How to put together or what to do with wheel components?
I have a killo tt and am slowly upgrading the stock components. I have gathered a velocity deep v back rim, dt spokes, and a formula hub. Right now the stock wheel set is on. I don't know how to put this wheel together myself, can i take these parts into a shop? or where can i find the information to do it myself? i replaces the crank and of course the pedals very easily so i'm not a total newb.
thanks!
thanks!
GONE~
Sheldon has got an elaborate article on wheelbuilding.
You could learn to put it together but it will be kind of hard to finish it up without a truing stand or you could give it to a shop to build it up. ~$50 and up depending on the shop.
I would suggest you to go build it up yourself, wheelbuilding could be a fun experience.
Sounds like you're in way over your head. Do you have any idea if the spokes you have are the correct size? Start here: https://www.sheldonbrown.com/wheels/index.html. Wheel building isn't rocket surgery, but it's a lot more complicated than replacing pedals and cranks.
Also, prepare for merciless ribbing from the bike forums mob.
Prepare to get those spokes cut, buy nipples, spoke tensioners, and the parktool tm-1 spoke tension meter as well as a wheelbuilding stand. not all are required, but i highly recommend.
Painfully average.
Do you know how to build wheels/have those tools?
GONE~
Bike co-ops are perfect for this scenario, you can use their tension meter, spoke keys, replace spokes/nipples, truing stand and most of all, advices from the mechanics. Especially during the winter times, they are usually not as busy as the better seasons.
That said, I have used my bike co-op's wheel building equipments to rebuild wheels for them. Plus, they have cheap spokes, $20 for whatever amount you need with nipples, can't beat that.
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
What are you talking about, do you even know if he bought the incorrect length spokes? Also DT spokes come with nipples, so he shouldn't need to buy those. And you don't need a tension meter, I have built many a wheel without one.
Bikes: 1990 Waterford Paramount, 1986 Pinarello Pista 195? Raleigh 3sp, 2001 Surly 1x1, 2014 Canfield N9, 2015 Canfield Balance, 2013 Rocky Mtn Flatline, 2012 Intense SS2, 2014 Transition Klunker, + more!
To properly build a wheel, this is a crucial piece of equipment. To little tension and you start to break spokes and the wheel does not remain true, to much tension and you start to break spokes and possibly damage your rim and/or hub. Good luck to you hack.
Nü-Fred
Bikes: Torelli Tipo Uno (stolen), Peugeot Nice, Mercier Kilo TT
tension meter is not totally needed as u can check by sound as i do with my wheels. But if u want to be extra sure, or if u are just starting out then having one is good.
extra bitter
Why are some folks so adamant about tensiometers? It's certainly preferable to use one, but pitch works fine.
Quoted: 3375 Post(s)
Liked 5,513 Times
Perhaps so you *know* whether the tension is in spec, rather than making a wild guess?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Funny how these threads get out of sync with the OP. We have a clueless newb who clearly has no business trying to build a wheel, and here we are debating the fine points of wheel building methodology. Fact is, a wheel built by an experienced and skilled wheel builder without the benefit of a spoke tension tool will be better than one built by an inexperienced newb using a tension tool. Wheels that I built decades ago w/o using a tension tool are still true today after thousands of rough miles of use.
Bikes: 2010 Specialized Allez, 80's Shogun Selectra, 2007 Specialized HardRock
Liked 5,513 Times
How I started:
1. Bought the Jobst Brandt book "The Bicycle Wheel".
2. Bought spoke wrench, truing stand, tension meter.
3. Selected hubs, rims and spokes, used spocalc.xls to get spoke lengths, ordered parts.
4. Built wheel with Brandt book at my side.
OP seems to have vaporized anyway, so dragging this on is probably a waste of effort.
Hey thanks. I decided to do it myself and borrowed a tension meter from a friend. It's working out so far. Hope it stays true.
