What’s your “ready to ride” road-bike weight? I was surprised at mine!
I know we’re often a bit obsessed with our bike weight, and value upgrades that can shave off a couple of hundred grams here & there. However, I’ve often suspected that manufacturers or bike reviews take a very minimalist approach when listing weights, i.e. no pedals or accessories of any kind
Out of interest, I thought I should weigh my bike with the gear that I actually have with me when I ride.
I was surprised to find that my 2017 Specialized Roubaix Expert UDi2 weighs in at 10.2kg without a bidon. I excluded the bidon, because they come in a variety of sizes and people carry different amounts of water. With a full 700ml bottle, the total would be closer to 10.8kg.
This includes:
1) front & rear lights (Serfas / Lezyne),
2) SWAT box with CO2 bottle & valve, spare inner tube
3) Small multi-tool + 2nd lightweight tube in a tiny saddle bag (I have punctured twice on a ride, so always take two)
4) Small top-tube bag for phone, keys etc. (Empty for weigh-in)
5) Garmin Edge 200 + out-front bracket, a small Cateye cadence meter, a tiny bell (legal requirement),
6) Speedplay zero pedals
7) 28mm Conti GP4K II tires.
There isn’t really too much that I could get rid of here. Maybe ditch the lights if there’s no traffic (I always have flashing lights to help distracted drivers see me). I could go with one tube or use patches if got two flats. Reduce the electronics - but then the ride didn’t happen if it’s not on Strava :-)
I know that some of the gear could be carried in my jersey instead of the bike, but it’s still there in the total weight. (Which raises another question as to whether extra gear is best carried on the bike or on the rider....)
IIRC correctly, one review showed the Roubaix Expert as weighing 8.4kg. Does the rest of my gear really weight 1.8kg, or are the reviewers being “generous”?
Let’s have a weigh-in, and find out how much we’re really pushing up those hills :-)
This includes:
With a mighty wind
Quoted: 1086 Post(s)
Liked 859 Times
18.47lbs ready to go but with no repair kit.
I only carry a tube and teeny multi tool plus a small frame pump.
I'd imagine it would go up a pound with that.
Quoted: 1096 Post(s)
1.8 kg sounds like a lot for accessories, but they do add up - the full saddle bag especially. I would expect it to account for up to 1/3 of that weight.
I can understand not wanting to put tubes, tools and canisters in ones pockets, and the lights, and even the bell, but the top tube bag - that's gotta go. Phone and keys? That's what jersey pockets are for. You're not carrying a three-course meal back there, are you? And by the way, what do you do for long rides when you might need to change out gloves or doff your warmers or windbreaker? Mount panniers?
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1248 Post(s)
Liked 1,275 Times
I don't own a scale, so I have no idea.
But I do know "a pint's a pound the whole world 'round" so whatever my bike weighs, add 3lbs for the two 24oz water bottles that invariably get loaded onto it.
For winter or the possibility of wet weather I often have an old water bottle converted to hold a Gillet or waterproof - so even more weight!
Quoted: 1814 Post(s)
Liked 923 Times
16.55lbs
w/ front & rear blinkies, bell, Garmin & mount, PM,
spare tire, pump, tools including pliers & chain tool, tire levers, 1st aid kit, needle thread thimble,
valve cores, extension, quick link, patch kit, $, paper & pencil, tape, knife, zip ties
& the new, weighty 11/32 cassette.
Everything except water bottle & 1 1/2 oz of sealant that I carry in jersey pocket.
16.55lbs
BTW, did you mean spare tire, or spare inner tube? That would be even more impressive!
Liked 923 Times
It's a Tarmac, & has weighed just under 15lbs, so just about the UCI limit.
I run tubulars, so yes a whole spare tire.
It will run on a clincher wheel in a pinch as well, so good to have one of us in the group
if you slash your tire.
Sunshine
Quoted: 10954 Post(s)
Liked 7,481 Times
23.85#
23.15#
24.30#
Weights of my 3 current road bikes. Pedals, cages, wedge bag of stuff included.
63-64cm steel frames.
23.15#
24.30#
Quoted: 4559 Post(s)
Liked 2,802 Times
"Ready to ride," meaning full water bottles, saddle bag with minimal spares and tools, pedals, etc.? Gotta be close to 28 lbs. This 1980s steel road bike weighs about 23 lbs without all that stuff, but that's not how it's ridden. I suspect Centurion omitted the pedals from the weight because those aluminum Look pedals were heavy.
Quoted: 663 Post(s)
Liked 496 Times
I don't obsess too much about weight although no more than I find necessary of convenient. The basic bike is 20.5 pounds and tools add another 2 to 4 pounds. Then, I usually have an extra layer in a handlebar bag unless it is mid summer. Around town could add another 10 pounds worth of library books.
Quoted: 1216 Post(s)
Liked 185 Times
Like 30 pounds.
After leaving the road race-industrial complex behind I basically ride a sport touring bike festooned with lights, fenders, framebag and three water bottles. Handles gravel and riding through the middle of nowhere without cell signal or water availability. It's overkill when I go for shorter local rides but it seems pointless to remove things when it rides fine, just slower, with all the stuff. Helps keep me strong for thrashing around my gravel racers and MTB, at least that's what I tell myself.
Quoted: 1743 Post(s)
Liked 1,281 Times
Guru Sidero (steel) w/Garmin, 1 bottle cage, 1 Italian roadbike mirror, blinkie light, seat bag w/levers(1 lb), tube, Pump/inflator, etc. , Speedplay Pedals and no water bottle.......19 lbs even. Not bad for steel IMO. I thinks that's 8/66 KG.
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
16 lbs 14oz with garmin vector 3 pedals, tail light, garmin edge 520 and metal kedge mount. Bottle cages (no bottles), tool pouch with tube, co2, adapter, levers, multi tool. 38mm carbon wheels set up tubeless 25mm tires with 2oz of sealant in each.
Bike is steel with carbon seat tube
Liked 1,281 Times
Bike brand? Tubing? My bike is about that weight w/pedals only but not "as ridden." Columbus Spirit tubing.
My heaviest bike that could be vaguely construed as a road bike weighs about 35 pounds when complete with full water bottles.
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times
As we are into this weight thing...
Some of us like to carry more stuff on the body and less stuff on the bike.
That could be spares, bidon, heavy shoes/cleats with light pedals, and padding in shorts vs saddle. ~2lbs there easy.
The "real" test would be to put everything but your naked body in a pile with bike and weigh it.
Quoted: 94 Post(s)
23.7lbs
this is with me just standing on my scale with my bike so not sure how accurate that is
will be about 22.7 once I get my new tires on there in a week
Pizzaiolo Americano
Probably doesn't matter with my fat butt on it...
I don't know. My bike stripped is at 17lbs with pedals. 30 pounds came off the rider. The rest is minor by comparison.
