Recessed brakes when??
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
This must have been discussed a zillion times but what the heck. When were recessed brakes introduced and when did they become standard? Was it gradual across the industry, or did one company do it after Campy or Shimano made it available and everyone followed?
Real cyclists use toe clips.
jimmuller
jimmuller
Quoted: 4722 Post(s)
Liked 3,039 Times
The earliest commercial brake set with recessed bolts, that I'm aware of, was 1979 Shimano Dura-Ace EX. Campagnolo followed but there there appear to have been some Italian builders making frames for recessed bolts in possibly the very late 1970s. These frames appear to have utilized custom bolts or the aftermarket versions offered from companies like OMAS.
Edit: I think Zeus 2000 was first, in the mid-1970s.
Edit: I've confirmed that Zeus had recessed bolt as early as 1975 on their Zeus 2000 brakeset. Attached is a comment from a September 1975 review in Bicycling magazine. However, I still believe that mainstream popularity followed their use on Dura-Ace EX and Dura-Ace AX.
Liked 645 Times
Hmmmm.... I ask because I'm digging into the details of the Champion Mondial A-Frame I picked up from Chrome Molly.
According to this Champion Mondial website the serial number places it maybe a third of the way into 1977. It has features consistent with the '77 CM A-Frame, the butterfly rear brake bridge, DO eyelets, the heart-shaped cutouts on nice long-point lugs, wraparound stays, 120mm DO spacing. But then, those details didn't change much during that time and some like the DT bottle bosses (which this frame has) and TT brake housing eyelets (which frames does not have) were optional. The details are also consistent with the '77 catalog to the extent that I can see the pics and interpret the Dutch.
Both the rear brake bridge and fork require recessed brakes. (FWIW, the forks SN matches the frame's.)
Now, that website also says "late '70's to early 80's" the frame size and rear dropout spacing were stamped into the bridge, and frame size stamped under the bridge when they changed to the Cinelli style. (My '86 A-B Frame has the later style with size. Other details aren't totally consistent with the catalogs, but then they could have been custom-ordered too.) The bridge on the '77 is clean. Perhaps they were filed out prior to the repaint but there is no sign of it. So I assume it was made before the "late 70's" practice began. This wouldn't be significant except for the possibility that the brake holes had been drilled out by the previous-previous owner who'd also disguised it as a Colnago. If so, he did a nice job. But it sure looks as if it came from the factory with holes for recessed brakes.
(I happened to have a nice shiny set of single-pivot 105 brakes which mount perfectly and look good on it.)
jimmuller
jimmuller
Liked 3,039 Times
I know little about Gazelle but given that the top frames were designed around Campagnolo groups, I would expect it to have been designed for exposed brake nuts. Clearly the complete bicycles in both the 1977 & 1978 catalogues depict exposed brake nuts. While this doesn't rule out the possibility of a custom order, I strongly suspect the brake mounting holes were modified by the previous owner.
Bikes: 1984 Schwinn Paramount Touring (650b conversion), 1993 Trek 7900 Multitrack, 2014 Bianchi San Jose (igh-8), 1983(?) Bob Jackson Tourist (igh-5)
This is off the top of my head, but I believe that in 1977, even on top-end frames, water-bottle bosses were rare.
Quoted: 384 Post(s)
Liked 6 Times
Liked 3,039 Times
When I bought my Scapin SL in 1974, it had bottle bosses. Ocana's Motobecane had them in the 1973 TdF. They were more widespread in 1974,including Merckx's bicycle. Still, depending on their personal philosophy, some manufacturers continued to resist brazed-on fittings for the the lighter gauge, centre sections of the tubes. Personally, I think that the big change was framebuilders accepting the benefits of using silver solder for small fittings on light gauge tubing.
Liked 645 Times
Thanks, guys. Most appreciated.
That CM website lists the various features and options model by model and year by year if you click on the timeline graphs. Apparently bottle bosses were an option for the '77 A-Frame. TT cable eyelets were too but this frame doesn't have them. I'll have to look at the other recessed-brake frames I have to see the details of the recessed holes. I confess I never paid them much attention before.
This is shaping up to be a very interesting exercise. My other Gazelle is so nice. But for some years at least the frame dimension were different between the A, A-A, and A-B frames. I'm curious to see how they compare.
jimmuller
jimmuller
Quoted: 3464 Post(s)
Liked 2,831 Times
This new software is buggy.
Masi Carlsbad made a show bike in 1975 with recessed brake mounting, Rydjor bike shop last had it and may still do.
Mario Confente used recessed brake fixing on all his USA built bikes, those started in 1976.
Liked 3,039 Times
I can only speculate as to why the mass market oriented brands were slower to implement bottle bosses. It was more expensive and they may have been waiting to see if it was just a short lived fad. Also, the early bosses were threaded studs brazed to a frame (see pic). These were ugly without a cage and bottle in place, which was another
added cost.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
My 86 Trek 400 Elance came with a recessed fork and a nutted rear.
Commence to jigglin’ huh?!?!
Bikes: Might as well, now that I am here...
Quoted: 79 Post(s)
Liked 78 Times
I've owned a'n '84 CM. IIRC, the front brake wasnt recessed, so my 1988-ish DA brakes didnt fit. So I sold it on... :-/ Still kinda regret that.
I've recently aquiered a 1984 (I think) Tour de L'Avenir. I plan to keep this one (going to make it a randonneur/commuter).
Beatiful frame though. love the colour! Very Dutch :-)
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
My Bikes
My Bikes
