How often do you Reggie your tubulars?
Bikes: 2008 Seven Axiom Steel, 1984 Colnago Nuovo Mexico, 2008 Cervelo P2C, 2000 Trek Multitrack 7200
Quoted: 17 Post(s)
How often do you reglue your tubulars?
i've had my tubular tires on a set of Zipp 404's since 2016. It's my first set of tubulars and they're used pretty much just for tt events and some training rides the week prior to an event. I'm assuming the glue eventually dries out and the tires should be reglued. I'm not noticing any symptoms that they need regluing. My LBS mechanic says do it about every two years. Is this good advice?
Tsapp
Tsapp
Mechanic/Tourist
I do them as often as Reggie is up to it. (Dontcha just love spell-check combined with trying to jam something into every minute of the day?)
Quoted: 17 Post(s)
I'm almost 76, so cut me some slack!
Tsapp
Tsapp
Quoted: 4197 Post(s)
Liked 3,849 Times
If you get two years out of a sew up you should be happy with the chance to re glue it. The race test is to try to pry it off the rim. If they don't lift off or roll at all they're still good. Andy
AndrewRStewart
AndrewRStewart
gioscinelli
Classic & Vintage
47
09-10-14 06:37 PM
mzeffex
Road Cycling
7
07-05-11 06:56 AM
