anti seize compound/grease
It do, but it don't.
i've got some new pedals on order and want to grease the threads before installing. what is the cheapest working option for getting some grease? can i go to an auto parts store and pick something up?
thanks!
thanks!
Quoted: 5792 Post(s)
Liked 2,583 Times
for assembly purposes (or even for ball bearings) any decent auto grease will be fine. You don't need anti-seize for pedal threads, but if you ride in very tough conditions, such as wet winters where they salt the roads or along the shore where you might ride through seawater puddles, then take out insurance by removing and replacing the pedals once a year.
FB
Chain-L site
FB
Chain-L site
Rides Majestic
Bikes: 1983 Univega Gran Turismo, 1970 Schwinn Super Sport, 2001 Univega Modo Vincere, Self-Built Nashbar Touring, 1974 Peugeot U08, 1974 Atala Grand Prix, 1986 Ross Mt. Hood, 80's Maruishi MT-18
Liked 7 Times
I use anti seize on my pedals, freewheel threads, and bottom bracket cups. I use the same stuff you use for spark plugs and what not. It's cheap enough if you buy the little tube, it lasts forever, and you can use it on your car also.
Quoted: 2026 Post(s)
Liked 1,096 Times
Indeed, anti-seize is a very effective thread lube/protectant/corrosion preventative. However, it's overkill for almost all bike use and very messy to use. A small tube is cheap enough and does last for years but keep it off your clothes.
I just use anti-sieze for like spoke threads , in the whelbuilding
mostly just Grease, Boat trailer wheel bearing is for hubs, headsets..
lighter stuff, Phil or Park to push thru the needle tip grease gun,
Rides Majestic
Liked 7 Times
Probably overkill for most bikes applications, but I especially like it on my mountain bikes, they get really wet every time I ride. It is also very messy. I just put a dab on a few places with the end of the tube as the applicator. The rotation of the parts during install spreads it evenly.
bazap
Bicycle Mechanics
20
06-21-17 02:40 PM
rollingsound514
Bicycle Mechanics
4
04-28-16 07:01 AM
