Wheel & Groupset Advice
I've just done my first Olympic distance Tri after doing sprints for a few months, and am currently using a Scott CR1 team, which, whilst a good bike, is obviously not a Tri bike.
My bike split for the 40k took 1:13, and I've decided I'm going to go for it any buy a Pedalforce TT2 frame with a few components online, and build up my bike from there.
I'm operating on a limited budget and want to know what is worth splashing out on and what isn't; should i go fully shimano 105 on the groupset, or should i buy 105 with an Ultegra crankset, etc.
Also, how much of a bonus will a Zipp 808/Disc configuration give me over, say, Planet X 82/101mm wheels?
Finally, should I buy the frame & groupset first, and use my current (non-aero) wheels for races, or should I first buy wheels, and use them with my current bike until I can afford the Frameset?
Thanks a lot for any input,
Chris
Chris
Bikes: Mtn Bike
105 is nice stuff. If it's properly setup it will shift just as well as pricier ultegra. A lot of the difference in the groupo is the STI shifters. Since you're building a tri bike that issue goes away as you'll be using bar-end shifters.
I've been racing the Planet X 50/82 combo for a year now and it is fast. The extra $1500 to go to Zipp is just not worth it. Here's the clincher, or tubular in this case, don't skimp on tires. I went with Conti GP4000s. At $100 a piece they are expensive, but the ride quality is amazing.
Do frame and groupset first. The flexibility on seating position and overall fit will do more for your ride than the wheels will.
I think some tri-fits prefer downsizing on crank length. Sometimes they will go down to 165mm. Consider that when you're selecting your crankset when buying a group.
105 is plenty. Microshift shifters, or the old stand by DA bar ends (does shimano make a 105 equivalent?). Not terribly expensive. I'd bet RD/CHAIN/CASSETTE/FD/CRANKSET/SHIFTERS can get pieced together on ebay for ~300
Very little, some aero is better than no aero wheel (if you can afford it), but aero vs more aero is diminishing returns. Save the $ and get an aero helmet (if you don't have one), will save you more than the difference in those wheels likely
Frameset. Much more comfortable to ride/run afterwards on a tri bike. The wheels will gain you a handful of seconds on a 40k (maybe a minute or so, I am sure there is hard numbers out there), but a proper aero position and helmet will gain you more. (assuming you don't have clip-on bars on your road bike, this could be fairly substantial).
On the same wheel set, I am ~1mph faster on my tri bike/helmet vs my road bike over a 40k. I can stay aero the whole time, and am less sloppy with position on the TT bike vs the road bike in the hooks
Chris
Late addition. You say you are on a limited budget. You CAN modify the road bike for better TT position with forward seatpost and clipons/appropriate head gear. But if you are considering carbon aero wheels, i don't think you are REALLY on a budget, it's just there in case your wife reads this .
Bikes: 2011 Cannondale Synapse Alloy 5 105
I currently ride 105 and I like how crisp they shift. Also agreeing with Adam here, if you are looking to go to carbon rims, Ultegra wouldnt be that much of a shock to afford over 105, but not too much difference with shifting quality.
ckc 189
Road Cycling
18
04-24-19 09:07 AM
Zeppelin
Road Cycling
54
10-20-15 09:25 PM
Excelsius
Road Cycling
70
08-02-12 10:17 PM
