Classic saddle bag for a slightly-too-tall-for-the-rider bike?
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
I recently built up a 58cm frame for myself, which is right at the limits of what I can stand over, but it was free and had the right top tube length. As a result, I only have about an inch and a half of seatpost actually showing. I've been borrowing a Carradice Carradura Maxi bag from a friend, but the dimensions aren't quite right for what I'd like, and I was thinking about something more along the lines of the Carradice Junior/Barley or Minnehaha Medium bag...but will those work for me without needing a Bagman style support? I'm using one of the Origin8 leather saddles with bag loops like a Brooks.
What??? Only 2 wheels?
Quoted: 1225 Post(s)
Liked 657 Times
That looks like a pretty nice bike. As for the bag, I'm not sure what your criteria are. But if you are worried about clearance, if the bag hangs from the saddle the clearance above the wheel would be more or less the same regardless of the frame size. The wheel is what it is, and with a different frame you'd run the saddle to more or less the same height above the BB.
Real cyclists use toe clips.
jimmuller
jimmuller
You have a quite modern setup. Why not try a Fairweather seatbag:
FAIRWEATHER SEAT BAG by FAIRWEATHETR
Sunshine
Quoted: 11097 Post(s)
Liked 7,693 Times
A minnehaha medium bag may drop too low and hit your rear tire Itll connect to your seat post just fine as that strap is high up on the bag
Fyi- the minnehaha bags thread thru the saddle rails and not the bag loops.
I have a minnehaha small bag on a brooks saddle and its funky that the saddle loops arent used.
Quoted: 248 Post(s)
Liked 27 Times
Quoted: 248 Post(s)
Liked 27 Times
Bikes: 2014 Cannondale Synapse Carbon 4 Rival; 2014 Cannondale Trail 7 29; 1972 Schwinn Suburban, 1996 Proflex 756, 1987(?) Peugeot, Dahon Speed P8; 1979 Raleigh Competition GS; 1995 Stumpjumper M2 FS, 1978 Raleigh Sports, Schwinn Prologue
Quoted: 213 Post(s)
The Barley will fit just fine. Mine seems to connect just under the saddle no matter what bike it is on. Never used the support.
Quoted: 248 Post(s)
Liked 27 Times
Awesome, thanks
You do as you like. But as said, your build looks modern-vintage and race. Carradice is much more old school and your ride will almost look like a vintage tourer. Carradice bags are wide and therefore not streamlined, the new saddel bags builds longitudinal and will therfore be "faster" and never touch you thighs.
Quoted: 248 Post(s)
Liked 27 Times
Bandera
3
04-20-13 03:44 PM
neocaligatio
Classic & Vintage
18
06-30-11 11:10 PM
pallen
Commuting
9
06-02-11 08:16 AM
