BF Samsonite
BF Samsonite
Old 03-01-18, 12:30 AM
gdlerner
Bikes: Pocket Llama
Quoted: 27 Post(s)
BF Samsonite
Hi
Is this suitcase now what BF use? Because on BF web say 29,5" I search and there only 31"
Thank you
https://www.amazon.com/gp/aw/d/B005SLEDAE/ref=mp_s_a_1_2?ie=UTF8&qid=1519885577&sr=8-2&pi=AC_SX236_SY340_FMwebp_QL65&keywords=samsonite+f%27lite+gt+31"+spinner&dpPl=1&dpID=41rcEQEhdaL&r ef=plSrch
The
gdlerner is offline
Old 03-01-18, 09:23 AM
Pinigis
Pinigis's Avatar
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 194 Post(s)
Liked 19 Times in 14 Posts
From the BF website: "Samsonite does not measure the wheels or handles in their measurements.The case dimensions are 29.5" tall x 20" wide x 12" deep. This adds up to 61.5 linear inches, which falls just under the 62 linear inches used by most airlines as their cut-off limit for suitcase dimensions. The suitcase weighs 11.65 lbs. + "
The only problem that I see here is that the airlines DO measure the wheels and handles when determining the size of checked luggage (I contacted numerous airlines to confirm this), so the case is actually 31" (as shown on the Samsonite web site, they don't refer to it as 30") and the case is identified as:
Body Dimensions: 31.0" x 21.0" x 12.0"
Overall Dimensions: 32.67" x 23.48" x 13.77"
So, best case, its 65" linear inches, worst case 69.92". You may never actually get caught and have to pay the fee, but it is a risk.
Paul Pinigis
Owner of Origami Bicycle Company
Pinigis is offline
Old 03-01-18, 11:42 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 7388 Post(s)
Liked 1,002 Times in 631 Posts
I left mine at the bike shop , where I get parcels left, rather than street side, on my porch.. I can measure it later...
My Friend frugal to a fault , gets softsided luggage at charity shops , then he can abandon them after taking his Bike Friday, Out.
fietsbob is offline
Old 03-01-18, 12:10 PM
bargainguy
bargainguy's Avatar
Quoted: 374 Post(s)
Liked 64 Times in 42 Posts
I have one of the technically oversize F'lite suitcases, but I have yet to be charged for oversize from the airlines.
It's easy and quick for the airline agent to plop your loaded suitcase on the scale. I've had this done every time I've flown with the F'lite and my Bike Friday. So I make sure the total weight doesn't exceed the 50 lb. international weight limit. If it does, you can bet that the agent will whip out the tape measure and check for oversize as well as overweight. I've never had the agent check for oversize if the case doesn't exceed the 50 lb. weight limit, tho, because it's close enough to the 62" total dimension to not look obviously oversize.
If the airline counter is crowded, the agents are much less likely to check for oversize as long as the case doesn't exceed the 50 lb. weight limit. There have been times I've gotten to the airport early and actually waited for the airline counter to get crowded before I approach.
bargainguy is offline
Old 03-01-18, 12:31 PM
gdlerner
Bikes: Pocket Llama
Quoted: 27 Post(s)
Guys I just want to know if this one in amazon link is the same suitcase BF sell,I already got a suitcase and I want to replace it
Thank you
gdlerner is offline
Old 03-01-18, 01:55 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
order it take a risk.. send it back if it baint adequate..
Amazon will not answer your question? no one on here works there,
and bezos just wants the profits , from all the minimum wage order fulfillers just running their little butts off..
fietsbob is offline
Old 03-01-18, 03:49 PM
rhenning
Quoted: 315 Post(s)
Liked 44 Times in 31 Posts
GDLerner over time BF has changed the suitcase model they use. BF has an 800 number call them or E-mail them and ask what model case they are using right now. They should know. My wife and I have 2 BFs and both cases are different and both are Samsonites. My Pocket Rocket is is older than her Pocket Crusoe. Roger
rhenning is offline
spacemaniss
Tandem Cycling
4
04-20-20 11:41 AM
kayakindude
Folding Bikes
15
07-20-19 08:55 AM
cyclezealot
General Cycling Discussion
5
04-03-13 10:53 AM
staehpj1
Touring
10
04-01-10 02:09 PM
