New favorite gadget, Garage Door Opener
Beer & Bikes
Bikes: '20 Specialized Roubaix Expert, '20 Specialized Shiv Elite, '13 Specialized S-Works Epic
Quoted: 38 Post(s)
Liked 80 Times
Bought it the moment I saw it. QoL, improved.
Liked 2,981 Times
vid unavailable.
-Oh Hey!
-Oh Hey!
Quoted: 3462 Post(s)
Liked 1,468 Times
Is that different than the one described here?
https://www.bikeforums.net/electroni...seriously.html
Quoted: 222 Post(s)
Liked 304 Times
Maybe I got a bad unit, bad battery. I don't care, uses an odd size battery, requires unwrapping the bars to replace the battery. Just not worth the hassle to me.
I see they now have a DoorMate 2 that uses a standard 2032 coin battery and can clamp to your bars, or even replace your stem cap. I would have bought this had it been available. Probably won't buy one because it is only a very minor convenience for me.
Super Modest
Quoted: 10965 Post(s)
Liked 4,621 Times
No problem with mine, so far. Fingers crossed.
Keep the chain tight!
Super Modest
Liked 4,621 Times
Left home yesterday and remote is dead. I have a spare battery but if it dies in 4-6 weeks, I’ll give up on it.
Quoted: 222 Post(s)
Liked 304 Times
I just found the whole thing a bit of a hassle. I had assumed it fit in like a bar plug. Having to wrap over it and subsequently unwrap the bars to replace a battery is a bridge too far for me. I wish the stem cap version had come out before I bought mine. I'd have gone with that. Looks to be much more convenient and takes standard coin batteries.
Please post how it goes with your battery replacement. At this point, I don't plan to bother buying a new battery and even trying it again.
Liked 2,981 Times
Could be they got some bad/heap batteries they shipped with the units. Big mistake to cut corners that way, if they did. No excuse for a garage door opener not lasting years between battery changes. I have garage remotes years old that have never needed a new battery.
-Oh Hey!
-Oh Hey!
I just wrapped a piece of foam tape around mine and shoved it in like a bar plug. I haven't lost it yet.
Quoted: 242 Post(s)
Liked 456 Times
I roll up to my garage and type in the code...voila my door opens...amazing...and I don't have to carry something or mount something on my bike...it's a garage, not the bat cave and I'm not in that much of a hurry.
Likes For Kai Winters:
Liked 1,468 Times
Yesterday the cheap $12 remote I have hanging from a D ring on my handlebar bag worked just fine. If I do not use my handlebar bag, I put the remote in a jersey pocket. Battery is at least two years old.
I did not have to push the buttons with my code.
Quoted: 242 Post(s)
Liked 456 Times
lol ...it's a two stall, one door, garage...the door is also insulated...i've had to lift it manually once...not going to try that again...
Liked 1,468 Times
If the door was initially installed where an electric opener was to be used, there might not be a handle on the door to grasp for lifting it.
Liked 1,468 Times
If a spring breaks, your motorized door mechanism will probably fail much faster, the motors are not designed to handle the full weight of a door.
Likes For Tourist in MSN:
Randomhead
Liked 3,701 Times
Our door is pretty heavy. I think when I replaced it, I might have kept the original springs. When one of them broke recently the old one looked really old. It turns out around here getting a spring replaced takes a couple of weeks and two visits from the door installers $$
Under normal circumstances, you can't lift our door manually from the outside because the release is well-hidden. I probably should take the old garage door opener down so the robbers don't screw up the door getting to the release that doesn't do anything.
Liked 5 Times
I had my garage lift motor replaced and new belts installed 2-3 years ago and it had a link to an APP to control the door. I can't remember the number of times I have left the house and get blocks or miles from home and couldn't remember if I had closed the door. Now all I have to do is look at the APP and it tells you if the garage door is open or closed. If it's open you can close it with the APP. If someone else opens or closes the garage door I will get a text stating the door has been opened and another text when it closes. Love it.
Likes For RLB2444:
Super Modest
Liked 4,621 Times
Btw, my bar end remote’s battery went dead after 6 weeks and it’s sitting on my bench waiting for me to buy a battery. I’m hoping the original battery was old or something because I’m not buying a new battery every 4-6 weeks.
With a mighty wind
Quoted: 1089 Post(s)
Liked 868 Times
Totally bummed. I got this for my Yuba. Programmed perfectly. It doesn’t fit inside the handlebar. The bar is quite a bit too narrow on the inside. It’s a Yuba, not a nicer bike, but I assumed the inside diameter of the bar would be the same. Now I’ve got to decide whether it’s going back or if I think I can ream enough of the inside out to make it fit.
Was actually pretty excited to have something that wasn’t a big deal to install. I didn’t want the one for the outside of the handlebar.
Quoted: 222 Post(s)
Liked 304 Times
Just saw this now. Thanks for reporting back. I was in a position to consider replacing a battery and trying mine again. You've made that decision easy. Not going to bother. The whole thing just makes no sense. Why can common, cheap battery operated garage door openers go years without needing a battery change, and this thing can only go 6 weeks.
