Best internal routing tool
Bikes: Tcr advanced sl & Protos
Quoted: 116 Post(s)
Liked 60 Times
Which is it? Park, Icetoolz, Jagwire or some other?
Jagwire has no long cables. Is that good or bad?
Thanks
Thanks
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I've been using the Park since it came out. Works well enough most of the time, really well sometimes. Haven't tried any others.
Likes For cxwrench:
Likes For noodle soup:
Quoted: 4802 Post(s)
Liked 3,923 Times
Great headline! I just had a colonoscopy yesterday. Sadly, I didn't ask what brand routing equipment they used. Edit: It incorporated a good light and camera.
Likes For 79pmooney:
Likes For Atlas Shrugged:
Quoted: 20810 Post(s)
Liked 9,456 Times
How many frames do you need to route? If you're doing this for a living, cool, buy the best tools that you can justify. If you're just routing one frame, try some dental floss, a tiny washer and a strong magnet, first.
Likes For WhyFi:
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
Running replacement cables
Many years ago, I posted how to pull a replacement brake cable by sliding thin tubing over the existing cable before removing it. That becomes a guide for the new cable. It's cheap and easy.
It should be good for shifter cables too. This wouldn't work with Di2 cables that have permanent connectors.
From 2014! replacing internal cables
And the linked video is still working.
Likes For rm -rf:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Shop vac and dental floss. Use mint-flavored ribbon.
Likes For Cyclist0108:
bike whisperer
Quoted: 1528 Post(s)
Liked 718 Times
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 116 Post(s)
Liked 60 Times
Normally I’m often making do with less than perfect tools, but now I’m older (47) and I’d like the perfect tool for each job as I no longer want to go to any bike shop.
I bought a wheels bearing press and park tool BB remover. I will likely use them two or three times ever? Maybe a few more. Who knows. I have 3 bikes plus my wife’s so maybe 5 times.
I think I’ve settled on the icetoolz over the Jagwire and cheaper Chinese versions of the ice and park version.
Yeah. I’ll likely not need it much, but I don’t need anymore frustrating and I’m pretty sure I like “wasting” a little money on my bikes and tools.
Likes For Greatestalltime:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
"Best internal routing tool"
Sram eTap HRD... no cabled
Liked 9,456 Times
Likes For WhyFi:
On Your Left
Liked 2,433 Times
Likes For GlennR:
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I have a piece of tubing I run through the frame with the current cable. Then I pull the cable out and the tubing remains and I thread the new cable in the tubing. Then run the housing it is easy and I don't need anything they offer as a tool to do this job. My favorite though is my regular Ti bike that has exposed cables and I just change them in a flash and much to be said for the old way. Once you have the system down for what your bike requires it is at least doable and no need for anything special you cannot make yourself, and no need to see the LBS.
Likes For deacon mark:
Liked 9,456 Times
Quoted: 399 Post(s)
Liked 185 Times
Yeah, once something is routed, it's easy to fish subsequent wire/cables/hoses/guides through - just don't be a dummy and yank something out without thinking ahead - but I assume that were were coving the starting-from-scratch scenario, which requires tools and/or ingenuity to avoid frustration.
Actually for me that is not all the difficult either but I assume that can be bike specific. In my case I repair guitars for a living and they are 100 times more difficult to work on that bikes, so I have guitar strings I use to thread a bare frame. A guitar string of .22 gauge wire will poke in a straight line and generally go through the frame. Once I have that in I am good to go since it now is like any other cable. The guitar string even bigger gauges work well as they don't deform and bend like cables, or as much. Really it is bike specific to get a plan but the tool I assume is useful and depending on your needs buy one. I made my dish tool also but if you do a lot of wheels the park is nice.
I got the Park tool cable puller for my Di2 rebuild and a bike build I'm doing for my wife. It made the cable pulling super fast and easy so I was satisfied with spending the money on it. I'm sure there were cheaper or diy options out there but I've been happy with my other Park tools and it was readily available on Amazon with next day delivery for me along with a few other things I needed for my build.
Likes For RandomDesign:
bike whisperer
Liked 718 Times
If you think about it, starting from scratch shouldn't happen. Even on a brand new frameset, you should be getting it with sleeves in there, and if somebody's stripped it, they'd either be a dingbat or a scumbag to not at least run string or something when removing the cables.
If I'm buying an internally routed frame, I'd be checking that and negotiating accordingly. It's not the quarter hour's labour, but the cost of the damn tool you shouldn't need.
Not that I'd buy it rather than spend half an hour without it, but you know, it's the principle.
Likes For Kimmo:
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,984 Times
I have the original park IR.1 kit and it works just fine, the new one is a bit nicer with the Di2 routing stuff but my Di2 bike is already routed and if we had something at the shop I would probably leave it to one of the mechanics or just use one of their tools if I had to do the wrenching.
The Jagwire tool looks fine but I think the Park one is the best and probably the most useful out of all the ones I have seen.
Likes For veganbikes:
Quoted: 2432 Post(s)
Liked 638 Times
I bend the tip of the cable at an angle, about the last inch. Then I slide it through the frame and twist the cable when the tip is near the hole. It finds the opening pretty quickly on my bikes. But I personally do not like internal routing.
