Unknown (Italian?) pedals
Quoted: 226 Post(s)
Liked 258 Times
Tried searching velobase for info on these. Not a single word or logo anywhere on the pedals, even the spindles when I took them out to repack the bearings:
The pedals only marking is S and D for left and right, so I'm assuming they're Italian. Unless that was a Japanese way of giving these more "street cred" but I don't think I've seen pedals from other countries marked S and D.
Cages are Ale, so would lend more credence to these being Italian.
I need to find some dust caps for them; any good sources on unmarked caps? I can only seem to find MKS.
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
Roto? I don’t recall there being much to distinguish the Italian brands other than level of quality, compared to Campy...
Gipiemme, Galli, Miche, etc...
No markings on the cage, I guess.
Likes For oneclick:
Death fork? Naaaah!!
Look just like the pedals I took of the Olmo, except cleaner:
Top
Top
Likes For top506:
Quoted: 3814 Post(s)
Liked 3,345 Times
wonder if Gruppo Rino may have produced some pedals which bore no maker's name...
from what have seen producers such as Galli, GIPIEMME, OFMEGA & MICHE always seemed to put their name on their products
OFMEGA products frequently private-labelled but at least had some form of name
at first glance wondered about the possibility of Notario but since they came OEM on an Olmo that would seem to rule out that manufacturer
does not look like anything have seen from Noli-Cattaneo
checked Rampinelli (ROTO) and their spindles carry the D & S markings on the spanner flats rather than the ends; also their spindles lack the shoulder on the spanner flats of the subject pedals
was thinking that another possibiltiy to look into might be OLIMPIC/SUPER OLIMPIC but the Olmo would seem to rule them out on the grounds of national origin
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I believe I once had some Ofmega pedals with same-diamond-shaped holes in the black cages. I wasn't a fan (crummy bearings) so might have tossed them but will take a look in my "old peddler's bin"
Pic courtesy of Velobase, maybe not a perfect match but "Ofmega Super Competizione" is close, IMO:
Liked 3,345 Times
thank you!
the shape of the cutouts in the plates is something looked for but did not find
makes good sense as the top506 Olmo had other OFMEGA bits as well
Likes For juvela:
Quoted: 3464 Post(s)
Liked 2,831 Times
That visually fits.
wonder when the Campagnolo toe flip tooth patent ran out?
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
https://www.somafabshop.com/shop/355...ach-3644#attr=
The tool also works on Campagnolo pedal dustcaps.:
https://www.somafabshop.com/shop/802...arch=mks#attr=
Likes For JohnDThompson:
Quoted: 1106 Post(s)
Liked 1,328 Times
I have a set of Ofmega-branded pedals, same steel cage, and a different aluminium body; it does NOT have a threaded end for the dustcap, instead it uses a snap-in kind.
Check that you have threads before buying threaded caps.
Quoted: 1304 Post(s)
Liked 1,912 Times
I have a set of these that are identical to the ones the OP has. Mine has a plastic dust cap with the Ofmega logo but nowhere on the pedals. The cages are steel held by a rivet type of fitting from the pedal body. as does the OP's set. HTH Smiles, MH
Liked 3,345 Times
as recalled, there is a generation/model of OFMEGA pedal with a black plastic dustcap which snaps in and for removal there is a small black oxide finished allen screw in the centre
when one tightens the screw it pushes on the spindle end to pop off the dust cap
Liked 1,328 Times
Two many problems with the design:
a) relies on the elasticity of a material which will change
b) relies on threads in an easily deformed material
c) despite a) and b) replacements are between costly and unavailable.
Their otherwise excellent and extremely light Sintesi pedals are so afflicted.
Liked 3,345 Times
my recollection is that this dustcap arrangement was in use approximately 1976-1983
does this line up with others memory?
pedals were of course also badged as Avocet
Old fart
Liked 3,401 Times
https://velobase.com/ViewComponent.a...m=109&AbsPos=6
https://velobase.com/ViewComponent.a...m=109&AbsPos=2
Liked 3,345 Times
thank you!
have a recollection of seeing it on other model as well but do not recall a model name/number
could of course be one o' me frequent mental lapses...
thank you!
Quoted: 226 Post(s)
Liked 258 Times
Pictures to come, but I checked with some dust caps from other pedals. They are threaded and the SR ones didn't fit, but MKS ones did. Bought a pair of MKS dust caps and filed off the logo and they work like a charm.
