135mm wheel from a 130mm?
Bikes: (shortlist) Cyclops, Marinoni, Mariposa, Air Firday, Pocket Rocket Pro, NWT, SLX Fuso, Claude Pottie (France) x3, Masi Team 3v, Lemond Zurich, Bianchi OS
Quoted: 168 Post(s)
Liked 34 Times
Annoying me again.
Last question. [and completely unrelated to bottom brackets! :-) ]
but I would really like to move along a build I've be procrastinating on for months - a Rivendell Sam Hillborne.
I thought I was all sset to go with parts when a Rear Wheel hurdle arose.
I have DOZENS of wheelsets, all 700c but also all 126 or 130mm spaced for road bikes.
this SH frame apparently was originally speced needing a 700c 135mm spaced rear wheel
I have none.
A) why might Rivdendell have speced a 135 700c wheel?
B) can I convert one of my 130mm spaced rears to 135mm - swap out the axle and add some spacers?
I really just want to get it on the road to see how it feels. If it amuses me, I'll then invest in some better, appropriately spaced wheels.
Peter
I have none.
Peter
Quoted: 6195 Post(s)
Liked 4,810 Times
Might want to ask them too. https://www.rivbike.com/products/fra...hillborne-2020
Maybe just standardizing for if someone wanted disc brakes added to the build.
Quoted: 1944 Post(s)
Liked 2,164 Times
Sure. There are a couple of ways to do this.
You can add 5mm to the NDS, but that also means re-dishing the wheel and whether you have enough spoke threads to center it.
You can add 1-2mm of washers on DS and the rest on the NDS so less re-dishing is needed.
You can find a happy medium and make the OLD 132.5mm and just close the dropouts in a little more. A number of frames were made with dropouts at 128mm to accommodate 126mm or 130mm. And some frames were made with 132.5mm dropouts to accommodate 130mm and 135mm.
John
Edit added: I hadn’t considered using disc brakes and how that works with NDS spacers.
John
Really Old Senior Member
Get a 5mm longer axle and add 5mm of spacing to the drive side. EDIT- Make that NON DS.
Redish by tightening the NDS spokes. 1/4 turn and recheck for centering between the DO's. Repeat if needed.
Don't touch the DS spokes. The amount of tension you add to the wheel will be negligible and DS has MUCH less effect on dish anyway.
The redishing is the easy part, assuming your nipples aren't frozen.
This will be about 1/2mm of length on the NDS spoke.
That's the CORRECT way to do it. It also makes the wheel stronger since it reduces dish.
Adding spacing to the DS might give RDER travel issues and won't be "as strong" of a wheel that you could have.
Quoted: 4206 Post(s)
Liked 3,870 Times
135 was likely chosen because there's more options for hubs/wheels that are more along the lines of the bike's intended uses. It also results in a stronger wheel as already mentioned. Some of us have been doing this with our otherwise road 700C bikes for decades. Andy
AndrewRStewart
AndrewRStewart
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Quoted: 168 Post(s)
Liked 34 Times
thank you for all your help.
I was able to steal a longer axle from a MTB wheel and retrofit one of my 130mmOLD 700c wheels.
seems to work.
Later I'll work on the redishing
many thanks all
seems to work.
many thanks all
I thought that Rivendell spaced their frames at 132.5 mm at the rear so that you could use either 130 or 135. Sorry I found the latest chart that shows 135 spacing.
Quoted: 3240 Post(s)
Liked 2,086 Times
I would take the bike to a decent LBS and have them bend the rear triangle to 132.5. At that spacing you could run 130 or 135 anytime.
I said to add the spacing to the DS instead of NDS, which was incorrect.
