Shock absorbing road seatpost
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
I'm building up a Lemond 853 frame. The idea will be to install an Ultegra (not sure about the R8000, I may save several hundred and just go for the 6800). I have an old aluminum seatpost from a cannondale. Fits fine. Holds the seat in position fine.
But I was thinking that to absorb some of the road noise that a shock absorbing seatpost would be nice.
They may absorb road shock, but they sure as heck induce sticker shock. E.g. over $400 for an Ergon CF3! Luckily (in case I was tempted to be an idiot), the Ergon is only rated up to 220lbs and I'm a Clyde (6'2", 240lb).
Any ideas on a tush-friendly road seatpost for a large BSO*? Or is this not necessary if I get the right wheels and saddle? I have a set of Bontrager Paradigm Elites, and these wheels do give a comfortable ride on a CF Domane.
*In this case Bicyclist Shaped Object.
Non omnino gravis
Sunshine
Quoted: 11044 Post(s)
Liked 7,595 Times
I would go with quality wheels, saddle, and cockpit(bars and tape). I cant imagine a suspension seatpost on a roadbike. Light supple tires that are the largest possible to fit the bike plus a comfortable saddle all day long.
Im guessing the Lemond needs a 27.2 seatpost? This cuts the current option's cost in half...
https://www.specialized.com/us/en/co...eatpost/105098
I have a cheap Nashbar suspension post on my frankenbike and it seems to work, BUT in only a few months it has loosened where the seat mount attaches to the post allowing the seat to yaw a bit...not a showstopper, but occasionally disconcerting. I'm going to replace it with my old aluminum post. I've put 28mm Conti's on that bike, so do not think I'll miss it.
Update: the Nashbar post is back in service. There was a clamp that required tightening under my seat bag...duh! So, no more yaw. Nashbar post costs around $20.
You can get a cheap coil spring inside telescoping seat post for under $30.
@240pounds you are at the very top of the range of Cane creek's thudbuster ST with its densest elastomer..
I'm close but 30 pounds less.. @210..
My Koga WTR trekking bike came with a German Air Wings seat post, zero setback , I put on a ST thudbuster for setback .
the post itself the German one is larger than 27.2.. it was in a oversize seat tube frame and shimmed out to fit it..
So selling it to you wont work, I guess.. these are not light weight seat posts..
Quoted: 2628 Post(s)
Liked 1,972 Times
Took me a while to find the reference, but here's one that should work for your weight:
https://www.amazon.com/Cirrus-BodyFl...float+seatpost
There's a cute movie showing it in action at: The Cirrus Bodyfloat Seat Post at R+E Cycles
Liked 342 Times
It is a 27.2. I'd seen the specialized post. It didn't compete very well against the Ergon/Canyon one in this test. And I don't like the look - too bulky.
The thudbuster and the spring post are both interesting. Thanks to folks for pointing them out. But, as was also pointed out, they add weight. Not sure its justified. I think I'm going to stick with my humble mid-90s Kalloy aluminum post unless the assembled bike is too rough. Probably vultch ebay to see if I can snag a bargain if I want to improve. Not spending more than 40 bucks. 400 bucks for a seatpost. Meh!
Thanks to all for your help.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Fabric Scoop saddles with flexible base absorb lots of vibration.
The "Cromo" and "Titanium" models have a flexible nylon base while the "Carbon" model has a flexible carbon base. The "Ultimate" model has a stiff carbon base.
I have not tried the one with the stiff base but I own three with flexible base. The flex can be felt in these as one rides and I love it on my gravel bike.
https://usa.fabric.cc/saddles/scoop-shallow-cromo/
-Tim-
-Tim-
Quoted: 18423 Post(s)
Liked 4,544 Times
Perhaps trade your bike frame for a "Softride" frame?
Sunshine
Liked 7,595 Times
Oh, its as pretty as braces. Just a total exercise in accepting function over form.
I am shocked I even linked that adams apple of a seatpost.
It apparently isnt all marketing, but $200 is wildly expensive for a goiter on a post.
