Problem greasing Speedplay Zero pedals
Old 04-16-10, 09:20 AM
chummdizzle
Bikes: Cervelo Soloist Team
I've been using Speedplay's for a while now and need to grease my pedals, which I have never done before.
I got one of those Finish Line grease guns and attempted to do it but ran in a problem. From what I understand the instructions say that as you pump in the grease and turn the pedal the old grease should be forced out of the spindle side of the pedal.
When I tried it it worked fine at first but instead of the grease coming out of th spindle side it actually pushed the black plastic insert, the area that the grease port screw goes in to, out of the pedal.
What am I doing wrong?
chummdizzle is offline
Old 04-16-10, 09:59 AM
bikeman715
bikeman715's Avatar
Bikes: Bike Nashbar AL-1 ,Raligh M50 , Schwinn Traveler , and others
Quoted: 85 Post(s)
don't force the grease gun, just hold it in the port and push the grease in and as the instructions said turning the pedal.
bikeman715 is offline
Old 04-16-10, 10:15 AM
chummdizzle
Ok I'll try to go slower and see how it goes.
On another note, does anyone know how much a replacement body for Zero pedals are?
Old 04-17-10, 02:58 AM
Torchy McFlux
Torchy McFlux's Avatar
Bikes: NOYB
I think a complete rebuild kit goes for around $100. That's a pair of bodies and a bunch of other parts though.
If you need just one body, check with your local Speedplay dealer. They might have one on its own in their service kit.
Torchy McFlux is offline
Old 04-17-10, 07:04 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Speedplay does charge high prices for their rebuild kits and requires you obtain them from a dealer. They won't sell repair parts directly to the user and have a minimum dealer order so many LBS's are reluctant to special order what you need unless they have a large enough order to make it worth while.
I found the cost for a body and bearing kit for my Frogs was high enough to warrant getting new complete pedals since the pedals come with new cleats that retail for over $30 by themselves.
HillRider is offline
theHomelessJedi
Bicycle Mechanics
13
05-14-17 10:12 AM
rollingsound514
Bicycle Mechanics
4
04-28-16 07:01 AM
koolerb
Bicycle Mechanics
5
10-23-13 08:58 PM
kitteh
Mountain Biking
5
03-30-11 01:01 PM
festero
Road Cycling
14
07-08-10 06:04 PM
