Dropout Screws Spring Location -- Where and Why?
#51
Quoted: 380 Post(s)
Liked 541 Times
I'd have to rate that as a first definition factoid. Please tell me the correct number of links for the chain on my '81 Colnago and just where exactly to set the adjustment screws to take full advantage of that chain length. I expect that critically missing info is what has been holding me back for several decades now. OMG!! I could have been Famous! I could have been Somebody! Now this feels like the right time for me to start cutting myself for being so stoopid
#52
Quoted: 1857 Post(s)
Liked 664 Times
But do you have an alternative explanation for why those screws are in there? What do you think would happen if they are not there?
But really, when I'm done setting a wheel position that helps me set up your friction shifting just right, (for some reason my Masi is finicky this way) I do not want it messed with. I tend to spend a lot of time on fine tuning. Maybe I'm the stupid one, but I get my bikes working well. If you don't have the need, so what, YMMV. And I truly like to have those little wheel stops making my wheel installations consistent.
Likes For Road Fan:
#54
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 508 Times
I’m still wondering why “vertical” drop outs are so obviously not vertical. At least from that picture which looks a little more upright from horizontal but certainly not vertical.
#55
Sekine SHT
Bikes: 1975 Sekine SHT, Sekine SHS, Kuwahara Apollo MKIII (stolen)
Quoted: 1639 Post(s)
Liked 829 Times
The 80's French Simplex dropout, do not use those silly little springs,...........ptouie!
They use miniature Delrin hockey pucks with holes through them,......... of course!!
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
#57
Quoted: 405 Post(s)
Liked 430 Times
--Shannon
--Shannon
#58
57 posts and counting on whether the spring goes inside or out....
For you perusing pleasure, only on C&V Forum.
#59
Quoted: 405 Post(s)
Liked 430 Times
You can get anything you want, at Classic and Vintage Bikes... (except an answer)
--Shannon
Likes For ShannonM:
#60
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
Well, at least another generation of cyclists has been disabused of the notion that they were put there to convert a bike from “racing” (short wheelbase) to “touring” (long wheelbase) with a minimum of fuss, which was what I was told by fellow greenhorns, who didn’t race either but loved to BS about stuff.
My cycling “crowd” back then was mostly guys who hadn’t been athletic in school, so didn’t compete on bikes as adults, thus missing out on the deep knowledge of equipment and techniques that the racing fraternity got. The racing clubs did allow “civilians” to join their group rides back then just by showing up, so if you were willing to suffer physically and take not-so-gentle direction you could learn a lot. But I don’t recall dropout screws being on the curriculum.
As to the answer about where the springs belong, bikes on display in bike shops always had them inside the dropouts. So that’s one answer. Elaborating, the adjusters need the springs to stay put. Springless, with the wheel clamped in place, the screw is free to move backward, spoiling the adjustment for when you need to remove the wheel. If it is inside the dropout, it will still survive to do its job if the part sticking out back loses the knurled nut or breaks off altogether, as frequently happened when bikes were crammed into Volkswagens. So there should be no controversy about where the springs belong when you combine history with analysis of consequences of failure— which orientation causes the lesser impairment and the lesser need to buy a new part immediately? If you were happy with where the wheel was positioned, you would never need to replace a broken-off adjuster screw, provided it still had its spring. You even still had some adjustment, requiring a narrow screwdriver with the wheel out.
(Granted, as one poster said, if you needed the wheel almost all the way back, there wouldn’t be room for the thickness of the fully compressed spring and the screw head, so then yes the spring would have to go outside behind the dropout.)
There are alternatives to springs, as pcb showed us. His setup would hold adjustment if the screw broke off flush with the jam nut.
The thread wandered away when it tried to figure out if the adjusters actually did what they were claimed (by me and others) to do: assist with B-pivot tension.
#61
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
Likes For SurferRosa:
#62
Liked 664 Times
#63
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
#64
Liked 664 Times
As far as doing what we now know a B-pivot does, I believe that explanation more than I believe the tourer-conversion story. Adjusting free length was important, and that's a decent explanation for what I raised, that the shifting might go off-kilter in the middle of a race, even though a B-screw was not a thing back then. On my Masi I still sometimes struggle to get it (with NR gearing) to handle a 26 tooth cogset gracefully across all the gearing positions.
As for the spring location, I think we're in agreement. If you need to have a screw which needs to have a spring, it's better to have it inside the slot than sticking out the back.
Conspiratemus1, I hope you are not dissatisfied!
#65
Liked 664 Times
And as far as the aimless discussion drift, C&V here is not exceptional.
#66
Quoted: 4512 Post(s)
Liked 6,382 Times
Likes For merziac:
