Advice for mudguards on cyclocross
I have a cyclocross bike that I've put thinner tyres on for commuting (around 25mm). However, I'm now looking to install some mudguards (aka fenders in the US). I'm pretty sure I can install them on the back wheel, but the front fork is looking troublesome.
How will I fix the mudguard to the forks when there is very little there to fix them to?
The forks look like this:
https://tedscycles.com.au/image/cache...-1000x1000.JPG
Any advice is gratefully received.
TIA
Adam
TIA
Adam
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
you should look on the inside of the fork for fender mounts or down near the axle.
Quoted: 95 Post(s)
Giant TCX SLR2? From the pic on the website, there is a fender eyelet by the thru axle, but I'd be concerned about mounting under the crown. I'd look at something like an SKS raceblade.
You don't get as much coverage as a full fender but it may work out.
Yea Having over shot the mark for a commuter ^^ something like that is your best Option ..
You could also shop for another bike not so CX Race Focused that has Fittings for Mudguards and a rear Rack
to be a More Practical as a Commuter..
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
As mentioned above:
Wiggle | SKS Raceblade Pro | Mudguards
Might work if the fender doesn't have to be anchored to the top of the fork.
Non omnino gravis
Bikes: ...a few.
Liked 409 Times
Not sure about MK3's, but MK2's need to be anchored to the top of the fork as well, but using small zip ties. I was also think that it could easily be done with fork OP mentioned using some such ties.
Quoted: 2952 Post(s)
Liked 3,106 Times
Zipties always work.
Real Men Ride Ordinaries
Quoted: 17 Post(s)
Fork Crown Daruma
Velo Orange makes something that might work called a Daruma. If you have any sort of a hole you could use this.
I swear I've heard of people just shoving a cork up the fork crown and mount it to that.
