Sram GX crankset 2021 to SM BB52 Shimano
Quoted: 714 Post(s)
Liked 800 Times
No. Since you asked about the SM BB52, I assume you have the GXP version of the GX crankset, so you need a GXP bottom bracket. The GXP spindle is 24mm on the drive side and 22mm on the non drive side, so it won't work with a Shimano or any other bottom bracket that has 24mm bearings on both sides.
Is there a way that the forum can disallow postings until the new person has first made a post in Introductions? This place is meant as a watering hole, not an encyclopedia. This is gettin' ridonculous.
Likes For BlazingPedals:
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
No it does not if you look up your crank with Google, Alta Vista, Ask Jeeves or whatever search engine you prefer you will find a plethora of information. I looked up sram gx crankset bottom bracket on the Googles and it got me here: https://www.sram.com/en/sram/road/pr...levancy&page=1 which gives me compatible bottom brackets for SRAM cranks and if I need something else I can search for it.
Likes For veganbikes:
Quoted: 850 Post(s)
Liked 344 Times
If you have a 2021 GX Eagle crankset, it's most like a 28.99mm DUB spindle, which will definitely not fit a shimano BB. If you have a BB52, you have a threaded BSA shell and would thus need a DUB BSA bb.
