Why a 650B Conversion?
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
What is the attraction of converting a bike to 650B wheel size? If it started life as a 700c or 27" wheel bike then the conversion requires installing much longer reach brakes and the bottom bracket height is lowered by about .75" or a bit more unless the tire width fitted is greatly increased.
I can see possibly converting 26 x 1 1/4 (597mm BSD) and 26 x 1 3/8 E.A.3 (590 BSD) bikes to 650B for better tire selection and availability though I understand 650A tires are even more readily available.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
Liked 6 Times
...and what's wrong with lowering the bb? And don't bring up the old "pedal strike" argument: In 35 years of riding (including 15 years of USCF racing) I've caught pedals on the pavement maybe half a dozen times, the last one was um.... let's see.... 15-20 years ago. And that includes a lot of miles on a bike with a 10" bb height and 180mm cranks.
SP
Bend, OR
ps - going from a 700x23c to 650x38b (probably the most common conversion) will drop your bb 5 mm (< 1/4"), not 3/4".
SP
Bend, OR
I think the attraction is to mount fat tires to the bike. Brake arm reach is a low hurdle to overcome. A high hurdle (true limitation) is frame clearance.
I am researching and searching for a C&V or C&V-type frame that is both lightweight and can accomodate fat tires (2.5" wide). The objective is comfort. Wheel size is unimportant but 26" is probably my minimum. Right now, I have found almost no suitable frames.
Palmer
Quoted: 1670 Post(s)
Liked 1,825 Times
An ISO23x622 (700C x 23) and an ISO42x584 (650B x 42) are going to be pretty close in outside diameter, depending on how the tire fits on the rim & etc. One can run a lot chubbier tires without changing the geo., so there's your conversion, right there.
Additionally, an ISO38x622 (700C x 38) tire on a hybrid or city bike starts to be pretty large in outside diameter to use in a well-fitting, good-handing small frame size bike design.
IMO a standard, available size around about this dimension makes sense.
A charge card will get you any of these 26 x 1 3/8 tires either in your hands or on order today:
Bell Sports Streetster (folding)
Chengshin C638
Continental City Ride
Kenda gumwall
Kenda Cross (knobby)
Kenda K40 Street
Michelin World Tour
Nutrak Traditional
Nu-teck (airless)
Panaracer Col de Vie
Panaracer ST Daily Commuting
Pyramid gumwall
Pyramid Sunlite Hybrid Nimbus
Raleigh Record
Rubena Flash V66
Schwalbe Delta Cruiser
Schwalbe Marathon
Schwalbe Marathon Plus
Schwalbe Speedway Pro (knobby)
Specialized TriSport
Vredestein Perfect Tour
Funny thing about tire availability: Let's say you're a cycling retailer. Carry 27" tires, even though they're obsolete? Sure, because a 1 1/4 inch wide one is going to work on 99% of the bikes owned by crusty old guys who come in looking for a 27. Stock the old, obsolete 650A? Sure, because they're all 1 3/8 inches wide, so just pick one you make good margin on and it's going to work on 100% of the bikes that use this size. The inventory will turn. 700C? Sure, of course, industry standard and all, but what widths? 19, 23, 25, 28, 32, 35, 38, 42, 47, 54, or 62mm? Inventory nightmare! Then we come to the 650B: an rare tire diameter that additionally comes in 28 to 57mm widths. Stock a 44mm and the only guy in three months that wants one will want a 37mm!
tcs
Chengshin C638
Kenda gumwall
Kenda K40 Street
Michelin World Tour
Nutrak Traditional
Nu-teck (airless)
Pyramid gumwall
Raleigh Record
Rubena Flash V66
Schwalbe Marathon
tcs
Quoted: 3811 Post(s)
Liked 6,710 Times
One of my favorite 650B conversions was a '78 Raleigh Competition GS. I found the wider tires (Col de la vies on that one) took a somewhat harsh riding bike w/ racier geometry and really smoothed it out for both comfort and speed. Another project I'm hoping for a similar result is to convert a Vitus 979 alu frameset.
As in all things, ymmv.
Neal
Quoted: 7349 Post(s)
Liked 2,474 Times
Other than adding fenders or fat tire to your beloved tight-clearance road bike, I think the new 650B trend is a lot of hype. I can't remember where I read it, but there was an article about how 26" (559mm) wheels are too small and 700C wheels are too big, and 650B is just right, with a luscious yet still efficient ride. Give me a break. You can make changes a lot easily by changing tires.
Liked 6,710 Times
Tom, all I can say is, Try it, you'll like it!
Neal
Neal
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
Liked 2,474 Times
Neal, how would you describe the ride?
Liked 6,710 Times
Tom, definitely "luscious but still efficient." Actually, I have no idea what that means, but I find that my 650B rides in general have lots of cush and roll right over rough spots in the road, but the good quality tires means that they still feel fast-ish, so it's not like riding a balloon tire Schwinn.
