Rock N Roll Gold Chain Lube
I have read good things about Rock N Roll Gold chain lube following my LBS recommending it and using it in their shop. Looking for comments on it from people who have used it.
I am not looking for recommendations on other chain lube products, as that opens the same rat hole that this forum has dived into many times already. Thanks.
Quoted: 6973 Post(s)
Liked 10,975 Times
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
RnR Gold works fine. Used to use it but am now using RnR's "Holy Cow" instead (if your LBS also stocks this).
Quoted: 10238 Post(s)
Liked 5,188 Times
Likes For bampilot06:
Quoted: 3241 Post(s)
Liked 2,512 Times
Quoted: 680 Post(s)
Liked 949 Times
I wanted to use it in winter but it says apply when warm what is warm? 50 degrees 60? it did not seem to ast in the rain much better. I like rock and roll as I don't have to clean the chain.
Should Be More Popular
Quoted: 22608 Post(s)
Liked 8,929 Times
Quoted: 18424 Post(s)
Liked 15,582 Times
I didn't like it. Needed more frequent application than NFS lube, which happens to be the best lube in the galaxy.
Likes For indyfabz:
Quoted: 2976 Post(s)
Liked 1,182 Times
Has anyone ever counted how many chain lube threads have existed on BF over the years? Something as simple as lubing your chain...Do these type of posts really need to exist?
Just find some lube and use whatever makes you happy fercripesakes.
Likes For prj71:
Liked 8,929 Times
Liked 2,512 Times
Likes For seypat:
Liked 10,975 Times
Definitely an amateur...
Quoted: 33 Post(s)
Liked 94 Times
Except this one is different from the usual, "What's the best lube?". This one is, "I bought this lube, tell me it's the best...I don't want to hear otherwise."
Liked 10,975 Times
And as has been pointed out already, bf is full of these threads. Use the Search function. Or google.
This is an unproductive pair of requirements, since it's hard to evaluate a product like chain lube without drawing comparisons with other options. (e.g., "it lasts longer than product x," or "it works better in dusty conditions than product y.")
Likes For oldwinger14:
Liked 2,512 Times
I gave you 5 links to reviews of Rock N Roll Gold in post 5. 2 of them are actual Bike Forums threads on Rock N Roll Gold.
Likes For seypat:
Liked 2,512 Times
For the record, I use Yacht Rock Platinum. It's a lot smoother than the Rock N Roll Gold.
Advocatus Diaboli
Liked 1,533 Times
Advocatus Diaboli
Liked 1,533 Times
Not sure.. generally I'm applying lube in room temperatures. Yeah, I don't think it'd be a long-lasting option for wet weather riding.
Bikes: Cannondale Topstone, Trek Dual Sport, State Bicycle Klunker
Quoted: 87 Post(s)
Liked 132 Times
I’ve used it, it seems to be adequate. If you don’t want to hear other options it may be difficult for others to offer comparisons.
buy a small bottle and try it for yourself. It’s probably like $10.00 at a LBS. since it won’t destroy your chain, even if your not fond of it, it should be close enough to adequate for you to use the bottle without wasting it. If it’s a big turn off, give it to another cyclist, someone will use it.
