Aluminum frame: Topstone VS Revolt
I'm thinking about building up a gravel bike. I'm leaning toward spending less on the frame (so aluminum) so that I have more left over for components. I've heard good things about the Topstone alloy frame so that was my first thought. After having a look around the Giant Revolt looks like a good option too.
Cannondale Topstone Sora (Canada)
Cannondale Topstone Sora (US)
Giant Revolt 2 (Canada)
Giant Revolt 2 (US)
Geometry - Similar in most areas except for the Revolt has 9mm taller stack and 5mm higher BB.
Fork - Both have carbon forks that I can't find any complaints about.
Thru-Axles - Both have 100mm front and back
Internal Cable Routing - Both have it.
Brake Mounts - Both have flat mount disc brakes.
Bottom Brackets - Revolt is press fit and Topstone is threaded.
Looks - Basically the same style and I like the colours of both base models.
Seatposts - The Revolt uses their proprietary D shaped seatpost which seems like a downside.
Price - The Revolt is about 8% cheaper.
Anybody know what the weights are for the framesets? The Topstone is listed as 10.3kg / 22.8lbs for the Sora build.
Any other input or opinions?
Giant Revolt 2 (US)
Quoted: 1872 Post(s)
Liked 692 Times
Bottom Brackets - Revolt is press fit and Topstone is threaded. <- advantage Topstone.
Seatposts - The Revolt uses their proprietary D shaped seatpost which seems like a downside.<- advantage Topstone.
Price - The Revolt is about 8% cheaper. <- advantage Revolt.
Anybody know what the weights are for the framesets? The Topstone is listed as 10.3kg / 22.8lbs for the Sora build. <- sounds about right, maybe a little on the light side.
Any other input or opinions? <- Unless they changed something the Topstone doesn't come with tubeless ready wheels, the Revolt does. <- advantage Revolt.
2019 Salsa Warbird
2019 Salsa Warbird
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
Specifically, what building are you looking to do on the bike? If you are wanting to add components that wont work for one/both of the bikes, itd be good to know now as that would affect your decision.
I was thinking 105 shifters and hydraulic brakes, XT rear derailleur, 1x Easton crank with 30mm spindle, XT 11-42 cassette and possibly Hunt wheels if I were to push the budget to the limit.
Sunshine
Liked 7,484 Times
Also, XT rd wont work with 105 shifters without a work-around, just fyi.
https://www.planetx.co.uk/i/q/FROOSP...ravel-frameset first that came to mind, though carbon.
https://www.jensonusa.com/Niner-RLT-9-Frameset-2020 this too.
Admittedly, I dont keep up on aluminum gravel framesets.
Bummer! Thanks for the info. You just saved me a potentially expensive headache. I thought the current mtb and road 11 speed stuff all got along.
Sunshine
Liked 7,484 Times
Basically, road and mtb dont work together past 9speed. There are a couple odd exceptions, but neither are truly full functioning drivetrains.
Use the link above to make 11sp mtb dr and 11sp road shifters work.
https://www.wolftoothcomponents.com/...roducts/tanpan
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
Having not ridden the Revolt 2 this is a one sided remark. I ride the alloy Topstone 105 and have found the bike works very well as a complete system. In my case I have no intention of drastically changing much on the bike and Cannondale frame sizing fits me very well. Most of my rides are on pavement/packed gravel-sand and the bike is very predictable. So much that it has saved my butt more than once when I have tried a path that was beyond my experience. Good luck.
Frank.
Frank.
Likes For Helderberg:
Liked 692 Times
I'll also add that the stock Fabric saddle on the Topstone is very nice, especially for a stock saddle.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Quoted: 3237 Post(s)
Liked 2,083 Times
Curious what Cannondale charges for an aluminum Topstone frame ? and can you order one ?.
I have the aluminum 105 Topstone. I purchased this bike as it's a very good price for a great frame and good component choice. I doubt it';s cost effective to order a frame and parts and do a build. It might be easier to buy the built bike, swap to 1x and a 11-42 cassette, maybe a GRX rear derailer might work with a 105 shifter, not sure. Personally I don't get the 1x choice for gravel, thinking 2x is far more useful.
If I had had the money to burn I would order somebody elses frame (Surly, Soma, Kona.....) which might be cheaper than what C-Dale will want for the frame.
It seems way easier to find steel framesets than aluminum. I've got a Specialized Sequoia right now. It's nice and cushy but I'm looking for something a little lighter and more responsive. That's why I'm leaning toward aluminum. I really like the green colour of the Topstone Sora so I think I'm pretty well decided on getting that one. I might ride it as-is for a while and just pick away at the components as I feel like it.
Likes For evan the cdn:
Liked 2,083 Times
Well, there’s this route. Grab this and swap out whatever components you desire.
https://www.ebay.com/itm/Cannondale-...MAAOSwN4VdzIHs
Last summer I found someone selling a brand new topstone frameset (in the sora build green color) on Craigslist and he said he bought it from his LBS. Might have had a special connection but it's worth calling around if you really want one.
I built up a jamis renegade escape from a frameset and I've been very happy with it. It's steel (Reynolds) 631 and was only $849 from my LBS. I think it checks most of your boxes:
Geometry - Can't compare. On my phone.
Fork - Carbon fork.
Thru-Axles - 12mm x 100 front. 12 x 142 in back.
Internal Cable Routing. Yes except for rear derailleur cable.
Brake Mounts - flat mount disc brakes.
Bottom Brackets - Threaded (BSA 68mm)
Looks - Dark grey/black
Seatposts - Not proprietary
Price - $849
Fork - Carbon fork.
Price - $849
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
Since I didn’t see much input for the Revolt I thought I’d add some since I own the Revolt 2:
My only gripe is with the Conduct brake system. Not because they are bad (because the braking performance is exceptional for this setup), but I basically have no way to figure out how to adjust or bleed them if necessary. I have GRX hydro levers that will go on and replace these so I won't be worried about that, but it is one annoying thing to deal with if you're a "home mechanic". If I wasn't, then these are perfectly fine in terms of actual real-world use.
- The BB is in fact threaded not press fit (the square tapered crankset was a big red flag)
- Tire clearance is huge. I ran 48mm tires on the stock 19mm internal rims and had enough room to get by.
- Can also fit 650b tires up to 50mm in the back and 55mm at the fork
Likes For DarKris:
Update!
I decided to go with the Topstone Sora. I haven't decided yet if I'm going to strip it or ride it as is for a while.
Here's the weight of my size medium. This is with the reflectors removed and the free plastic pedals still installed.
Quoted: 249 Post(s)
Liked 306 Times
Ride it as is. I have Sora on my second bike and it works well. The 105 on my Topstone is great gearing for my terrain and old legs. Ride it first and that will give you some real time feed back as to what needs to be changed and what you would want to maintain in the new build. Nice looking bike but I am more that a little biased.
Be safe, Frank.
Be safe, Frank.
