Replacement Trek head badge screws?
I’ve lost the small brass machine screws used to attach the screw on head badges. Anyone happen to know what size I need to pick up?
Quoted: 887 Post(s)
Liked 335 Times
Probably #2 x 1/8. McMaster Carr has them, but you'll need to buy a bunch. I have had no luck finding them at local hardware stores. You may want to try a local LBS that has been in business for a long time as well.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
https://www.fasnetdirect.com/refguide...rewthreads.pdf
You can try by measuring the hole.
Tap and Drill Size Chart - American Fastener Technologies Corporation
I don't know about Trek but I have used both 4-40 & 2-56
If you can't find them in a "Good" hardware store try a gunsmith
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Yes, they're #2-56 x 1/8". I bought longer ones at Ace Hardware and cut them with a dremel cutoff wheel.
Awesome, thanks everyone. I’ll check out my local Ace tomorrow.
Looks like they only go to 4-40 at my local Ace. Looks like I’ll be ordering some.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
At my local Ace, the "miniature" hardware is in a separate selection kit.
With that said, one advantage to ordering is that you can order the correct slotted-head brass screws. Ace only has stainless Phillips-head.
I saw the correct size stainless, but really wanted to stay with brass.
On that note, if anyone needs a few of these let me know.
Digger Goreman
General Cycling Discussion
10
07-13-19 06:46 PM
thirteenthcor
2
07-29-18 02:10 PM
