells nice. X-marts and places like Home Depot should have it. I haven't tested it for paint safety.
radeln is offline
Old 03-05-15, 08:45 PM
Dave Cutter
Dave Cutter's Avatar
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1569 Post(s)
+1
Dave Cutter is offline
Old 03-05-15, 08:50 PM
Reynolds
Passista
Reynolds's Avatar
Quoted: 485 Post(s)
Liked 50 Times in 39 Posts
Just leave it alone and call it patina.
Reynolds is offline
