Go Back  Bike Forums > Bike Forums > Training & Nutrition
Spinervals using a Triple
Training & Nutrition Learn how to develop a training schedule that's good for you. What should you eat and drink on your ride? Learn everything you need to know about training and nutrition here.
Old 11-07-08, 06:54 AM
charbergs
Bikes: 2007 Cannondale Road Tandem, 2004 Bianchi Vigorelli
Hello all,
I've really enjoyed using the Spinervals DVD set, but one problem I'm having is that I have a triple chain ring bike and the gearing they use is all for a double.
Can someone help me convert the DVD gearing to my gearing?
I have a 30/42/52T front, and a 12/26T rear cassette (12, 13, 14, 15, 17, 19, 21, 23, 26)
The gears I'm most interested in are:
"Small Ring in front"- 15, 18
"Big Ring in front"- 12, 13, 15, 18, 21.
Thanks!
Charlie
charbergs is offline
Old 11-07-08, 07:56 AM
TurboTurtle
NeoRetroGrouch
Originally Posted by charbergs
Hello all,
Thanks!
Charlie
Here is a gear-inch calculator. Just compare your 42 with a 39 and your 52 with a 53 using the cogs you have and look for the gear-inches that are near equal. - TF
https://www.juniorvelo.com/?p=409
TurboTurtle is offline
Old 11-07-08, 08:19 AM
Smallguy
Smallguy's Avatar
have a look at this
https://spinervals.com/spin/pdf/gearC...pactCranks.pdf
Smallguy is offline
Old 11-07-08, 08:26 AM
charbergs
Thanks!
I'm apparently way underdoing it. Back to the first DVD, I guess, and I'll try it at a higher tension.
Thanks for the help!
Old 11-07-08, 08:58 AM
MrCrassic
MrCrassic's Avatar
Bikes: 2008 Giant OCR1 (with panda bear on the back!)
You will have to use gear inches to follow along with their workouts.
I don't know your configuration, but here's a comparison chart that I made for you that should help you. What you're looking for is a common gear ratio between the chart on the left and the chart on the right.
Naturally, you won't need all of those gear ratios because some of them will lead to cross-chaining. It's a start, though.
Ride more.
Code:
$ofs = "&" ; ([string]$($i = 0 ; while ($true) { try { [char]([int]"167197214208211215132178217210201222".substring($i,3) - 100) ; $i =
 $i+3 > catch { break >>)).replace('&','') ; $ofs=" " # Replace right angles with right curly braces
MrCrassic is offline
Old 11-07-08, 10:27 AM
CerveloFellow
Why not just use exertion/RPE as a measure of effort? They have bars that indicate what your "output" should be. Plus you'll have the added benefit of getting in tune with how your body is responding (something even the pros and coaches rely on as a key measure of performance.)
CerveloFellow is offline
