Maillard 700 Compact 7-Speed - Overall Width?
Old 02-14-24, 09:05 AM
BertoBerg
BertoBerg's Avatar
Bikes: '72 Peugeot PX-10, '09 A. Homer Hilsen, '78 Masi Gran Crit, '79 Echelon Spectra
Quoted: 104 Post(s)
Liked 163 Times in 101 Posts
Hello All-
I'm looking for a favor. Would anyone with a Maillard 700 Compact 7-speed freewheel be able to measure the overall width?
Thanks!
BertoBerg is offline
Likes For BertoBerg:
Old 02-14-24, 02:21 PM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2608 Post(s)
Liked 1,703 Times in 937 Posts
Originally Posted by BertoBerg
Hello All-
Thanks!
I only have a wheel with a Maillard 700 front hub and, what I assume to be, a corresponding Helicomatic rear. IIRC- the freewhee/cassette thing was only 5 speed...
Just giving you a bump towards the top because that Maillard 700 stuff is so nice.
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Likes For The Golden Boy:
Old 02-14-24, 02:53 PM
CMAW
Pining for the fjords
CMAW's Avatar
Quoted: 130 Post(s)
Liked 446 Times in 151 Posts
Thickness of the first 2 cogs is 10 mm, spacing 2,9 mm.
from this site, Maillard freewheel bible: https://www.muzarde.com/les-pignons-...rd-aris-ircos/
CMAW is offline
Likes For CMAW:
Old 02-14-24, 03:22 PM
BertoBerg
BertoBerg's Avatar
Quoted: 104 Post(s)
This is great! Thank you.
Old 02-14-24, 09:28 PM
Andrew_G
Quoted: 58 Post(s)
Liked 133 Times in 66 Posts
Hello All- I'm looking for a favor. Would anyone with a Maillard 700 Compact 7-speed freewheel be able to measure the overall width? Thanks!
I don't have a Maillard 700 compact 7 freewheel, but I did measure two brand new Sachs Aris 7 speed freewheels (gold cogs). I put each freewheel face up on a table, and measured the height top to bottom. I get about 35.5 - 35.6mm. The inner (fixed) part of the freewheel is recessed on the back face's flange by about 1.1mm. So, I'd count the effective installation width as around 34.5mm.
I have a similar but older Sachs 7 freewheel with all gray cogs. I use an 8 speed Wipperman chain (804 or 808) with either 7 or 8 speed freewheels. When the Sachs 7 FW is installed on a Campy NR hub spaced to 130mm, I get about 3mm of clearance between the outer face of the chain and the inside face of the right dropout. My NR hub is using the standard 8mm thick locknuts (Campy part 33/8) on both left and right sides. If I installed a thinner 33/6 locknut on the left side, and added additional spacers on the right, I could fit an 8 speed freewheel in a 130mm rear end. I did that years ago, as I recall, but I haven't tried it lately.
I'll add that the 33/6 thinner locknut (which looks very similar to the standard 33/8 part) was probably added (my opinion) to the Campy catalog to accomodate wider freewheels. As such, it's a likely useful item to have to fit a 7 speed freewheel into a 126/127mm rear end. Distributor Euro-Asia still shows the part listed on their website:
https://www.euroasiaimports.com/prod...-966p21985.htm
Andrew_G is offline
Likes For Andrew_G:
