Upcoming FTP test
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,179 Times
Upcoming FTP test
i will be taking an FTP test in about two weeks time. i'm doing this in zwift. wondering what the terrain should be. anyone have some insight into the kind of terrain? hilly, giant hill, flat?
i am thinking flat so i can maintain a good rhythm during the course but not sure.
and please don't knock me for using zwift, it is what i have.
thanks,
scott
thanks,
scott
Quoted: 18883 Post(s)
Liked 10,646 Times
Flat.
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
If you're using Zwift's own FTP test, I don't think terrain matters, or at least it doesn't with the ramp test. Can't confirm this with their other FTP testing methods but I can't imagine them factoring in terrain.
Likes For atwl77:
Quoted: 528 Post(s)
Liked 230 Times
thanks,
scott
thanks,
scott
Quoted: 1027 Post(s)
Liked 325 Times
Another option is to simply set the trainer difficulty to 0 and your resistance will be constant on every ride, workout or not.
Likes For OBoile:
Liked 1,179 Times
Unless zwift assumes a 0% grade i believe the route does matter. the ramp test i think i have seen before and that is in erg mode i believe. in erg mode the route does not matter because you are after a target power and the trainer adapts.
when i ride trainings i don't care about the route because they are all in erg mode. i go slow "uphill" only because zwift is adjusting my speed to make it more real taking into account the current target power.
if one were to do an FTP test in real life on a real road the terrain/weather surely comes into play.
i'll do it on a flat route like out in the desert, tempus forget what it is called.
-scott
-scott
Quoted: 6178 Post(s)
Liked 4,796 Times
It's all about how hard you can go for the time given. So you want to make sure you don't overestimate how much you can put out for a given route and time, nor do you want to underestimate how much you should put into it.
It really doesn't matter if it's a hill or curves or what as long as you are putting out your max effort the entire time. A straight and level course just make it easier for you to guess how hard you can go without burning out prior to the end.
Liked 325 Times
-scott
-scott
https://www.strava.com/activities/2973381560
During the 20 minutes, erg mode is off but the resistance does not change based on the terrain.
