Dynohub/Light Switch
Anyone here have any good ideas on a simple in-line on/off switch for dynohub driven light? So many lights have no switch. I have been looking at micro switches and auto switches. Any pics of your solutions?
Quoted: 3465 Post(s)
Liked 1,470 Times
I am not aware of any dyno powered headlamps without a switch except the very old Lumotec lamps that were intended to be attached to sidewall generators. What headlight are you talking about that lacks a switch?
A vintage Royce Union and a more modern Lumotec. Neither has a switch
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
I use handlebar switches just because they allow me to change the status by moving a finger, not risking a mishap by leaning to the light or stopping. I search for the switches on Ebay using keywords "Triumph", "Lucas", "replica". Examples of those I might use are lined below:
https://www.ebay.com/itm/401985543142
https://www.ebay.com/itm/151558702607
Lumotec 2 on left, RU on right
Liked 1,470 Times
I have no suggestions for a switch, I think that 2_i has the right idea thinking of a motorcycle high low beam or turn signal switch as those were designed to work in the rain.
Is it that important to have the ability to turn the light off?
If your Lumotec looks like the one in the photo and lacks a switch, it was intended for use with a sidewall generator. I picked up a used dyno wheel for $20 for my errand bike. I had the light in storage, so it made sense to use it. I do not need a switch on that bike, I just leave it turned on. That was the easiest wiring job I ever did, the hub and light are both grounded to the fork, so I only needed to run one single conductor wire that was less than a foot long.
Liked 1,470 Times
Now, on a bike tour, my dynohub is only used for battery charging, dyno powered lights are off. If I use my S&S coupled touring bike for a tour and flew somewhere with the bike, I do not even bring dyno powered lights, I only use battery lights on those trips.
When riding near home, exercise rides, randonneuring, I leave the lights on for the same reason you do.
My point is that I almost never use the switch. The only time I use the switch is if I have been using the light and my GPS batteries are getting low, I will turn off the lights so I can instead use the power to top up the GPS batteries.
Randomhead
Liked 3,706 Times
Velolumino and Rene Herse both offer light switches. Not inexpensive.
I just leave my lights on. Granted, I'm not using a 20 year old light.
