Water Bottle Cage Noise
Bikes: Cervelo Prodigy
Quoted: 402 Post(s)
Liked 40 Times
I noticed a squeaking noise during pedaling. I checked the bolts that hold the water bottle cages. I have two cages, one on the down tube and one on the seat tube. This is a carbon frameset.
The bolts were loose. I tightened all 4 bolts. Then after a 40 mile ride, it was quiet, no squeaking. Next ride at the 20 mile mark, it squeaks when I pedal. It got louder as I rode. I came back home to check the bolts and they became loose.
I took off the entire assembly. Now the water cages are off and so are the bolts.
Is there an easy fix? Other than to put the water bottles behind the saddle?
Likes For dedhed:
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 58 Post(s)
Liked 72 Times
Likes For Skulking:
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Fondriest Squadra Corse; Trek Y11
Quoted: 482 Post(s)
Liked 282 Times
I was also thinking a lock washer, along with any sort of grease. Even Vaseline might work. Simple stuff first...
Quoted: 1269 Post(s)
Liked 707 Times
Properly-torqued bolts should not loosen up. To what torque did you tighten the bolts? You should be using a torque wrench on a carbon frame.
Likes For dsbrantjr:
Likes For Garfield Cat:
Likes For MudPie:
Quoted: 58 Post(s)
Liked 72 Times
Tighten the bolts to maximum 0.94-1.23 kgf.cm / 0.09-0.12 Nm / 0.81-1.06 in.lbs torque with 4mm Allen Wrench...my mini torque wrench goes up by a factor of 1 Nm increment at a time...I couldn't find 0.09 Nm on there with a microscope
This is a non-critical fitting, bolts go into preset alloy threads in the carbon assembly. So feel tells me when they are tight enough...and about 25 years of experience
I do use a torque wrench for pretty much everything else...Got one, might as well use it
A Roadie Forever
Quoted: 2716 Post(s)
Liked 1,181 Times
My first thought - you did grease the threads, didn't you? There is only one metal-to-metal interface on a bike I don't grease - the flats on square taper spindles and cranks. Everything else get (usually) marine boat trailer grease or whatever is on hand. (Hmmm - not true. I don't grease any of the clamps around the handlebars; stem, brake levers. accessories ... But all their fasteners, yes.)
Metal bottles , plastic cage, plastic bottles, metal cages are fine..
My guess: they used riv nuts.. they expand further into the hole when you tighten the bolt .. if they are loose..
a flat washer against the outside flange (of riv nut) when thread part is pulled up is how they expand..
With a mighty wind
Quoted: 632 Post(s)
Liked 333 Times
Also, if I'm chasing creaks, I definitely lube the handlebar lightly before clamping. Same with seat rails. I've never had them slip.
OP, one drop of blue loctite on the bolts and your problem is solved.
Old fart
You should still use a torque wrench, as the RivNuts for the mounting bolts are usually a friction fit between the RivNut and the frame. Too much torque and they can break free and spin instead of securing the bolt.
Quoted: 413 Post(s)
Liked 320 Times
They make a purple loctite as well. A little harder to source, need to order on line, but that is what Campy speced for my crank bolt.
Quoted: 489 Post(s)
Liked 100 Times