Calamari Marionette Ph.D
A good leather saddle offers a significant amount of shock absorbing suspension travel. The hammock design provides real world results that can be felt immediately.
Liked 342 Times
I agree. A broken-in Brooks Pro is very nice. But the one I have is pretty decrepit. Leather is cracking.
* A long, tragic story involving a drunk hitting me and Rudy Schwinn sending me the wrong frame. Sigh.
Quoted: 189 Post(s)
Might I recommend the redshift shockstop suspension stem. Rather expensive, and definitely NOT a seatpost, but it helps.
Is your problem more with vibration dampening or with actual suspension? If the problem was with vibration I would just recommend a carbon fiber seatpost.
Tubeless wheels and tires, lower the pressure. Much more comfortable ride.....amongst other advantages.
Non omnino gravis
The ridiculous Spesh seatpost-- questionable performance aside-- is shaped so oddly as to interfere with the positioning of many, many saddles. I know a dude who has gone through half the list of suspension posts, from Thudbuster to Cobl-Gobl'r (it hurt to type that) and has a straight FSA carbon post on there now.
Liked 342 Times
Right now, I ride a Domane and it has the decoupling (isoshock?) seat tube to reduce vibration. So far, I just rode the frame (with a seat and handlebars) down my driveway. No groupset (no brakes, crank etc). So I don't have data yet, but I am anticipating a higher level of vibration. Maybe not.
Quoted: 189 Post(s)
The Redshift product looks interesting, thanks.
agree with your anticipation- going faster over rougher surfaces than your driveway will make lots more vibration.
Interocitor Command
I tried one of those suspension seatposts before and I don't recommend them. All I did was Pogo up and down on mine. Just think of this from the viewpoint of the car driving behind me. Very embarrassing.
Quoted: 1169 Post(s)
Liked 444 Times
I ride a Thomson Elite 27.4 mm post on my Aluminum Flyte road bike so I am only speculating but can offer a few thoughts.
1) I agree about seeking out a saddle that you like that has some give to it. I have ridden on Selle Italia Turbomatic series saddles for years. They have stiff, very slightly forgiving elastomers under the rails. These do help soften expansion cracks, bridge joints, roads being resurfaced, etc... My current one the carbon railed Team
Turbomatic is really nice but on the stiff side.
2) Have you considered a titanium post? Particularly, one with some setback? I have heard from several people that I respect that titanium posts add just enough springiness to be noticeable. Probably less than 1mm of actual deflection, but somehow capable of attenuating road buzz. I know you said $40 is your target price but if you think about your post as a real asset to your expensive bike, then spending more no longer feels out of the question. Type "titanium seatpost" into eBay & you'll see a good variety usually. Several of the Chinese made ones look quite nice for under $100. Also, used Moots & Eriksen ones seem to pop up in the $200 range.
Quoted: 18506 Post(s)
Liked 15,818 Times
bit old but eh. I have a canondale save post on my rigid mtn bike and it definitely helps off road. I only have it because it came with another used bike I picked up. I see them for around $80 shipped on ebay but they are also from Taiwan which makes me doubt if they are legit or clones.
Quoted: 285 Post(s)
Right now, Paradigm Elite wheels with tubeless R3 tires. They ride very comfortably.
Road bikes vary considerably in weight from under 14 lbs to around 22 lbs for budget models so an additional half pound of weight is hardly a significant penalty given the benefit of shock absorption.
I think more important than component weight is the amount of bob these suspension components introduce. You will definitely be less efficient pedaling using one of these suspension components. I've even found that cushy saddles make me less efficient.
You could try a saddle with more foam or wide tires as well.
I wouldn't sweat the weight though. Any body weight you lose will be a far more noticeable factor than the weight of a seatpost or a few extra grams in wider tires.
edit: I was going to recommend the fsa as well, but I read numerous reviews stating that the fsa saddle failed, despite users sticking to the recommended torque spec.
- Soli Deo Gloria -
Liked 736 Times
Reviewed recently by Gravelcyclist.com-Tim-
