Bottom bracket swap out
I've been all over the Sheldon Brown site as well as forum posts without success. I was hoping that someone here might have the specs comparison to help me determine if I can remove my current Sugino VP double crankset (and bottom bracket) and replace it with a Shimano double 6700 setup for my Univega Supra Sport frame.
Any help would be greatly appreciated. Thanks.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Univega = English threading 68mm width + 1.37"*24tpi threading
Sugino = square taper BB
6700 = external
So you'd have to swap out the BB as well (which you indicated). But make sure you get a standard English threaded crank/BB setup, not one of the BB30, BB86, or whatever the newest solution in search of a problem is.
6700 = external
6700 = external
6700 = external
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
I've put external style cranks on a couple of bikes that were from the square taper days. Admittedly a small sample of 2, but ran into zero issues - besides needing new tools.
Chainline is set by the crank/BB and the frame would not affect this - excepting some oddball [no-dish] frames and the like. You're putting a road bike crank into a road bike. Clearance should almost never be an issue with an external-type crankset, as there are not multiple spindle lengths to choose from. The spindle is part of the crank itself.
Ex Pres....That was exactly the insight that I was looking for....Many thanks.
...Just a follow up note in hopes that this might help another newbie like myself. The new crankset fit perfectly. So far, this was the easiest upgrade I've made. Had a bit of a challenge readjusting the front derailleur, but all is well.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I was getting ready to reply, to mention that these new cranksets are all designed for 130mm rear spacing, but likely your freewheel isn't quite as wide as the intended modern cassette, so won't cause noticeable cross-chaining noise/friction.
I tend to prefer minimal "chainline" (as it is called, the distance from chainring/chainset center to seat tube center).
I like to make use of the big/big cog sprocket combination with frequency, as when cresting our many rolling hills.
So I usually prefer older bottom bracket designs that give me the freedom to select the chainline dimension at the chainrings.
Very glad to hear your new crankset works well on your older bike though.
How does it look?
How does it look?
