Can I change the bars on a Trek 930?
Can I change the bars on a Trek 930 to swept back bars?
I was gifted with a late 90s Trek 930. I'm not certain of the year but it has front suspension on it. Everything on the bike seems to work well.
I'm not sure what to do with the bike because I already have a decent commute bike and I don't really care for suspension bike in the city. I already know I'm not going mountain biking. Anyhow, I had my dad take a spin around the block on it since he's been asking about bikes. He complained that his back hurt because he had to lean over so much.
My dad asked me to turn the stem around so that it points towards the seat rather than the front...I don't think this is a good idea at all. Anyhow, what I started thinking was to get some bars like Soma Sparrow instead so that it would bring the bars closer to the seat. Maybe a shorter stem too...I'm probably going to have a shop do this for me.
What is involved in changing out the bars and what should I know before I go ask? I'm guessing I might need new cables.
The other thing is whether or not this is a good idea to covert a mountain bike to an upright city bike.
Soma Sparrow bars: https://store.somafab.com/sosp490bar.html
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
Measure the bars at the handlebar clamp with a caliper (probably 22.2 or 25.4), and that will let you know what size bar to find.
Don't rotate the stem backwards.
Also measure the bar itself to ensure compatability of the brake/shifter levers (probably 22.2mm)
Another option is a shorter stem with more rise, or a combo of shorter stem and swept bars.
Quoted: 5976 Post(s)
Liked 2,883 Times
As long as uyou stay with the same basic style, ie upright vs. drop changing bars is very straightforward and simple. The key element is the fit at the stem. This is typically 1" (25.4mm) for a bike of your vintage, and the rest of the bar is 7/8" so things like levers and grips transfer without issues.
While you're at it, you can change stems to a shorter extension, maybe also with some rise. Depending on how and how much you wish to change the position, this may make more sense than changing the bars, or may be done at the same time you change bars.
When you order the new bars, order a set of grips. This will have you covered if yours don't come off without being cut off. Even if the existing grips are OK, they wear out or get cut pretty quickly, so the new ones will be needed soon enough.
FB
Chain-L site
FB
Chain-L site
What's a bike?
Bikes: Bianchi Veloce
You might also look into riser bars if the current ones are flat. That would give you some extra height on the bars but keep the orientation of your hands the same if that is something you are worried about.
Quoted: 1441 Post(s)
Liked 1,095 Times
Two suggestions:
1) Ensure that the frame is not too large for your father. You can mess around with components but it's going to be difficult to make a too-large frame comfortable.
2) If you think you may be needing to fiddle around to get the sizing right you might consider a stem with a removable face plate and/or an adjustable stem.
Liked 1,095 Times
"When you order the new bars, order a set of grips."
Ergon grips,such as the GP-3, -4 or -5 offer additional hand positions and clamp to the bars so that they can be easily adjusted or removed/replaced. https://www.ergon-bike.com/us/en/home#
Liked 2,883 Times
Yes, it's marginally slower than my road bike, but I think that's mainly the result of the upright posture's higher wind drag.
FB
Chain-L site
FB
Chain-L site
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
You will need longer shifter and brake cables and housing when changing out to riser bars or swept back cruiser bars.
My commuter is built from a non-suspension mtn bike. A pair of fat slick tires and it's perfect for the lousy streets on my route. I also don't have to worry about sewer grates, gaps between concrete slabs, or potholes all of which comes handy this time of the year when I'm going home in the dark.
My commute bike is a essentially a rigid 29er with street tires (Marin Muirwoods 29er) so I know where your coming from. Just never considered putting swept back bars on something like this and how well the geometry would work out.
Two suggestions:
Actually when discussing the bike, I'm pretty sure my dad wants swept bars. He told me when he was growing up the bikes would have bars behind the steering axis which I think is why he asked for the stem to be turned around.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
Yeah, just get a short stem and some swept back bars of some sort. Probably change to a wider saddle of some sort. ANd a set of colour-matched fenders. You dad will love it.
