Spine health and heavy lifting
Quoted: 18883 Post(s)
Liked 10,646 Times
There are a lot of mistakes you’ll see other people making in the weight room. A lot of people round their backs excessively when they squat. Or go too deep on the leg press, and then round their backs at the bottom to get the weight up, which is basically the same thing. Or dead lift with the weight too far forward.
I’d like to understand how much “wiggle room” you have before doing permanent damage. I’ve tried asking Google, but I’m mostly finding poor quality results.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
It's probably too hard to quantify to say. Rounded-back exercises can be safe as long as you work up to a particular weight gradually and carefully. The lower back is expected to round a little in exercises like the straight-leg deadlift: https://www.exrx.net/WeightExercises...ghtLegDeadlift
Quoted: 5767 Post(s)
Liked 2,540 Times
Plenty of wiggle room, but the devil is in the details. Prior condition, supportive muscle condition, weight involved, frequency, smoothness of the lift, etc.
If they don't have pain, and don't do it all day every day, odds are they're OK for now.
FB
Chain-L site
FB
Chain-L site
Quoted: 4227 Post(s)
Liked 2,488 Times
When it comes to squats, deadlifts, standing overhead pressing or any exercise which involves picking the weight from off the ground , you don't have a lot of wiggle room and you need to make sure that your technique is correct. It's better to use less weight with perfect technique than it is to use more weight with bad technique. low back injuries are not fun.
Shoulder injuries, elbow injuries, knee injuries and other injuries usually heal fast and you can go back to lifting, but when your lower back gets injured your lifting days and training days can be all over...One very famous martial artist Bruce Less sustained a very serious back injury from doing barbell good mornings. His back never healed, he had to take pain killers and it had a negative effect on him for the rest of his life.
I guess I don't give myself a lot of wiggle room. If I feel I'm losing form, I'll stop and take notes the next time to use lower weights but for the same volume (weight x number of reps). Yes, I take a calculator to the gym.
As for the leg press, I try to mimic the squat so I go low, legs spread out, toes pointed out. There's a back rest to push against but I don't feel any pressure against my lower back. Maybe I should put something to support my lower lumbar curve.
Liked 10,646 Times
I've got perfect squat form, I video myself doing them regularly and check. Maybe that lulled me into a false sense of security.
I do one-leg leg presses. A set with the right leg, then a set with the left. Here's what the Stronglifts guy has to say about leg presses:
And of course that's exactly what I've been doing, trying to get the full range of motion.
My lower back has been sore, which is new to me. I know lots of people have back pain from cycling, I've never experienced it before, until now.
The Leg Press is a machine where you push weight away with your feet. Some Leg Press machines are 45° incline, others are horizontal. But they’re never substitutes for Squats. The weight moves, you don’t. You don’t balance the weight, the machine does. Go too deep and your lower back will round at the bottom and squeeze your spinal discs. Unless you have no arms to hold the bar on your back, stick with free weight Squats.
This is the closest thing I could find in Google.
https://www.poweringathletics.com/productpress/
And just to clarify, I do squats and deadlifts. This machine is supplemental to go beyond my target I want to squat.
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
I think it's always possible to screw it up. We have a ~65 y.o. ex-gym owner we see at the gym. He's big and has been working out all his life, has good form, etc. He popped a disc doing heavy deadlifts many years ago. His advice: don't do heavy lifts. Just don't. Sooner or later, you'll make a mistake and regret it the rest of your life. It's not worth it.
My research says that the exact weight doesn't matter, only the exhaustion. You can get about the same result from sets of 20 as sets of 5, as long as you take both to failure. But 20 is safer. That is unless you're competing, in which case you have to do what you have to do regardless of risk.
It's notable that studies of progress using 1 minute rests vs. 5 minute rests between sets found that the 5 minute people were able to use more weight, but also had more injuries. I use 1 minute rests.
Results matter
Results matter
Liked 1,938 Times
I've started doing high rep kettlebell swings for hams and lower back. Never did them before, but they're a great way to increase strength and conditioning at, AFAIK, no injury risk. I'm doing sets of 25 and hope to go up in reps from there. Glutes, back, and hams say OW, so I guess they work.
I had to quit doing one-legged presses because I damaged something in one of my feet, maybe because it's not a natural stance, like squatting. Plus I was only going down to 90° (not rounding my back), plus only doing 6 reps. It's OK now but I still feel it a little sometimes. We hope we're always learning before it's too late.
Results matter
Results matter
Quoted: 1027 Post(s)
Liked 325 Times
A slight bend is fine. The problems really happen when your back gets rounded to the extremes of its range of motion.
Having said that, there is no reason not to aim for perfection and keeping a good arch in your back. You're training health and cycling performance right? Not to set records in the gym. So form and safety should take priority over lifting numbers.
