About folding bikes' rear shock "sag"
Old 04-05-21, 03:34 PM
Estuche
Quoted: 27 Post(s)
Hey, does anyone know how much the chainstays length is reduced when, say, a Brompton, Moulton, or Birdy's rear shock is compressed? What percent or how much smaller does a rear shock of the kind used in folding bikes get when compressed? 10% of its original size? What is that, 3mm?
Estuche is offline
Old 04-05-21, 08:13 PM
grayrest
Bikes: Birdy, Orbea Gain, Optima Baron, SatRDay
Quoted: 24 Post(s)
Liked 11 Times in 8 Posts
As near as I can measure with my calipers (the positioning is hard), the spring on my Birdy compresses 3.4mm and is 42.5mm uncompressed.
I measure the chainstay at 427mm so at most it would be 0.8% of the distance but the shock itself is off-axis and forms a triangle between the BB, rear axle, and contact point on the stem so it's a bit shorter than that.
grayrest is offline
Old 04-08-21, 08:05 AM
Falconista
Bikes: 1986 Falcon Laser, 2004 Dahon, 2018 Moulton TSR
Quoted: 29 Post(s)
Liked 7 Times in 6 Posts
The current Moultons have an fixed triangle between the crank and cassette, so the chainstay or chain length doesn't change at all when the suspension is compressed.
Looking at it the other way, pedalling hard doesn't compress the suspension, which was an energy loss on some mountain bikes.
Falconista is offline
Old 04-08-21, 09:03 AM
Schwinnsta
Schwinnasaur
Schwinnsta's Avatar
Quoted: 459 Post(s)
Liked 184 Times in 122 Posts
It is front suspension where most of the losses occur.
Schwinnsta is offline
Old 04-09-21, 02:32 PM
Jipe
Quoted: 800 Post(s)
Liked 247 Times in 211 Posts
What kind of losses ?
Jipe is offline
Old 04-09-21, 04:40 PM
Schwinnsta
Schwinnasaur
Schwinnsta's Avatar
Quoted: 459 Post(s)
Pogo losses from up and down motion. Losses from shocks are acceptable to me if they allow for faster speeds overall. So they may allow faster speeds on real bad roads but generally substract from speed on smoother roads.
Old 04-12-21, 03:16 AM
Geepig
Geepig's Avatar
Quoted: 194 Post(s)
Liked 204 Times in 151 Posts
I would imagine that if speed is the aim, then having the front forks steal a portion of each and every power stroke must be annoying, plus the extra weight that has to be continually re-accelerated.
Still, I will take the hit on my larger bikes, because it makes it easier on my old wrists.
Geepig is offline
Old 04-12-21, 08:22 AM
Schwinnsta
Schwinnasaur
Schwinnsta's Avatar
Quoted: 459 Post(s)
Actually its more about efficiency than speed..
Old 04-13-21, 12:02 AM
Geepig
Geepig's Avatar
Quoted: 194 Post(s)
Yes, very true, and energy conversion rates etc., I just wanted to keep to your subject of speed.
Geepig is offline
