Shimano XTR Brake Bleed - first time. Suggestions?
So I decided to bleed my brakes! Previously, I figured that I would leave this job to the shop, but I had a change of heart after watching some YT videos. I found this one to be informative:
Brake lever level with the ground, whereas some rec 45 degree angle.
Anyone have a favorite bleed kit? I found one on ebay that's complete for $28. Looks like some places are charging nearly that much for the Shimano syringe - which seems excessive. I had no problem unscrewing the 2.5mm reservoir bolts on the lever.
The brakes are currently very squishy, almost no stopping power. Bike has not been ridden in a good 18 months, except for a spin last week.
If you have any tips to add, favorite kits, etc... please let me know, thanks!
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
A threaded Leur lock for the syringe is ideal. You can use any disposable syringe. Just buy a few from your local heroin addict.
You may be able to get away with just topping off the fluid rather than bleeding it.
Use authentic Shimano mineral oil. Don't get any on the pads.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You might want to try just burping the lever first. If it's been over a year since they were bled or they've never been bled do the full bleed. Fluid will probably come out grey/black so you'll know when you've purged it all. I ALWAYS finish w/ taking the syringe off/closing the bleeder screw and just pumping the lever w/ the cup attached. You'll get some small bubbles out that way. I also change the angle of the bike or rotate the lever a bit, that helps get any stubborn air out of the lever.
Likes For cxwrench:
Likes For Canker:
You keep the lever rotated (guessing around 45 degrees) throughout the process? I will employ your method of squeezing-pumping the lever with the funnel screwed in, the final step.
Here's the Bike Radar video:
Bikes: lots
Liked 2,932 Times
I'd give that video 3 out of 5 stars.
If you're going to 'bleed' then no fluid in the cup. Push fluid up from the caliper as he does. I rotate the lever so that the cup is flat when attached. This minimizes the chance of spilling. Push fluid up from the caliper. I tap the hose a few times while doing this as he does. Once you have some fluid in the cup it doesn't matter if you pull the lever. I push at least half a syringe of fluid up the line then close off the bleed screw. Remove the syringe and then you can burp the lever/master. I will change the angle of the bike in the stand a couple times while I'm doing this, or you can just rotate the lever back and forth. If I get more than a few small bubbles I'll strap the lever down tightly for 5-10mins and let the pressure do it's thing. This should give you fresh mineral oil all the way through the system and result in a very firm feeling lever.
Yes, the fresh fluid is pushing the old fluid into the cup. If you're just going to burp the lever always start with a little fluid in the cup, you won't be able to see the air bubbles come out if you don't.
Likes For cxwrench:
There's two basic strategies for Shimano, top-down or bottom-up. The Park video is the bottom-up strategy. The official Shimano procedure is a top-down, which doesn't require the syringe, just something to catch the fluid on the bottom. For top-down, you fill the cup with fluid and let it drain through. For top-down, you must NEVER let the cup run out of fluid or you'll suck air in.
Bottom-up theoretically pushes air up to the lever on the top and out, making it easier to get a clean bleed. The challenge is that if you aren't super careful you can introduce an air bubble when you connect the syringe.
Top-down is a little simpler if you just want to quickly burp the brakes.
There are pages of internet wars debating these two strategies. Pick the one that seems the most reasonable to you.
Likes For gsa103:
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
My favorite is the BKM-1 from Park Tool it feels nice in the hand and makes bleeding easy. The Park video on bleeding is pretty sufficient.
Bikes: lots
Liked 2,932 Times
Important to position the bleed valve at the lowest point? This is mentioned in some videos....supposedly it helps push all of the air out.
I bled my front brake, don't think I did an A job, more like a C or D.
Bikes: lots
Liked 2,932 Times
Yes, the bleed valve/caliper should be as low as possible even it means removing it from the frame. Lever obviously at the highest point, rotated to a horizontal position. If you did that poorly you should do it again til it's solid.
Likes For cxwrench:
