Go Back  Bike Forums > The Racer's Forum > "The 33"-Road Bike Racing
Interchangeable Cassettes
Old 05-16-14, 12:30 AM
Little5er
Little5er's Avatar
Bikes: Cannondale SuperSix Evo Red
So I will be riding in my first crit next weekend and I have a question regarding wheels for the wheel pit. I'm currently riding on 10 speed SRAM and I have an older 7 speed shimano wheel set from my old bike. Would there be any chance that the 7 speed cassette will work with the 10 speed derailleur?
I'm guessing the answer I will get is no, so if that is the case does anyone know the best place to find a cheap used cassette that I can put on my spare wheel set?
Thanks
Little5er is offline
Old 05-16-14, 03:52 AM
gsteinb
out walking the earth
gsteinb's Avatar
Quoted: 912 Post(s)
Liked 752 Times in 342 Posts
Doesn't sound possible, but if it were at minimum you'd need a longer free body and a longer axel.
BikeRadar.com ? View topic - Cassette compatibility
gsteinb is offline
Old 05-16-14, 07:21 AM
mkadam68
mkadam68's Avatar
Bikes: 2012 MotorHouse road bike. No. You can't get one.
Liked 9 Times in 6 Posts
No. Your shifters are also part of the problem. Changing them on a free-lap would be... time-consuming.
To find cheapest cassettes, I use Google Shopping. You could also try CraigsList for your area. The cheapest cassettes I can usually find are in the $50-60 range. Cheapest SRAM cassette I found (I prefer SRAM cassette's with my Ultegra setup) was one I found at Performance Bikes. It was on a sale. I haven't found it again.
Best solution, though: check at your LBS. Racers should support LBS's so when you need something last-second, they will be more inclined to help you.
mkadam68 is offline
Old 05-16-14, 07:38 AM
globecanvas
Ninny
Quoted: 686 Post(s)
It's not just a matter of buying a new cassette, like gsteinb said, you won't be able to put a 10-speed cassette on the 7-speed wheel.
In other words, you can't use the rear wheel as a pit wheel.
globecanvas is offline
Old 05-16-14, 07:40 AM
spectastic
commu*ist spy
spectastic's Avatar
Quoted: 653 Post(s)
Liked 5 Times in 5 Posts
I got an ultegra 10 speed from ebay for like $55. I bet you can get tiagra or 105 for around $30.
spectastic is offline
Old 05-16-14, 08:26 AM
MDcatV
Quoted: 31 Post(s)
Thanks
front wheel should work, you can just buy a spare rear wheel with a cheapo cassette to use as a backup. aside from just pit wheels, it's good to have a backup to use when needed.
MDcatV is offline
Old 05-16-14, 10:09 AM
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
Gsteinb giving mechanical advice is hilarious. I'm surprised he even knows what a cassette is. He is right about this one, though. Even a blind squirrel gets a nut every once in a while.
Put the front in the pits and pray. Get a spare like MDcatV says. I bought my trainer wheel brand new on Amazon for $75 shipped.
shovelhd is offline
Old 05-16-14, 10:46 AM
Tyrell
Tyrell's Avatar
Quoted: 5 Post(s)
Liked 6 Times in 3 Posts
7-speed wheel won't fit on your 10-speed bike without lots of work. The spacing between the dropouts for 7-speed is less than 10-speed. If I were in your position, I would either borrow a rear from someone for my spare or go without.
Tyrell is offline
Old 05-16-14, 11:18 AM
waterrockets
Making a kilometer blurry
waterrockets's Avatar
Bikes: rkwaki's porn collection
Quoted: 37 Post(s)
Liked 91 Times in 38 Posts
Another option is to replace the hub, nipples, spokes, cassette, and the rim. You should be fine with the same rim tape though.
waterrockets is offline
Old 05-16-14, 12:26 PM
Little5er
Little5er's Avatar
Thanks for all of the tips everyone! Looks like for now I'm going to go with the front wheel and pray...
Old 05-16-14, 07:47 PM
botto
botto's Avatar
Quoted: 15 Post(s)
Liked 27 Times in 12 Posts
will work.
botto is offline
Old 05-17-14, 06:35 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
You can use the 7 speed wheel. After you install it, shift around until you find the least noisy, least skipping gear. Then leave it in that gear.
Homebrew01 is offline
pgoat
Bicycle Mechanics
10
06-26-14 04:22 PM
mstone5
Bicycle Mechanics
16
11-23-13 11:37 AM
nayr497
Bicycle Mechanics
8
05-24-12 09:23 AM
RoboCheme
Road Cycling
2
05-20-11 08:57 PM
jasonball
Bicycle Mechanics
3
12-17-10 02:20 PM
