Any New Suggested Tires For 2016?
I'm due to retire (re-tire?) the stock set on my bike and I know I could immediately go to the Continental Gatorskins and be happy but I was wondering if anything new emerged over the Winter that people are all tingly about. I'm a bike path rider if that matters.
got the climbing bug
Bikes: one for everything
Liked 935 Times
Loving these panaracer gravelkings in 28c. I'd say they are a cheaper competition to the gatorskin hardshells but ride better imo. Zero flats in the month I've had them. All types of terrain so far.
$40 each in Amazon prime.
https://www.amazon.com/MRP-TR6258-P-P.../dp/B00PUE49NU
Rule #10 // It never gets easier, you just go faster.
What size of tires are you using? Goals? Touring, commuting, gravel, speed, MTB?
I just mounted a pair of 700x23 Tannus tires on my winter commuter. NO FLATS... EVER
They were a bit of a pain to install, and it is still early in the testing phase, but so far, so good. I do chirp a bit on my driveway hill, so traction could be a bit better, but perhaps it will improve as the tires break in. The ride seems similar to other high pressure tires (for the ones I chose, there are wider ones available).
Purchase Tannus Aither 1.1 Solid Foam Bike Tires
Liked 326 Times
I never noticed a difference in the flat rate between the three tires, although the GP4000S/SII lack side-wall protection and would not be good on gravel.
There's also a Grand Prix which is supposed to share the GP4000 tread compound, but has tougher side walls. I have no clue how that rides or measures.
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Liked 6 Times
I've also been using the Gravel King 28s and really like them. I've put about 2,000 miles on a pair over the past 6 months, mostly commuting. I've had a couple of flats during that time, but that's to be expected while commuting in winter, riding in the dark often with lots of potholes. My rear tire still has plenty of tread but has a lot of cuts, so I might replace it soon.
Compared to Gatorskins, I would rate the Gravel Kings as a much nicer riding tire, wider in size 28, but probably not as flat-resistant or long-wearing. I am not a Gatorskins fan, as I found them harsh-riding.
I'll have to look at my exact size but basic a road bike size. I know that only narrows it down. I'll look.
While I do commute some I'm training for an Imperial Century. So basically tires for someone who will do regular 40+ mile rides.
Continental now sells the GP4000SII in widths up to 28mm. They'll save you 20W+ at 20MPH over Gatorskins and 15W+ over GP 4 Seasons.
I never noticed a difference in the flat rate between the three tires, although the GP4000S/SII lack side-wall protection and would not be good on gravel. There's also a Grand Prix which is supposed to share the tread compound, but have tougher side walls. I have no clue how that rides or measures.
The bike paths around here are relatively flat. We do have a fairly extensive system around here and I can go many miles and only have to use a few stretches of road. With that in mind if there is any actual gravel it would be because of temporary path fixing or the like. Nothing stead.
Interesting. I'll check those out.
Tannus Aither 1.1 Tire Size Chart Tire Selection
Installing Tannus Bicycle Bike Tires | Tannus USA
Tannus Tires - Solid Bicycle Tires
But, in general, there are different widths, that would vary a bit by one's use and weight.
narrower tires (23mm, 25mm width) may be a bit sportier for various reasons, but are also better suited to lighter riders.
wider tires (28mm, 32mm) give a bit cushier ride, and would also be more appropriate for heavier riders.
I'm not sure about rolling resistance. 20W would be a substantial difference, but may only work out to be a minimal difference in speed.
Liked 935 Times
at least 1 or 2 pending if I ride on dirt or not. Lower pressure gets pinches or I catch one of those thin wires from tires.
With the GKs I'm running 83F/85-87R psi and been solid so far.
GP2s are my favorite summer time, really good cornering grip and fast!!
If you go with the Tannus, there are tire/rim width charts, and you have to be pretty specific.
Though I am heavy for biking standards I'm not as heavy as I was and probably sometime in 2016 I'll be around 210 lbs.
Oh I don't have to worry about cornering as I generally only have to get into that if I'm reacting to an issue or made a mistake. Generally I just still don't trust leaning over too far on a curve. I don't know if I'll ever trust tires (or me, basically) that much.
Bikes: Too many to list
Liked 1,127 Times
When i have a choice, i use Vittoria Open Pave' open tubulars in miscellaneous widths -- life's too short to put up with cheap tires unless a person has some legitimate durability concerns because of their road surface
Non omnino gravis
Maxxis Re-Fuse TR. They call the new tubeless versions "gravel/adventure tires" for whatever reason, though the tread appears identical to the tubed version. I can't speak to the tubed, but the tubeless is a damn revelation. I rode for 4500 miles on Gator Hardshells, and switching to the tubeless Re-Fuse is like getting a supercharger. My average speeds for full rides have gone up over 2mph. It's absolutely unreal. I knew that the Gators were renowned for their rolling resistance (and durability-- I had zero flats in those 4500 miles) but the Maxxis are a whole new thing altogether. Extremely fast rolling, plush as all get out (I run 60F and 70R in my 700x32s) I've yet to find a single drawback. If I get even close to 2000 miles out of the rear, this will be my choice of tire... FOREVER.
Behold the power of the Re-Fuse.
Non omnino gravis
<shrug> Maybe? It's supposed to be long-wearing, and also has a full-width kevlar belt, so definitely what would be classed as an "everyday" tire, like a Conti Gator, only it actually rolls. I cannot emphasize enough, the Re-Fuse rolls so much faster the Gator might as well be square.
But yes, definitely not a "trainer" tire.
I at 360 pounds ride the Schwalbe One tubeless tires at 100psi and man it is a great ride, and I don't have to worry about pinch flats.
You will find some companies list a "training tire" this is just a way to say "every day use tire" or "not specifically a racing tire".
A Trainer tire is not for outside use, but for use on rollers or a trainer, but a training tire is for general riding or "training" for that big race.
One thing I'm thinking that I'd like to explore is energy usage. Since doing the prep for this 100 miler I have planned will involve quite a bit of riding I'd like to have as low of rolling resistance as I'm willing to spend on. However I also want to give consideration to "It's not hurting you a significant amount" when NOT going right to the Conti GP 4000 S II's. The idea of not having to deal with flats is an attraction for some of the tires mentioned in this thread but they also have a bit more rolling resistance. Does it really matter in the scheme of things as long as the are mush?
DrIsotope mentioned that the Re-Fuse rolls better than the Gator, which is my default tire. The GP 4000 S II is probably even less than that. So really as far as rolling resistance, and extra energy one would use, what is the real difference?
