Campy NR hub 6 speed spacing question....
Bikes: 1975 Motobecane LeChampion (silver lilac), 1974 Motobecane Grand Jubile (red/black); 1975 Motobecane Team Champion (orange); 1982 Pinarello Professional (Exorcist Green); 1974 Raleigh Professional MkIV mink blue, 1974 Motobecane Grand Record blk/red
Quoted: 103 Post(s)
Liked 749 Times
I'm setting up a rear hub for 6 speed spacing (Raleigh Pro), which should be right at 126mm between the dropouts. My axle length measures around 134.3, and my locknut-to-locknut distance is about 126.5. That leaves just short of 8 (7.8)mm left to be split between drive side and non-drive side (about 3.9mm each). Question - is ~4mm wide enough to be safe in the dropouts? Thanks for any advice....
Quoted: 1106 Post(s)
Liked 1,327 Times
4mm is ok IF your QR's are tight[1]. More would be nice, if the frame is at all narrow I'd be taking out the washers.
[1] Really tight (they should be anyway).
Likes For oneclick:
Quoted: 3464 Post(s)
Liked 2,829 Times
If you were north of 200# then buy a new axle, Wheels mfg are good.
Quoted: 103 Post(s)
Liked 749 Times
Thanks for the advice ... I might take out a washer to get an addiional ~1mm on both sides.... I think I should be OK on the axle, I'm a bit less than 150lb
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
What's Sheldon say? 2-3mm of axle outside each locknut is plenty long enough.
Personally I like 4-5mm. It gives me the warm fuzzies.
What's also important is that my rear cluster has exactly enough room for the chain to clear the stays when it's on the small cog and big ring. So I have to fit the freewheel, derailer and chain before I'm comfortable making the final adjustments to the hub spacing and wheel dish.
Quoted: 103 Post(s)
Liked 749 Times
Good advice SurferRosa, I agree. I did check Sheldon, and it just would not make me comfortable riding to have that minimal amount under the dropouts....
I'd expect a Campy 6 speed hub to show 125 mm OLD, not 126.55. How accurate is the micrometer?
Bikes: 1981 Colnago, 1984 Bob Jackson, 1985 Benotto
Quoted: 103 Post(s)
Liked 749 Times
Ironically, just after reading Repechage's note above about replacing the axle (though I am well south of 200 lb), I slide the QR through the axle and it bound up. Turns out this axle came to me already slightly bent. So, I bought a new Wheel Industries axle - I was fortunate to find a 137mm, which is a bit longer than the original Campy, but does leave a bit more on the ends, so that was good.... Thanks !
