Mirrors
#51
So on the Take A Look mirror....compact or original version?
[insert clever quote here]
#52
I like the Take A Look better than the Third Eye because of the longer arm.
The shorter TAL would have the same mirror but since I don’t always use the same goggle or sunglasses the longer arm gives more “temple room” for mounting.
A shorter arm provides a closer larger image but I prefer the smaller image within my normal line if sight. (if that makes sense to anyone but me)
#53
Quoted: 427 Post(s)
Liked 699 Times
I use a bar end mirror on my road bike. It isn't small, but gives a good view of what is behind. As the first review on the link says, do have to remove the mirror from the mount when you first mount it, and it is a tight fit, but once mounted, works very well and doesn't seem that vibration really bothers it. Inexpensive to boot: https://www.amazon.com/Sunlite-Ce-2-.../dp/B00B13686K
#54
I just got an EVT Safe Zone Bicycle Helmet Mirror. It is, beyond a doubt the dorkiest looking mirror I've ever used. It is also the best mirror I've ever used. It can be easily positioned to give a clear, wide angle view to the rear with just a quick glance. The mirror is large, gives a sharp image, and unlike every glass frame mounted mirror I've tried, it stays put with little or no vibration.
Likes For bmcer:
#55
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
I started using a helmet-mounted CycleAware mirror about 15 years ago and don't know how I ever survived without it. The only deficiency is the adhesive system, but it is easy to replace that with a square of double-sided tape. I had to cut a small notch in my helmet visor to clear the mirror mount. I am very pleased with the whole setup.
Likes For nomadmax:
#57
Quoted: 800 Post(s)
Liked 218 Times
Since Take-a-Look is a favorite brand of many, I just posted to this aforementioned thread, Jim's Famous Trick for Rear-view Mirror Goggles
Note that I have lost a couple of black plastic sleeves on the prongs of one of my Take-a-Look mirrors. That’s about the only drawback of the brand. I have previously posted my remedy:
The Take-a-Look eyeglass metallic rearview mirror has three prongs covered with plastic tubing to secure it to the eyeglass earpiece. Those plastic sleeves slip off the prongs pretty easily and get lost; heat-shrink tubing replacement is much more secure.
#58
Like the OP'er, I ride a drop-bar road bike and I wear glasses. I'm also hearing impaired - mostly in my left ear - so, generally I can hear a nearby car and know to be extra cautious. However, I don't have a sense for what direction car noise is coming from. I've tried five different mirrors in the past three years. Of those, my all-around favorite is a Third-Eye bar-end mirror. It's cheap and cheerful, but the mirror quality is pretty good and it has an appropriate amount of curvature. It helps me spot cars when they're pretty far away (behind me) at just a glance. With it, I can judge overtaking cars' speed and distance quicker and more confidently.
I tried to like an EVT helmet mounted mirror for a year... but I could never get information from it quickly enough. I had to wait for my eyes to focus, and then think about what I was seeing. I think I would have the same problem with any eyeglass or helmet mounted mirror. On my commuter, which has bar-end shifters, I use a Blackburn mirror that straps onto the left-side brake hood. It's okay, but vibrates more than the Third-Eye bar-end. I didn't like the way the D+D Oberlauda mirror mounted. It always seemed in the way of my hands, and it didn't play nice with my bar tape. Also, the Third-Eye is larger and thus more functional than the expensive German mirror.
#59
I use Sprintech bar end mirrors. They do a decent job and installation is easy.
https://www.jensonusa.com/Sprintech-Dropbar-Mirror
I haven't got a helmet-mounted mirror yet, but if I really want to see what's behind me better, it's probably going to have to be something like that.
#60
The Hafny bar end mirror, 68mm, is way bigger and better than the Third Eye bar end mirror. But, I prefer the "Mirrycle Origional", which mounts to the old style brake levers. The Mirrycle is in a better position both for visibility, and not being in the way.
#61
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Finally got around to securing mirror to helmet visor.
Have been using similar mirrors since about 1981.
Likes For JanMM:
#62
Bikes: Carrera Virtuoso and friend
Quoted: 129 Post(s)
Liked 47 Times
I just bought a cheap Bar End mirror and mount it on my bar extensions. Doesn't stick out, and tells me if there's a car behind, when I want to turn right (we drive on the left here) and it saves my ageing neck..
It's well adequate. Would be better mounted higher, or with a stalk, but that would vibrate; as it is, by the time I've finished checking it, I'm usually uncomfortably close to the kerb. . . .
Likes For peterws:
#63
Quoted: 5224 Post(s)
Liked 3,581 Times
had a nice long road ride yesterday. since it was going to be bright & it's springtime I broke out the sunglasses. these have the "compact" Take-a-Look (I think). also, of course made good use of the cheap bar end mirror I got at a consignment shop for $5
took some pics of the setup in case it helps anyone
#64
[QUOTE=bruce19;21357672]Depends on what you like but I use the Italian Road Bike mirror.
QUOTE]
Yep same here, absolutely superb bit of kit. Unobtrusive but really clear, doesn't scratch or distort/wobble. Best cycle accessory I've got, wouldn't ride without it.
QUOTE]
#65
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
I used a couple kinds of 'mount to your glasses' type mirrors. They were OK. I ended up trying a dropbar mounted mirror and much prefer that. This is the one that I use (it clamps onto the very end of my drops and is (barely) not in the way).
dave
dave
#66
Quoted: 1743 Post(s)
Liked 1,281 Times
FWIW the Italian Road bike mirror is glass not plastic.
#67
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
I've been using Blackburn Helmet Mirrors for many years. It's a perfect mirror. I set it so that I have to turn my head slightly to see directly behind me. The only hassle I've had is that it's possible for the sticky-back mounting pads to get weak over time, so I add superglue to the sticky-backs. It's very useful to be able to scan the road behind just by moving my head slightly.
Results matter
Results matter
#69
Quoted: 4806 Post(s)
Liked 3,928 Times
I started this 15 years ago and I've made three. (Three models of helmet.) Why helmet manufacturers and the mirror people cannot talk to each other and come up with a system like mine (that requires a standard and two tiny holes) is completely beyond me.
Ben
#70
Quoted: 10 Post(s)
After four and a half decades of being grumpy about mirrors I got a Take A Look. It wasn't love at first sight (pun not intended), but it's useful and I've made peace with it. Especially good when I ride with my wife so I can keep from getting too far ahead. She doesn't mind it, but I do...
#71
Quoted: 938 Post(s)
Liked 2,941 Times
She encourages me to go on ahead. Sometimes I do, mostly I don’t.
#73
Bikes: Bianchi Infinito CV disk, and rim brake
Quoted: 29 Post(s)
Liked 97 Times
#75
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
I use a take-a-look mirror on my road bike. It attaches to your glasses and is very effective. I don't ride without it...or at least not on the road.
https://takealookactive.com/
