No way to remove this pedal cap non-destructively I assume?
Quoted: 45 Post(s)
Liked 12 Times
Rat trap pedal from a 1982 Motobecane. My assumption is this isn't designed to be user-servicable?
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
It looks like it may just pop in to the pedal. What I would try is a knife blade in between the cap and body and give it a tap like you're opening a watch case.
Quoted: 803 Post(s)
Liked 2,984 Times
"My assumption is this isn't designed to be user-servicable?" doesn't mean you can't try.try prying where the taper ends,could be a interference fit.
Quoted: 4205 Post(s)
Liked 3,863 Times
IIRC these pedals have their end cap pressed on. A fine edged tool might pry the cap up a bit and then a slotted screw driver could do the rest. I suspect you'll find the bearings are common cup and cone and can be taken apart for servicing. The usual challenge is on reassembly and how to trap the cone from turning while the lock nut is tightened down. I would consider a non take apart flushing with solvent then injecting with grease. It's easy to drill a tiny hole (in the cap) and use a needle tip on a grease gun. Andy.
AndrewRStewart
AndrewRStewart
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
Raleigh71-
You may be able to pry the cap off with a fine blade but you will likely find a cup and cone bearing assembly with the end of the pedal axle peened over to hold the cone in adjustment instead of a lock nut. Good luck with this.
Likes For bertinjim:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Likes For JohnDThompson:
Quoted: 45 Post(s)
Liked 12 Times
Thanks for the info, gents!
I tried prying it apart with a box cutter blade and I could tell the blade was going to fail before prying it open. I'll try again (carefully) with something a little more resilient. Sometimes leaving it alone is the best move.
Quoted: 1324 Post(s)
Liked 927 Times
If you do manage to get the dust cap off and discover that the spindle is peaned over making the bearings non-removable, you might be able to lubricate them with a very heavy oil or with a light oil mixed with some grease. I put the mixture into a syringe (from the surplus store near me) and inject the oil/grease mixture into the pedals.
Cheers
Cheers
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times
You can get grease in there like you do a bearing, put the grease around the seam and push it in with your fingers...I have put an abundance grease on the seam and hit it with a quick pulse of compressed air...seems to work.
r
r
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
I've wondered if any types of grease will melt at low heat, so they can be poured into tight spaces, then re-harden back to grease when they cool down.
SE Wis
Liked 3,395 Times
On non serviceable things like this (or don't feel Iike taking apart) I use these type of products. Sprays in as a liquid and sets up as a grease.
https://www.northwoodstm.com/lubrica...oof-lubricant/
https://www.1stayd.com/penetrating-g...x13-25-oz-case
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
There's a lot of products that are aerosols that deliver grease in a volatile solvent, which achieves similar things to trying to melt grease with high temperature and is not so cumbersome. Spray these products into the bearing as a psuedo liquid, and the solvent evaporates off. I'd probably want something with moly disulfide in it. So in addition to dedhed's suggestions, here's another
https://www.amazon.com/Lubriplate-Re...6952439&sr=8-2
The downside to the product I suggest is that its expensive. So dedhed's suggestions may be better (cheaper, just as serviceable).
