Bicycle MechanicsBroken bottom bracket? Tacoed wheel? If you're having problems with your bicycle, or just need help fixing a flat, drop in here for the latest on bicycle mechanics & bicycle maintenance.
Typically, NDS will range between 50-70% of DS tension, depending on #cogs & hub/rim geometry & width between DO's.
IF they were the same, you would have a symmetrical wheel like a non disc front.
IG hubs will be closer to (if not) symmetrical.
No. The non drive side should be considerably looser. Spoke calculators often give the relative tensions. 100% drive side/45% non drive side is common. On a rear wheel.