Liked 325 Times
Same thing with barbell squats, known as butt wink. Don't go that low.
In general, high reps can be fairly risky due to the large amounts of fatigue involved near the end of the set. Also, it's far easier for one's concentration to lapse over a 20 rep set than over a 5 rep set.
One other thing to consider: while a 20 rep set may have the same potential for hypertrophy as a heavy 5 rep set, it's far easier to do multiple heavy sets of 5 than multiple sets of 20 with a lighter weight. There's a reason sets of 20 squats are called "widow maker". If you're doing them heavy enough, your day is pretty much done after one of these. The cost/benefit just isn't there in most cases.
Liked 10,646 Times
I inherited good genes for not having diabetes, and for wanting to exercise, but also more than my share of anxiety.
So, when my lower back started bothering me on the bike, and it seems to be coming from the spine, my instinct is to get worried. Have I already ****ed myself up?
I should probably go see the doctor, but most of them aren't much help if you're not looking for pills.
Liked 1,938 Times
That's what I'm afraid of.
When my back hurts from working out, I rest it until it doesn't. OTOH I don't have any "damage", just wear. I think if the pain doesn't shoot down your butt or hams, you're good, just rest. Skiing shouldn't bother it, counts as rest. Check this out:
https://trainright.com/fix-lower-bac...-ultrarunners/
Results matter
Results matter
Liked 1,938 Times
I would be careful with KB swings. You're generating a lot of force when you decelerate these which, coupled with fatigue from doing high reps, could make it easy for your form to break down. Not saying don't do them, or that they are a bad idea, but don't think there is no injury risk either.
Results matter
Results matter
Liked 2,540 Times
If your back is normally OK, and the problem creeps up slowly as you ride, it's likely not a serious problem, but more like the result of strain. If it ONLY bothers you after a longish time riding, it's likely bike related, and IME the most likely cause is a saddle slightly high, causing your hips to rock with each pedal stroke. Or it may be muscle strain from the reaction force needed to stabilize the back as you pedal.
There are other possibilities, but as long as it's otherwise OK, I'd tinker with riding position and pedaling style and see if you can solve this yourself.
BTW- if you're past middle age, consider the possibility of sciatica which can have multiple underlying causes. A common sciatica related issue for cyclists is piriformis syndrome, which can manifest in all sorts of ways, leading folks to suspect problems in other places. Piriformis syndrome is fairly easy to confirm with a simple stretch, and can usually be managed by regular stretching of the muscle.
FB
Chain-L site
FB
Chain-L site
Liked 10,646 Times
Last Saturday, skiing (cross country) hurt after about an hour and a half. After a little more than two hours I wanted to do another lap but my back hurt too much. Standing on it hurt, and double poling hurt. A month ago, I skied from Mazama to Winthrop in four hours and felt good at the end.
But it seems to be improving.
When it bothers me, it's an achy kind of hurt that comes on slowly.
I turned 40 in December.
BloomBikeShop.com
Liked 2,488 Times
Don't worry about it. Just use lighter weight for the next few workouts and take it easy, maybe it's time to deload.
Do you remember which exercise it was that aggravated your back ??...If you know which exercise it was, than stop doing it for a while and find an alternative. The beauty of weightlifting is that there are so many different exercises to choose from, if one causes pain, you have an option to choose another.
Liked 2,488 Times
KB swings are fine for high reps, as long your technique is spot on, every rep from the first to the last should be the same. It takes practice to be able to hip-hinge the bell for high reps. I usually use 53-60 pound bell and do 100 reps total for KB swings. I use few different set/rep ranges to achieve those 100 reps total...10 sets of 10 reps... or 5 sets of 20 reps... or 4 sets of 25 reps and I make absolutely sure that the last rep is the same as the first.
Quoted: 7346 Post(s)
Liked 2,452 Times
I get such great advice here from you folks, especially @Carbonfiberboy. Thank you all.
And I get affirmation on the techniques I have developed recently from my intuition. I had neglected my upper body and never lifted with my back, even light weights. I always used my legs. So I had terrific legs and was a weakling from the waist up. I needed physical therapy to get some mobility after an injury, and now I do deadlifts and similar things. I usually use a 60-lb barbell. I'll look into getting a kettlebell now.
Liked 2,563 Times
Leg presses are for legs. If you want to exercise your spinal erectors, do weighted hypers.
Liked 325 Times
Liked 2,452 Times
I just looked up weighted hypers on youtube. Wow.
Liked 10,646 Times
Still hurts. Haven't been to the gym in 2 or 3 weeks. It's probably time to see the doctor.
Liked 10,646 Times
Doctor says muscle strain, no skeletal damage. Predicts complete recovery. Based on symptoms and mobility, we didn't do an MRI.
