rear derailleur suggestion
Myrtle Beach Crab
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 541 Times
i'm looking for suggestions for a vintage (ish) european brand rear derailleur that will handle 52x42 chainrings and 14-30t 5 speed freewheel combo for my 73 Italvega build. i installed the Soma long cage mod on a campy NR, but it looks weird to me... although to be honest i don't have the 27" rear wheel back from the LBS to install on the frame and see it mocked up. it just seems like the cage is long enough to be a kickstand! i have hangers for both campy and huret to go on the stamped dropout. i don't want shimano or suntour for this bike.
Quoted: 3804 Post(s)
Liked 6,643 Times
Lots of Huret long-cage options that will work well. A long-cage Jubile is super rare and super sweet, but a Duopar would be cool and easier to find. Lots of info here: Huret derailleurs
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,865 Times
Campy Gran Turismo!
Just install it for a few weeks and you'll find yourself warming up to the Soma long cage. Plus, it will come in handy in the event of a zombie apocalypse.
Seriously, though, if you can find a claw hanger with a long enough drop, you might be able to get the NR to work with a 14-30. It sounds to me like you should bite the bullet and consider a triple, though.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 1088 Post(s)
Liked 1,205 Times
Is there any way you can fit a smaller chainring, like a 38? Not sure what BCD you're working with.
You can get a similar low gear with the 38 using a 26- or 28-tooth large cog in back. I've read that the practical limit for a short cage Nuovo Record is 26, but that folks can get it to work with a 28 without too much fiddling. (I couldn't get mine to work with a 28, but I did not try very hard.)
Likes For RobbieTunes:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 977 Post(s)
Liked 626 Times
Just for a weirdness factor, would those long cage sides I've seen fitted to NR's also fit a Galli?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Myrtle Beach Crab
Quoted: 271 Post(s)
Liked 541 Times
i have a TA specialites crankset that is real purdy with (several hours of elbow time invested) earmarked for this bike, so 52/42 is what i'm working with, and my bottom bracket is already in my parts bin for this one, so don't want to invest in more parts for a triple. i have a campy rally but that is destined for a '60 paramount that is getting a triple. i looked on disreali gears this morning and almost for a fleeting moment considered the tourismo but i'm not that desperate yet.
I think the Huret Duopar shifts well and will easily handle that range (and more) but the steel one is heavy and many folks just can't get used to the looks of the thing. A Huret Luxe Touring will shift onto a 30 tooth but have a reputation for being easy to bend. Plus you need to use an older Huret shifter with the larger drum diameter and I believe all of those are steel and consequently pretty hefty. A Simplex (preferably a metal one) should handle that range without complaint.
Myrtle Beach Crab
Quoted: 271 Post(s)
Liked 541 Times
i might consider a jubilee long cage if i could find one that didn't require a second mortgage on the house! or even a campy chorus long cage, but those are rare to find so far as well.
If you don't like the look of the long-cage NR, you can find yourself a v1a/v2b Campy Rally rder. They're Campy, and real purty.
Fuggedaboutit!
Fuggedaboutit!
Bikes: Yes
Liked 3,865 Times
If you're willing to stretch the "ish" in your vintage-ish, an 8/9-speed Racing T derailleur would have excellent functionality, looks pretty nice, and are often available at a decent price.
My Bikes
My Bikes
Likes For Andy_K:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
The problem then becomes taking up the slack between the big and the small rings. Nuovo Record can easily accommodate a 10 tooth chainring difference, but anything more is difficult (given a wide freewheel cluster like 14-28t).
Myrtle Beach Crab
Quoted: 271 Post(s)
Liked 541 Times
have you ever just totally changed your mind about the entire package for a build? i went down to the dungeon last night to look through all my parts bins, and found a velo orange 46/30 crankset i bought last year but never used. got on the internet afterwards and somehow ended up looking over sunxcd stuff in my travels. so now i'm switching to what i said i wasn't doing... suntour pro compe 14x28, sunxcd rear derailleur, shiny microshift front to deal with the range of shifting, and a velo orange grand cru crankset. i like curvy polished art deco and sometimes steampunk looks. besides, the all europe derailleur options were adding up to be more that i wanted to fork out.
thanks everyone for your suggestions. don
Likes For cocoabeachcrab:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
likely no one else has ever done that. yer so weird...lol
Likes For thook:
Liked 1,205 Times
Yep, you’re right... I haven’t used anything but a long cage for my builds, so I forget the delicate calculus of running up to the limit of (or exceeding) capacity.
Liked 1,205 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Liked 6,643 Times
Sounds super functionable and not bad looking, too.
