Hey Miyata people, help me out!
Bikes: 1991 Diamondback Interval TG
Quoted: 14 Post(s)
Hi,
I just came across a NOS 1999 Team Miyata in my size and I'm buying it!! I could go on and on about how excited I am, but there is one piece I'm not thrilled about. The Team Miyata from that year has an aluminum fork. I'm sure some might feel it's lame to think about switching it out for steel or carbon, but it's crossed my mind. So, what would you do?
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
I have never seen a 99 Team Miyata. Can you post some pictures?
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Ride it and see if I like it.
Quoted: 2323 Post(s)
Liked 4,988 Times
Yep, ride it first and see how it feels. The aluminum one on my 1999 Schwinn Circuit was harsh unless the road surface was perfectly smooth, the one on my Vitus Argal was downright scary at speed because it felt vague and was all over the place. The one on my Bridgestone Mile 112 was divine. Solid and precise yet not too harsh on the rough chipseal.
You can't expect them all to be the same or to ride like junk. You need to ride them and see how it works for you and your style of riding.
Steel is real...and comfy.
Likes For jamesdak:
Quoted: 14 Post(s)
Yep, ride it first and see how it feels. The aluminum one on my 1999 Schwinn Circuit was harsh unless the road service was perfectly smooth, the one on my Vitus Argal was downright scary at speed because it felt vague and was all over the place. The one on my Bridgestone Mile 112 was divine. Solid and precise yet to harsh on the rough chipseal.
wow i had no idea there was that much variance between those forks, thanks for the input.
Quoted: 659 Post(s)
Liked 595 Times
I have an ‘88 Cannondale Criterium with an aftermarket Sakae FX Litage aluminum fork. On busted up cracked asphalt it is a bit rough but I’m rather used to it. On new pavement nothing compares to the road feel I get, very smooth and controllable.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
I'd say ride it and consider adding a carbon fork later. You're the one riding it and I have heard many people enjoy the change on a vintage steel frame.
If they made compatible touring forks with discs I would even consider it on some of my bikes.
Quoted: 236 Post(s)
Liked 171 Times
Hi,
Quoted: 4722 Post(s)
Liked 3,036 Times
Agreed, you really should ride them for an extended period of time to see if you like them. They appear to be from Tange's Fusion series.
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
Quoted: 581 Post(s)
Liked 921 Times
WHat exactly is your concern? Miyata is/was a reputable and highly regarded builder who sold many thousands of bikes. What makes you think they made a mistake on this bike?
Quoted: 14 Post(s)
Just don't see much aluminum on road bike forks is all. Based on steel and carbon fiber being used so much more I tend to think they're better for the task, but I'm no expert on this.
Quoted: 188 Post(s)
Liked 997 Times
Suddenly I had this thought...., maybe heard about 'the death fork'? In that case, do not worry. Only Viscount and Lambert had these, for a short time.
Quoted: 581 Post(s)
Liked 921 Times
Bikes were primarily steel from ~1880-1995 or so. THis was just the traditional method for constructing frames and forks. By 2000 or so, steel was much less common and Aluminum was more popular in frames and forks, but not long after, carbon forks became the standard. I think this was as much of a marketing decision as anything else - a carbon fibre fork on an otherwise mundane bike seems like an upgrade. The truth was, however, that many carbon forks only had the mid part of the legs made from carbon and the rest of the fork - steerer, crown, top part of legs, and dropouts, were aluminum.
Quoted: 236 Post(s)
Liked 171 Times
Yep, you definitely have a '93. Very nice Miyata 'STB' tubing with, unfortunately, a crappy aluminum fork that Miyata switched to in the early 90s to save money. Personally I'd try to find a late 80s/early 90s Japanese steel fork to replace it with. You can find out what they looked like in the late 80s miyata catalogs.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Here is the 1993 Koga-Miyata FullPro which, if I'm not mistaken, is basically the same frame. That year came with an Alfrex Alloy 6000 A.P.A. bonded fork with partial polishing.
The scan seam is unfortunately right around the top of the fork but the similar models all have the same fork and look exactly like yours.
Pretty sweet splined triple butted chromoly frames and probably came with 8-speed Dura Ace groupset.
Check out the Koga-Miyata thread for more info and specs.
Now that I have read about the bonded fork I am even more inclined to replace it. It was a cool technology but after almost 30 years that epoxy can have a tendency to fail.
Pretty sweet effect with the polished and clear coated aluminum though. Looks a lot like chrome socks.
Quoted: 1609 Post(s)
Liked 2,590 Times
A lot of the bikes were using aluminum forks in the early 90's. Maybe people just didn't trust the carbon option? I wouldn't hesitate putting one on.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
The fork on this Miyata is very likely a bonded aluminum fork. At the very least I would suggest checking the sharp edges for cracks in the paint, which can indicate the epoxy failing.
Liked 3,036 Times
This definitely isn't 1989, as it has the fastback stays and vertical dropouts that first appeared circa 1993. Miyata was definitely still in business in 1999, though they had closed their USA sales/distribution division by that time. We still had them in Canada in 1999 and they were also available in Europe (as Koga-Miyata). There may have have been some USA dealers that were independently importing Miyata.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I've never seen any statistics suggesting that bonded forks from Tange (I believe the world's largest and most-trusted fork manufacturer for many years) were less reliable than steel forks.
And I've heard of no tendency for good bonded frames/forks from the early 90's to suffer higher rates of failure than steel.
I've re-bent crashed aluminum forks and can tell you that they were very strong in terms of the force required to re-bend(!!!), and that no failure of bonding ensued.
Just like forks made from steel or from carbon or from carbon/aluminum, a fork can be made more or less noodly than an average fork.
Aluminum forks saved about a half-pound in most cases versus a steel fork, hence their popularity!
Miyata certainly knew what they were doing when it came to making quality frames/bicycles, made rather few mistakes over the years though I seem to be recalling one early-90's model, a few of which suffered top tube failure at the rear cable port(?).
Likes For dddd:
Quoted: 1088 Post(s)
Liked 1,205 Times
OP -- yes, just ride it and see what you think first. I've fallen victim to upgrade fever before, but you're starting out with an excellent bike, so I would start with the bike as designed first.
Quoted: 1561 Post(s)
Liked 1,734 Times
I replaced the aluminum fork on my Performance Focus bike with a carbon fork, and it improved the ride significantly.
Having said that, I think the first thing to try would be to switch to 28mm tires (or whatever widest tire will fit in the frame). That will probably soften the ride enough to make it acceptable. CF seatpost and handlebars also help soften the ride.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Then again, that's on the frames with carbon/titanium tubing in cast aluminum lugs. The different materials almost always mean some oxidation occurs over time and the frame fails. It's usually the aluminum. Technically the epoxy isn't the bit that fails. It's the layer underneath that it is bonded to.
I think aluminum is a wonderful material but I have broken enough aluminum parts that I am wary about it in certain applications and I sure as hell wouldn't bend it back.
I have had handlebars, cranks and forks fail suddenly without warning. Fortunately the crank was the only one that failed catastrophically but even that one nearly killed me. The handlebar just folded over when I pulled my bike from the rack and I noticed my fork was broken when my wheeel was at a weird angle when I stopped at a traffic light.
Anyway, I am going off-topic.
OP check the fork for frame damage. If it's clear it will probably be a wonderful ride. Otherwise there are tons of excellent options for carbon forks and from what I've heard