Neal
Neal
Quoted: 443 Post(s)
Liked 27 Times
The only reason I haven't tried it is the expense of rims, spokes, tires and brakes. I'll bet that Rivendell has made a fortune on 650B conversions.
Neal
Neal
So are you saying that it is primarily the available tire quality that makes the difference between the feel of the ride on 650B vs 26" wheels? You would be happy, say, putting better quality tires on your balloon tire Schwinn, as opposed to doing a 650B conversion on it? Not arguing, just trying to understand.
Thanks,
Eric
Liked 6,710 Times
Hi Neal,
Thanks,
Eric
Thanks,
Eric
Then again, Matthew Grimm, creator of Kogswell, has declared he's done with 650B and is developing new frames designed for 559mm wheels, which he feels are *his* sweetspot!
Neal
This is the "problem", frames that are designed for the fat tires tend to be heavy, dead clunkers.
Frames that are light and lively tend to be designed only for skinny, skiny 700c tires. The sweet spot (for me) is a light weight, high quality rigid (non-suspended) mountain bike frame. The frame geometry is more relaxed and confortable. The fat, high pressure tires give all the "suspension" you'll need on a paved road. There's plenty of room for fenders. There's braze ons for racks, if you want them, too. The riding position is somewhat upright but forward enough to be energy efficient and fast. Light weight, aluminum rims, and powerful cantilevered brakes, triple crank up front, indexed shifting,... what's not to like?
That last question is not just rhetoric.
Liked 2,474 Times
I'm putting super narrow tires on someone's mountain bike today. I'll see how it feels.
Quoted: 443 Post(s)
Liked 27 Times
It will probably feel zippy compared to a mountain bike with fat knobby tires, but still slow and heavy compared to a decent road bike. That's why my MB-2 with skinny slicks is gathering dust and cobwebs in the rafters.
Gentlemen,
The two versions you mention are well outside "the sweet spot". I suspect you are well aware of this. ;-)
Super-narrow slicks on a mountain bike will ride as harshly as they do on a road bike. Fat, knobby tires on a road bike will be as rough, noisy and sluggish as they are on a mountain bike or beach cruiser when ridden on a paved surface. Those versions are outside the desired envelope.
What's being suggested is to use fat, high pressure slicks (or lightly treaded) tires on a zippy frame. Because most road frames will not accept fat enough tires, many have opted for smaller diameter wheels. What this does is move the point of maximum tire width (not tire height) to a smaller diameter, thereby gaining additional clearance from the frame.
What would be cool is to compile a list of bikes which are available set up this way. Another cool list would be of frames compatible with this set up.
Liked 6,710 Times
Lots of good stuff from Ed Braley, the guru of 650B conversions on "fast" bikes:
https://www.bikeman.com/content/view/1771/146/
https://650b.webs.com/conversions.htm
https://www.bikeman.com/component/opt...0B/Itemid,135/
Pics of Ed's fleet:
https://www.flickr.com/photos/25373440@N00/sets/
Neal
Pics of Ed's fleet:
Neal
Liked 2,474 Times
I have a Surly Cross Check which accepts extremely wide 700C tires. Are cyclo cross bikes that hard to find? I'm under the impression that the Cross Check is pretty close to a classic cyclo cross design.
perpetually frazzled
Bikes: 1977 Bridgestone Kabuki Super Speed; 1979 Raleigh Professional; 1983 Raleigh Rapide mixte; 1974 Peugeot UO-8; 1993 Univega Activa Trail; 1972 Raleigh Sports; 1967 Phillips; 1981 Schwinn World Tourist; 1976 Schwinn LeTour mixte; 1964 Western Flyer
Quoted: 5 Post(s)
Liked 6 Times
I'll say this about fatter tires and smaller wheels, then duck back out of the way. Currently, the two bikes I ride regularly are a 590 wearing Phillips 3 speed and a 630X28 Fuji Palisade. COmfort-wise, the Phillips beats the Fuji every day. The Col de la Vies that I have on it are like riding on pillows. Then again, I've got 40psi front, 55psi back, so they're pretty low pressure-wise. The Fuji with it's 100psi 28's (100 front, 110 back) ironically doesn't seem to roll as well, and it picks up road buzz more easily, but I feel that it corners much more effectively, and is much easier to control in dirt or other at-the-limit riding (God knows, with the 'rents living on a dirt road, I see that enough).
I would truly be interested to see differences and similarities between 584/590 and 622/630 on an identical bike.
Quoted: 5 Post(s)
Liked 6 Times
Got a World TOurist also that could probably take 35-38's...
ETA: Something else to consider...what would the weight be of a pair of 650b wheels and good tires (hetre, CdlV, etc) compared to 700c wheels and comparable tires? I know the 700X38's I was riding on the CX/hybrid nearly killed me after about 10 miles because they were so bloody heavy and resistance crazy. I could triple my distance at a given speed switching from 38's to 28's on the same bike with the same wheels.
